Question about Sony Xplod Car Audio Amplifier XM-DS1300P5 - 800 Watts Mono Amplifier Car Audio Amplifier
Xplod XM-DS1600P5 red light
Hi the amp was working fine about a month ago put it in my new car and the light is now red instead of green as it should be the sub is still the same let me no how to fix please
thanks chris
  • 15,935 Answers
For some reason it has gone into protection mode to limit further damage to the amplifier. Remove the subwoofer wires and power on to eliminate shorted voicecoil. After checking all wires for continuity to ground, a service tech will be required.
Posted on Dec 22, 2008
Xplod XM-554ZR Car Audio Amplifier: powr/protect light comes on red not green...
Hi, disconnect all speakers from unit and try again - if red light still shows then your amp has died.
If the light goes green, then start testing for shorted speaker/wiring. This includes speaker wiring to vehicle shorts - there should be an o/c reading on your meter
May 05, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
My 600w power amp XM-554ZR wont turn on.Its an Xplod 4/3 channel, and it was working fine...until yesterday that i checked it. the green light was off.
open it n there is a red wire look at the end of it n u would see a black celinder with a with a white strip on it change that part if it is burn
Jul 14, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
I need a high level input connector for a Sony Car Amplifier
best buy-wal mart-circuit city-ultimate electronics-radio shack- any stereo shop that deals with car audio-hope that helps look to spend between 12 and 35 dollars
Jun 18, 2009 | Sony XM-DS1600P5 Car Audio Amplifier
1000 w sony xplode works at low volume then red lights at volume5
Most likely one of your subs are blown, or the Ohm's are too low for the ampliphier. Try hooking up one speaker at a time to the amp and see if it does the same thing. If it shuts off on one of the two speakers, that speaker is most likely blown.
Apr 19, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Amp often decides to not work.
HI DUDE ,, TRY CHECKING UR RCA CABLE ,, COZ IT MIGHT B UNPLUGED AT UR PRE AMP OR PLAYER ... OR CHECK UR SUB WOOFER WIRE INSIDE THE BOX ....
Apr 14, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod Amp
well you might want to try using 30 amp atc fuses instead of 10 amp fuses on your amp, because you are getting an overcurrent from your alternator then from your battery. I have the same amp and you will find that your subbs will hit better too. also check on your ground wire from your amp as this also will cause the RED light to come on. :)
Mar 24, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Hello....
If you disconnect the speaker wires from the speaker terminals on the amp and the amp still goes into protect mode, the amp probably has shorted output transistors. If that's the case, the amp is probably not repairable. The outputs that Sony used were discontinued and there are no other transistors that will work properly (unless some of the newest transistors are compatible).
If it's under warranty, contact Sony. If it's out of warranty, contact one of the authorized Sony service centers to see if they can help. They may have a supply of NOS parts that would work.
Nov 23, 2008 | Sony XM-DS1600P5 Car Audio Amplifier
My sony xplod 1000w xm-1652z doesnt work anymore
First off, according to the manual, the protect light should be green. That's normal operation. If it is red, that's a problem.
If it does go red, disconnect all of the wiring to the amp except the +12V and ground. Short the remote connection to the +12V to force the amp on. If the protect light still lights red, the issue is inside the amp and will need repair. If the issue goes away, try reconnecting one wire at a time until the protect light goes red again.
Mar 23, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony Xplod Car Audio Amplifier XM-DS1300P5 - 800 Watts Mono Amplifier Car Audio Amplifier Logo
243 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
