I'll go to turn on the tv, and it will just turn on and off for about 5 seconds, and has no picture or audio, what to do?
Im going to assume if you press the on button on the remote or the tv, that is just clicks at you and does nothing then turns off...if so kiss it goodbye..it's a problem with its main board and there isn't really anything you can do to fix that. Unless you are good with electronics that is...if it's new it may be under warranty, if it's old well then no luck there...
SOURCE: TV has green sceen and turns off by itself
dont do nothing with that tv go and buy a new one and thats all...good luck
SOURCE: sony kv-32s26 32 inch tv
Could also be faulty Power supply. If Proper 110 V is not generetaed by SMPS, the above symptoms appear.
SOURCE: RCA Television D52W14
The first thing in this unit is to check the ribbon cable that goes from the front control panel to the back ssb board, I would unplug and replug to make sure seated properly. Then try it again. There are alot of screws to take out but worth it if this solves the problem.
SOURCE: Rca Big screen shut down and now no power
NO audio and no picture .... no power to on - off button. Checked outlet and it is good .... cable connection good - checked with another tv....
SOURCE: SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
