Question about Soleus HGW-308 Mid-Size Heater
Heat does not come on Coleman furnace - Soleus HGW-308 Mid-Size Heater
  • Edward Mouton
    Edward Mouton Jan 07, 2009
    Turned out that there was a sensor that was clogged that prevented the igniter from firing. Cleaned it out with a pipe cleaner and it lit.
  • dsnoogy May 11, 2010
    HGW 308R heater is not heating. One year old. Is this something simple? All buttons and functions seem to work.
    Doyle Haynes
    dsnoogy@sbcglobal.net
  • 61 Answers
See if your hot surface ignitor is glowing when you first fire up.
This is the most common cause of the unit not working
Posted on Nov 30, 2008
Coleman evcon furnace
So the furnace will come on and heat sometimes ? Then other times it will click but not heat ?
Check for fault codes if it has them and make sure it is clean inside burner tubes and clean the flame sensor.
Oct 13, 2013 | Heating & Cooling
My coleman central electric furnace only blows cool air
The AC unit outdoors must be running and rejecting heat by its air flowing through it the 2 copper lines are the refrigerant lines, the fatter one should be "beer can cold" if not its low on refrigerant or not running.
Jan 01, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Coleman mobile home furnace pilot light turns off when blower turns on
Heat exchanger could well be split causing it to blow out pilot
Oct 27, 2012 | Heating & Cooling
My Coleman propane furnace kicks out once and a wile and flashes a 10 flash code (gas flow with no call for heat) what need to be fixed the furnace is only 1 year old.
This sounds like you have an intermittent main board problem. It may be turning on you furnace when the thermostat is not calling for heat. It also could be a short in your low voltage(thermostat wire) going to your furnace. Either way you need to have it checked. It's under a year it should still be under warranty.
Jan 23, 2011 | Coleman Propane Forced Air Heater...
Coleman roof top a/c, is the heat controlled by thermostat
hi
on the new colman units (trane) the heat is control only from the t-stat.
i will reccomand a programble t-stat for the new unit.
thanks
Nov 02, 2009 | Coleman Mach III Air Conditioner
Draft fan keeps on running after furnace shuts
That sounds pretty normal for most furnace/heater products. They run the heating element with fan for a cycle then after the heater reaches temperature it will shut off and the fan will continue to run to cool the element and to circulate the heat that it produced. If you want the manual for this product it looks like you can get it here: http://homeappliance.manualsonline.com/ex/product/headline/m/Coleman%2BEvcon/d/furnace/p/DGATO75BDC
Oct 26, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Burner flame going out on windy days on Coleman Evcon LP furnace
This sounds like a bad heat exchanger. It is possible that you do not see the crack because the crack is closed when the heat exchanger is cold (or room temp). Allow the furnace to heat up, this will allow the expansion of the crack. Turn the power off and examine the heat exchanger while it is still hot.
Mar 31, 2009 | Coleman Propane Forced Air Heater...
Soleus HGW-308 Mid-Size Heater Logo
123 people viewed this question
Top Soleus Heating & Cooling Experts
Michael Galve
Michael Galve
Coss
Dennis Boxerman
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
