Question about Toshiba Satellite 1115-S103 Notebook
Powers on but won't boot a loud beeping begins and won't boot
Won't boot till i keep pushing a key pad button then it boots.
  • 38 Answers
Try resetting bios defaults
disconnect all wires in cable and then reconnect them.
pick out ram
then put it back
regards
-Mayank
Posted on Nov 30, 2008
Keeps beeping at boot
beeping in some computer is a factory installed indicator for a malfunctioning part on your computer. One possible issue on your laptop is a stuck key on one of your keyboard keys. Have your keyboard keys checked. If the issue is in relation with the universal charger, the laptop may not be recognizing it at first boot due to incompatibility with your laptop or the charger itself is damaged. Have them checked by a local technician to avoid further damage.
Oct 19, 2014 | Fujitsu Siemens Amilo M7400 Laptop...
Booting beeps
Beeping indicates that something on the circuit board is not working. On desktops beeping with no boot means your mobo is fried. And you'll need an expert to repair it, usually the vendor.
Jul 24, 2014 | Compaq Computers & Internet
Acer 5742g Beep at boot up
I have a problem that looks like this one.
At boot up, after the POST, each time the HDD led blinks, the laptop produces a loud "beep", and refuses to boot, as if this phenomenon prevented the HDD to be read.
If I press the power button, it stops beeping. When I release it, it starts beeping again.
If I press F8 at the beginning and then ask for a normal boot, It boots normally. Anyway, in windows, I have some strange activity, like I would continually pressing Alt+Tab. If I press Esc, it stops immediately and then all seems to work fine.
Any clue?
Jul 26, 2012 | Acer Aspire 5742G
White screen when I turned it on ten minutes ago, still hasn't started. Tried the option-command-p-r. Worked before for a blue screen. Is it working and will start up when it gets done?
Try holding the power button down and keep holding till you hear an extended beep, then allow to start up normally this is like a heavy duty PR zap..... if that dosent work try booting up from your OS10 or techtool dvd holding down the C key during start up if boots from the DVD go to utilities then disk utilities and run it
Aug 24, 2010 | Apple 24" iMac Desktop
Loud fast beeps on boot.( Toshiba Qosimo F45 )
Looks indeed as if the TAB key was stuck or malfunctioning. The most common cause for such behavior is a liquid spilled on the keyboard, a bit of which got between the layers of the keyboard membrane films and causes intermittent semi-short between conductive areas.
A trace of liquid caught between plastic films is hard to get rid of, as it practically sealed and doesn't evaporate.
If it doesn't go away, you may need to replace the keyboard, which is not very expensive fortunately,
Jul 08, 2010 | Toshiba Computers & Internet
PS3 startup fails
try removing the hard drive then booting it up then putting it back in and booting up again.
then try holding the power button while the ps3 is in standby (red light) till it beeps,... then beeps again,...then turns red again,....then let go and hold the power button again real fast you should hear beep....then a double beep beep. let go of button and you should see recovery console. choose rebuild file system. it will reboot and go through the rebuild steps. then if it still doesnt work go through the steps of recovery consol again and choose rebuild database.
Sep 21, 2009 | Sony Playstation 3 (PS3) Console
How to put top down 1998 BMW Convertible
depends on what type of top you have (full power or power assisted).
if power assisted, then release the latches on the inside where the top meets the windshield, then hit the button on the lower dash (its near the button for the heated seats & traction control) and give it a little push with your hand to start it folding. it has a picture of a side window & top on it. pushing it one way lowers the top. you have to be in park (or drive with foot on brake) to lower it. hold the switch down, the side windows will lower a bit and the top will begin to move. keep holding it till the top tucks under the boot and the windows begin to go back up, then release it. if the light on this button is not flashing when you release it, then the top is tucked away properly. if still flashing, then keep it depressed until the top folding sequence is complete.
if a fully automatic top (you will not have latch releases on the top where it meets the windshield), then simply hit the button as described above. no need to push on the top during the beginning sequence. keep holding it until the windows begin to go back up, then release it.
for both, watch the top as it tucks into the boot. sometimes if the top is not properly aligned, the top cloth may not tuck correctly and may require some help from you. the sequence can be stopped any time, but the red light on this button will flash.
to put it back up, simply hit the button in the opposite manner and the sequence will start with the rear boot lifting up first. fully auto tops will lock automatically to the windshield. power assisted tops will require to lock the top. if red light on this button still flashes when released, then the sequence is not complete or has encountered an error.
hope this worked for you.
Mar 09, 2009 | 1997 BMW 318
I just got a 1997 bmw convertible. How do I let the top down ? Thank you in advance .
if power assisted, then release the latches on the inside where the top meets the windshield, then hit the button on the lower dash (its near the button for the heated seats & traction control). it has a picture of a side window & top on it. pushing it one way lowers the top. you have to be in park (or drive with foot on brake) to lower it. hold the switch down, the side windows will lower a bit and the top will begin to move. keep holding it till the top tucks under the boot and the windows begin to go back up, then release it. if the light on this button is not flashing when you release it, then the top is tucked away properly. if still flashing, then keep it depressed until the top folding sequence is complete.
Jan 26, 2009 | BMW 328 Cars & Trucks
Latitude D600 beeps twice
that may be because of a bad connection with the harddrive thats easy to fix you just take the harddrive out and blow the connecting surface clean then it should behave normaly agian:)
Jan 04, 2009 | Dell Latitude D600 Notebook
No booting anymore
Sound like a motherboard problem.
If you unplug and remove the battery, the light should turn off
put the ac back in, power up, do fans spin? any beeps? just the light?
Jul 06, 2008 | HP Compaq nx6310 Notebook
Toshiba Satellite 1115-S103 Notebook Logo
91 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
