Question about Gigabyte GA-8SR533P Motherboard
No boot, got continuous beeps at first, reset my 'savage2000' VGA card
After I reinstalled the VGA card, everything stopped, now only the fans are working, i tried running the mobo without anything on it, still nothing(only fans run) checked the processor on another mb it working fine, cant think of anything else, help!!
  • nasser ahmed Jan 22, 2007
    Thanks sandrew!!,
    I pulled out the cell; waited for 10 min's and put it back in, now it's running, I jiggled the ram slots too, :)
    I wonder which one worked, but now I'm getting bold colored lines when I use my old savage 2000 VGA card, any suggestions?
  • eustlr Mar 23, 2009
    My computer ( GA-8SR533P) just gives a continuous beeping sound. I cannot see where to clear the cmos, juts the instruction 1-2 clear cmos, and 2-3 cmos. Any help?
    Eustace.
    President:
  • 2,961 Answers
The solution may be to locate the JBAT1 terminal and move jumper from pins 1-2 to pins 2-3 for a few seconds and back again. Turn on pc and then hopefully you can access the bios to set the time and date and save settings then re start.
Posted on Jan 22, 2007
  • andrew pester
    andrew pester Jan 22, 2007
    Check that the driver isn't corrupt, run a little video test, go to Start>Run, then type 'dxdiag' and hit enter.
    If all else fails check that your agp card is set to the primary graphics controller in the bios settings, or uninstall driver, restart pc and let windows find your card again and install the driver, although don't let windows install it's own generic driver as it may cause problems.
    I'm assuming when you say VGA card you mean AGP, as VGA is normally the standard on board graphics set up which would be a different driver.
Continues two beeps and wont boot
From the time it start beep it means either your ram or video card is not good. My recommendation would be checking to connections of the ram and the any other card you have installed on the motherboards or simply just dis connect them wait a couple seconds and connect them back properly and firmly.
KJR
Jan 10, 2013 | Foxconn Computers & Internet
I am running Unix Tru64 5.0 on Compaq Alphastation XP1000. The computer does not boot and does not display anything and does not beep. The power supply works and some LEDs are on on the logic board and the...
Hi.first pull-out your motherboard in the CPU case then power on without memory only processor installed.if you hear continuous beeping your motherboard is working good.
try this beep code means.
No beep means short,no power,bad CPU,loose peripherals.
One beep means everything is normal running motherboard.
Two beep means CMOS error IC.
One long beep,one short beep means motherboard problem.
One long beep,two short beeps means video card problem.
Three long beeps means keyboard error.
Repeated long beeps means memory error.
Continuous hi-lo beeps means CPU overheating.
Hope can help you.
Jun 18, 2011 | Compaq AlphaStation XP1000 PC Desktop
Mobo fried? Beeps when startup but no video. I reseated ram and video card, with no luck. Both fans work and it sounds like it is booting. I tried older video card too but nothing. Thanks for any...
Try removing the display card and using the onboard VGA. Remove the BIOS/CMOS battery for about a minute and then reinstall it in the correct orientation. This will reset the BIOS/CMOS to it's default settings. You say it beeps once, this means that it is fine the mainboard is ok, it is not experiencing any problems. If it beeps in a continuous manner then it is the RAM that is causing the problems, I would say that the default settings may solve your troubles. Remember to enter the BIOS/CMOS when during boot up to reset the date and time by hitting the delete key. Also try entering the BIOS/CMOS even if you can't see any thing on screen, by doing this it may come up. let me know how it goes, I am here to help.
Thanking you
damnor01
Nov 09, 2010 | HP Compaq Presario SR5450F Desktop PC
NO DISPLAY COMING. CONTINUE DOUBLE BIP SOUND. PROCESSOR FAN RUNNING.
Try removing your memory and than reseat it. One DIMM at a time and boot the system in-between each.
Still hear the double beeps? Its possible one DIMM may be defective. Continue.
Clear the bios. See page 1-7 in your manual. When the bios has been reset everything will revert to default settings. The onboard graphics will give you back video. Enter the bios and set the bios so the PCI-E card is used. Save and exit. (Most likely your PCI-E card also needs a power adapter connected).
If the system goes back to double beeps try removing the PCI-E card and than reseat it. (Possible loose connection).
Happy 4th!
Mike
Jul 04, 2010 | ASUS M2N68-AM SE2 Motherboard
When i try to boot my pc, it continuously beeps
check it one by one first is remove the ram, then then restart it, if nothing use another vga card ..insert the ram and then start again.. else..reset it by removing the battery in few second the start again until you find the couse of that problem..
Sep 13, 2009 | ASUS P5N32-E SLI Motherboard
No beep sound after switch on my desktop computer but power led of CPU are on and glowing , drive light are blinking and screen is black. Inspite of checking the memory ...
hmm if it not beeping it means that is something wrong with the Ram memory ..check if its right inserted ...and is it is ...remove the bios battery , to reset it ..and reboot...you might have to reinstall cause sometimes when everything appears to be ok .but get blank screen its cause you messed up with the video card driver ...or collor setings...reinstalling will fix the problem if its from there ..but cause its not beep-ing at boot means its not recognizing the RAM memory ...
So ..the cause may be multiple ...either you changed the frequency of the memory ..and its out of its range ...or you have made changes on the memory configuration ...( changed ram or added more...) and in this case its just making a little click like its booting in looping ...if the memory its still working ...removing the battery for a few moments and restarting will get the bios on the default optimal factory settings ..and it will take the memory frequency at automatic values ....Good luck !
Sep 03, 2009 | Computers & Internet
HP P4B-MX beep
HP P4B-MX is Award Bios
Award and Phoenix BIOS:
1 short beep: Normal
2 short beeps: CMOS error
1 long and 1 short beep: DRAM error
1 long and 2 short beeps: Video card error
1 long and 3 short beeps: Keyboard error, or video card error
1 long and 9 short beeps: ROM error
Long continuous beeps: DRAM not installed correctly, bad memory, or incompatable
Short continuous beeps: Bad power supply
Jan 19, 2009 | HP (5185-6477) Motherboard
Abit nf8-v keeps beeping when turned on. no video
How is the beep sounds? Long beep and three short beep or one (-...) or all long beep?
For the first, usualy the VGA connector is not correctly seated, so the motherboard can say it has no output device and beeping.
The last is usually memory problem. Try, unplug your memory board and replug it again, make sure that it is correctly seated.
Dec 10, 2008 | Abit NF8-V Pro Motherboard
Bios Beeps and no boot
Remove and reinsert the dimms
reseat the video card also
put everything back and try agailn
If this dont work reseat the cpu and repeat steps above
If the above fails to fix
If it will boot into safe mode
and use the standard vga as
you did before and restart
and try to reinstall the drivers
You are sure you installed the rilght
drivers for your OS
It may be that the card is not compatible
wilth your mobo.Try checking compatability list
for your OD
Nov 16, 2007 | ASUS A8N-SLI Deluxe Motherboard
Gigabyte GA-8SR533P Motherboard Logo
218 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
steyr1
pankaj rautela
pankaj rautela
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
