Question about Whirlpool Dryers
Wont dry clothes
Clothes will not dry on high/heavy
clothes will dry after a couple of times on medium temp/it seems to be warm..
    Genius:
  • 1,122 Answers
You need to clean out wall vent and dryer vent,thats your problem-mike
Posted on Nov 30, 2008
  • MIKE major Dec 08, 2008
    your an ******* for that rating
My dryer wont dry laundry in1 cycle
A lot of the times if a dryer starts taking numerous cycles to dry clothes it is because the vent to the outdoors has become clogged with lint. This keeps the dryer from being able to discharge the moist air. You can buy dryer vent brushes with a wire attached that you can use to keep the vent clean.
Mar 04, 2014 | Dryers
What is the best setting to use to dry clothes
Medium or low heat and put a few DRY,clean towels in there.
AUTO moisture sensors will do the rest.
The HIGH setting is not good for the dryer or your clothing.
Always put in a dry article to speed the process up.
Permanent press w/cool down is good.
If you use the HIGH setting,you better be **kid and waiting for the clothes to be dry!
Sorry.
Aug 26, 2013 | Dryers
Dryer won't dry clothes
How to check the timer:
Sep 26, 2012 | Whirlpool Dryers
Roper electric dryer. Clothes not drying. Temp ok/timer not?
I would supect a faulty high limit thermostat. This small round device is mounted to a metal plate and attached to the internal ductwork. It can be tested using a multimeter or ohmmeter. Test for continuity. It should have none. Hope this helped and best wishes.
Aug 11, 2009 | Dryers
DUET DRYER SEEMS TO BE STUCK ON MEDIUM TEMP. CLOTHES TAKE TOO LONG TO DRY
Hhi, Have you checked the vent that goes outside to see if it is plugging up? Make sure it is not pinched/kinked as well.
Is this gas or electric?
Vic
May 28, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
There is no difference in drying between medium and high setting.
You only need a certain amount of heat and air to evaporate a given amount of water. If you don't notice any difference, use the medium setting. You would notice a difference with a larger load.
Feb 20, 2009 | KitchenAid Dryers
DV448AEP sensor drying doesn't seem to work
I had the same problem with mine. My wrinkle free setting some how got turned off. As soon as I turned that back on machine kept running and dried the clothes fine.
Feb 19, 2009 | Samsung DV448AEE Electric Dryer
Burner temp.
If set to high, burners should remain on. If set to medium high let's say, they would be on for maybe 70 percent of the time, off for 30 percent of the time. If set to warm, they might be on only 10 percent of the time, off 90 percent. There is a high temp limiter which could turn a burner off. If you have a burner on high and are cooking on that burner and it goes off, the high temp limiter may be faulty. It is an integral part of the burner, and would require replacement of the offending burner. Burners are individually replaceable after lifting up the glass cook top.
Oct 19, 2008 | GE JBP66 Electric Kitchen Range
The clothes dried on high or medium heat come out smelling like heated metal
hi .thanks for the question .yes i would check all venting from dryer to the outside . clogged venting, or dryer too close to the wall could cause this problem . thanks the appliance doc
Sep 30, 2008 | Kenmore Elite HE4 Electric Dryer
Open Questions:
Dryers Logo
76 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
