Question about Kenmore Washing Machines
Kenmore 970-c40042-00 (Frigidaire frt load) rubber particles insi
Hya all
Having problems with my 8yr old Kenmore 970-c40042-00 (made by Frigidaire, similar models in the 43142 or so series).
It died on me and upon trobleshooting I found the speed control board defective (2 transistors blown) and replaced it. Works fine now.
While taking it apart I notices rubber particles inside like the belt was slipping or something. It's like a black dust.
It does not seem that the belt is incorrectly postioned (took it out and put it back in position over the right motror drive grooves), but I don't think it's normal to find rubber inside...I'm concerned that the belt is indeed slipping and this caused the control board problems.
Is there a way I can verify this theory? The belt does not have a tensioner or something and does not seem worn out.
Thanks in advance for any suggestion/advice.
vest6
  • 196 Answers
SOURCE: Maytag LAT9757AAE,top load washer won't spin.
Sounds like a sticky brake assy. This type of brake is very tricky and should be checked be a service technician
It's possible to do it yourself but not recommended because of the 200 lb. pressure spring. Hope the diagram will help.
Posted on Jan 13, 2008
  • 1314 Answers
SOURCE: Washer-Kenmore front load belt drive model #417.40042990 (Won't final spin on any cycle.)
frigidaire did you get to the pump from the front or back
Posted on Jan 22, 2008
yalmer
  • 549 Answers
SOURCE: kenmore front load washer Model 970-C40042-00
Click this link.
They will have a manual for you.
Posted on Apr 02, 2008
SOURCE: I have a problem with
You can download the User's Manual as a PDF file for free:
http://www.fitnessequipmentcatalog.com/lifestyler-owners-assembly-manual.htm
A complete parts list is included in the manual.
Posted on Apr 09, 2008
aborcass
  • 2651 Answers
SOURCE: Kenmore 970-C41062-00 Spin cycle, belt keeps coming off
sounds as if yo umay have a bad rear bearing, and the off balance of it is "throwing " the belt. magor repair, and would ck with manufacture, for possible part warr
Posted on Mar 19, 2009
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
My kenmore washing machine (front loader, model #970-C42062-00) is not spinning the clothes dry. sometime water is left in the drum other times not. the drum is making a squeaky noise as well. what...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 22, 2011 | Washing Machines
How to increase the water level of Front loading washing machine
I have used extra weight inside the tub. I have used bottle of water and also a plastic 2 or 5 pound weight.
Apr 13, 2010 | Frigidaire ATF6000ES Front Load Washer
Mar 18, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
FWT425RHSO FRIGIDAIRE CLOTHS WASHER
if you have changed your door lock then it will more than likly be your pcb or timer
Jun 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
259 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
