Question about Dryers
Hotpoint aquaries dryer TDC32P,the fuse in the plug blew, canged it blew again, opened it up and saw 2 blue wires broken(on the back of the timer like the were rubbing on the drum as it span) crimped them back together fitted a new fuse now it works fine except when the timer finishes it stops spinning but its like it hasnt cut off and if you turn the timer dial it starts again without pushing the start button as you used to have to before?
    Sergeant:
    Champion:
  • 324 Answers
Check for a short in the timer or motor probably where the blue wire went to.
Posted on Nov 30, 2008
Hummin noise hotpoint TDC32P dryer
That noise is usually associated with a failed AC motor that turns the dryer drum.
Dec 01, 2016 | Hotpoint Dryers
Can anyone please email me a circuit diagram for the Hotpoint TDC32P condenser Dryer. thanks
on the back of your dryer remove the top six screws and inside the left top corner there is a diagram. Good Luck Tim
Feb 18, 2011 | Hotpoint Dryers
HOTPOINT TDC32P Dryer - No Heat Usual story. Have found the green spot thermostat had gone open circuit but reset it. All three stats including the one over front door test for continuity. Heating element...
Could well be a intermittentt sticking relay, I have experienced this myself, fitting new relay solved the prob, I doubt you will be able to obtain a wiring diagram , in any case , you should not need one.
I would fit a new relay myself if I were you.
Dec 04, 2010 | Hotpoint Dryers
Dryer just stopped running
2 quick ones come to mind. 1)Check the door limit switch. If it goes open circuit, there will be no operation. 2) Surprisingly, on some driers, there is a hidden fuse in the wiring loom.(referring to the larger driers). If not the problem, does it hum as you press the start?If not, switch off, open panel and trace wiring back and observe for any burned or broken areas.
Sep 28, 2009 | Crosley CDE6000 Electric Dryer
Dryer wont start, timer clicks but wont start
the thermal fuse is open its the white plastic looking item on the blower housing
Sep 10, 2009 | Dryers
Older Hotpoint Dryer blew the (house) fuse in the
Start by disconnecting the heater and stats, if it still blows, then it is probably the motor that is faulty.
Please rate my solution.
Thanks.
Aug 21, 2009 | Dryers
Hotpoint aquarious extra wd63 motor mounting broken
Made a new mounting bracket out of a piece of flat bar. Machine has never run so quietly!
Jun 13, 2009 | Washing Machines
Wd61
What ha happend is the door interlock shorted and blew the rcd. However in doing so it al blew a triac on the timer..
This is very easy to repair if you know how to get to the timer... but you also have to replace the door inter lock...
Solder a bit of wire between the connections on the timer...
If you follow the neutral wire back fro mthe door interlock upto the timer then you will see what i mean by it blowing the triac...
Jan 21, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD51 fuse issue
is it the motor that got hot?, if so then check the motor carbons for wear, as these heat up when worn, also if the carbons are fine check the pump and filters for blockages, this makes the motor spin while water is still in the machine causing the motor to overheat, and subsequently tripping and blowing the fuses etc hope i have helped a little
Sep 25, 2007 | Hotpoint WD52 Front Load Washer / Dryer
Hotpoint WD52 washing machine door not opening
hi when your fuse blew it welded contacts inside door lock mech replace and all will be fine **** it could have been the door lock that blew fuse but check carbons whilst you have top of ALL THIS IS DONE WITH THE PLUG OUT DONT FORGET
Sep 20, 2007 | Hotpoint WD52 Front Load Washer / Dryer
Dryers Logo
80 people viewed this question
Top Dryers Experts
