COMPUTER WON'T RECOGNIZE LIGHTSCRIBE DEVICE
NOTHING MORE THAN ERROR MESSAGE STATING ABOVE
  • James Vernon
    James Vernon May 11, 2010
    Do you have a lightscribe drive, just becasue the box says lightscribe does not mean it was not swapped or not installed. check the drive itself for the light scribe emblem and verify that the drive you have is a lightsrcibe.  Ihave seen this in HP products where some people thoughtthey ahd lightscribe abd they only had rw.
Windows Vista does not recognized the Brother HL-2240.
hi Markaz.
you can try is to open Device Manager, expand USB Serial Bus Controllers, right-click on USB Root Hub and then click on Properties. Click on the Power Management tab and uncheck the Allow the computer to turn off this device to save power box.
or read up more at this link.
How to Fix USB Device Not Recognized in Windows
What do I do if my USB device is not recognized? Method 4: Reinstall USB controllers.
  1. Select Start, then type device manager in the Search box, and then select Device Manager.
  2. Expand Universal Serial Bus controllers. Press and hold (or right-click) a device and select Uninstall. ...
  3. Once complete, restart your computer. Your USB controllers will automatically install.
Error: "USB Device not recognized" when you try to access a USB ...
https://support.microsoft.com/.../error-usb-device-not-recognized-when-you-try-to-acces... Search for: What do I do if my USB device is not recognized?
or this link.
Windows does not recognize the USB device Google Search
Dec 02, 2017 | Brother HL-2040 Laser Printer
My computer does not recognize my hp 557s as a lightscribe compatible device
Hi professa31!
Have you tried installing the Lightscribe software bundle? Their website says that it's required for operation of any lightscribe device. Here's the link: http://www.lightscribe.com/downloadsection/windows/index.aspx?id=810
Also, it appears that there are a bunch of reasons why it may not be detected, most of which are not bad at all. Here (http://www.lightscribe.com/support/index.aspx?id=401) is a list of a few reasons, from the lightscribe website.
Mar 03, 2011 | HP Hewlett Packard HP DVD557S 8x USB Slim...
My SuperMilti Dvd Burner with Lightscribe tech is not being recognized by the software as an available driver. The lightscribe template labeler shows "no lightscribe drive". If it's installed in my pc,...
I assume it's a USB device.
If it does not appear in 'My Computer' as a 'drive letter' device, the most likley problem is DRIVERS = go to manufacturers web site & see if you can find a driver specirfic to your (not stated) operating system (if it's a 64bit OS you are on your own ...).
Aug 21, 2010 | Computers & Internet
Matshita DVD-RAM UJ861H Lightscribe fcn not working
its light scribe day.
again, no pC stated, nor OS stated? why?
1: bad media
2: bad drive or HP don;'t support it.
3: wrong OS loaded, W10?
4: HP dont support this now.... why use it?
5: missing driver for it, matching OS and drive, yah. that be it .
ask hp yet, its not supported now.
https://h30434.www3.hp.com/
try google for alternate support, non HP???? be wise !
Aug 19, 2017 | HP Computers & Internet
Sony Optiarc AD-7581A 8x DVD?±RW DL Notebook IDE Drive w/LightScribe Burner is not being recognized and installed.... It shows the error 10 "device will not start" can anyone help?
Try a cold boot. Shut down the computer. Remove the battery. Unplug the power cord. Wait at least five minutes. Start up the computer. If still does not work, go to device manager --> CD/DVD drives. Uninstall the Optiarc drive. Go to Actions --> Scan for Hardware Changes, or simply reboot to reinstall the drive.
Apr 05, 2010 | Sony Optiarc AD-7581A 8x DVD?±RW DL...
Windows Vista recognizes the Memorex DVD- RW multi recorder w/Lightscribe device and the Lite-On CD-ROM device, yet fails to recognize the drivers sending an error code 10. It says the device is unable to...
You need to have a software driver download for the Memorex DVD-RW and Lite-on CD ROM. You can have it from the Internet. Just type at the Search engine blank (Download for driver of Memorex DVD-RW). Upon reaching the site, Choose the one with Windows Vista OS. Then, thereafter you can get the download for Lite-on CD ROM. After having the
download, go back to your PC menu and open the
download to install it. Once installed, test it. And job
well done.
Nov 27, 2009 | HP DVD 740VI 16X16 Dual Layer LightScribe...
Lightscribe will not recognize verbatim lightscribe cd
PLEASE USE THE CD LABELED "LightScribe"
AND WHEN U R WRITTING THE COVER ON IT PLEASE FLAP IT THEN WRITE IT MEANS ANOTHER SIDE OF GREEN SIDE OF CD OR BLUE SIDE OF DVD
PLEASE VOTE FOR ME
May 11, 2009 | Microsoft Windows XP Home Edition
Not recognized by PC
get replacement fm vendor. u have 5 yrs warranty on this
Apr 20, 2008 | Electronics - Others
Unknown device
this is an error message stating that. the usb device is faulty.
It has detected that the usb port has an error/fault or problem.
check that non of the pins are touching each other, or that dirt or dust isn,t inside the usb connection port. blow in it. or use a cotton bud to swab it out.
Mike @ Compurepair.
Feb 23, 2008 | Sony PlayStation Portable (PSP) Console
Computers & Internet Logo
329 people viewed this question
David Payne
David Payne
