Question about Canon GL2 Mini DV Digital Camcorder
No memory card light keeps flashing on GL 2 Video Camera
Although I have a memory card inserted, the 'no memory card' light keeps flashing red on my new GL2 video camera. I just took it out of the box. I have formatted the memory card that comes with it and a Sandisk card I bought at the store at get the same problem with both. Is it the camera or should I send the camera in for maintenance?
  • 44 Answers
Hello, If your brand new camera will not even regognize the SD card that came with it (in the box, 8MB card I believe) and you can format/read the SD cards in your computer, than it must be related to the slot/pins inside the camera. You can also format SD cards directly from the camera but if it won't even recognize that one is inserted, the camera needs to be returned.
Good Luck!
Posted on Nov 30, 2008
    Sergeant:
  • 276 Answers
Try any other memory card in your camera or try your memory card in any other device to confirm the fault.
also try reformatting the card.as reformatting deletes the old data on the card.
  • 333 Answers
If you just took it out of the box I would take this unit back. It seems that the camer is not recognizing the memory card. If you have this problem with this new unit who knows what else is wrong with it.I hope this helps you.
  • 10,594 Answers
Seems memory card holder pins are not making good contact with memory card.
Please check memory card slot and observe contact pins.
  • Canon Master
  • 19,396 Answers
First ensure that you have used the right format, I think the camera should support FAT32.
Test a different memory card and use the camera to format the memory card.
    Sergeant:
  • 217 Answers
Remove the card and clean the area where u insert the card in the camera.if any dirt.and if under warranty sending it to the service center is much advisable,
Thanks for the info. You mentioned factory reset. How does that work?
You should find the reset to factory default option within the camera's menu options.
Try this too: Remove memory card before resetting.
Turn off the camera, and leave the camera without inserting the battery & memory card overnight allowing it to reset.
Dec 10, 2014 | Canon Powershot A1200 12. Megapixel...
Canon t3i will not turn on without sd card?
This a situation the manual not even mentions. The red light on the bottom right of the camera is the memory access indicator. It should light green as I remember ok. And blink when it is writing to or reading from the memory. If it is red, it means : this is not ok.
This light is not a gadget. It should be taken serious. As long as it is burning, of flashing you are not supposed to switch of the camera or to remove the memory card. If you still open the memory compartment or switch of the camera or remove the battery, while the camera indicates I'n accessing the memory, serious damage can occur to the memory card.
You could lose all your pictures, because of it.
I would suggest, make sure your battery is charged correctly.
Format your memory card in a PC with FAT 32.
Check if al contacts in the camera are clean and shiny. (Battery and memory card contacts too)
The place the battery and the memory card in the camera and try switching it on again. If it should start, first do a format of the memory card in the camera before you starts taking pictures, of the camera has its own format and can make a folder.
You should be able to switch on the camera without a memory card inside. The camera will us the internal buffer, to let you take a picture in DEMO mode.
I hope the red light does not indicate your internal memory is corrupted. Because if nothing helps and the red light comes back, I think you should contact a Canon service centre.
Jan 14, 2014 | Canon EOS 600D Rebel T3i Digital Camera
When i click red light indicates in front and near camera to video camera a red light blinks
Hi there remove the memory card and then reset the camera. After that take a back up of your image from the card and format the memory card. Now insert the card in the camera and turn on. Let me know whats the result now.
Feb 21, 2011 | Nikon Coolpix S210 Digital Camera
I have a Conon Powershot S1 IS camera and bought a Transcend Compact Flash 4GB memory card and when I insert in into the camera a red light flashes at the menu and set buttons?
Have your new memory card inserted into your PC to test for any virus. Format the memory car.
Please check if your cannon is adaptive to the 4GB (check the instruction manual) if the card shows the same fault now after inserting.
Use another card into the camera to confirm if the card slot is faulty.
Sep 13, 2010 | Canon PowerShot S1 IS Digital Camera
I have a HP PSC 1610 All in one printer and I tried putting my media card in the SD slot and it tries to read the card but the red light flashes and says memory card error. HELP Please!
If using the Card Reader -
The HP all-in-one has detected an error with the memory card.
1. More than one memory card is inserted in the HP all-in-one.
2. An incompatible camera is connected through the camera port.
3. A memory card is inserted and a digital camera is connected at the same time.
Solution:
Remove and reinsert the memory card. It may be inserted incorrectly. If the problem continues, the memory card may be defective.
Remove one of the memory cards. Only one memory card can be used at a time.
Check the user guide that came with the camera to see if it supports PictBridge. If it does not, try using the cable that came with the camera to connect the camera to the USB port on the back of the HP all-in-one instead of to the HP all-in-one camera port. If the camera does support PictBridge, make sure the camera is set to PictBridge mode. See the user guide that came with the camera for instructions on how to do this.
Remove the memory card or disconnect the camera. Only one can be used at a time.
You might try the following - Reformat the memory card in the camera or format the memory card in a Windows XP computer by selecting the FAT format.
Hope this helps!
May 01, 2010 | HP PSC 1610 All-In-One InkJet Printer
My 12th old ps3 has been faultless until 6/2/10 .It will not boot up at all .The start up red light turns to green as per normal then after 2 seconds it flashes red and goes back into stand-by mode Any...
That is the PS3 "Red light of death"
The articles below could help you fix them :)
<a href="http://ezinearticles.com/?Have-You-Got-Issues-With-the-PS3-Red-Flashing-Light?-Fix-This-Problem-Today&id=3629324">PS3 Red Flashing Light</a>
<a href="http://ezinearticles.com/?PS3-Red-Light-Fix---Quick-Guide&id=3512073">PS3 Red Light Fix</a>
<a href="http://ezinearticles.com/?PS3-Blinking-Red-Light-Problem-Solved---If-You-Have-This-Problem,-You-Really-Need-to-Read-This&id=3512063">PS3 Blinking Red Light Problem</a>
<a href="http://ezinearticles.com/?PS3-Red-Light-of-Death---How-to-Fix-it-Quickly-and-Easily&id=3512067">PS3 Red Light OF Death</a>
<a href="http://ezinearticles.com/?Thinking-About-Buying-a-PlayStation-3-Repair-Guide?-Then-You-Better-Read-This-Before-You-Do!&id=3676847">Playstation 3 Repair Guide</a>
Feb 07, 2010 | Sony Playstation 3 (PS3) Console
Cha flashing when new memory card inserted... have tried several to no avail... please can you help?
CH A error indicates that the camera can not communicate with the memory card. Most often this is caused by formatting a memory card in a computer and then putting it into the camera. (Especially on 4 + gb cards). Solution is 1. Reset the camera - then it should work with cards that it worked with in the past. 2. Take the bad memory card and reformat it in your computer to FAT not FAT 32.
It should now work - although it will show capacity to be only 2 gb...
I believe at that point, if you reformat it in camera it will work at the full 4 gb.
Oct 22, 2009 | Nikon D2X Digital Camera
Sony CX-12 Camcorder gives message when memory stick inserted
Hi!
This is a feature and not a defect of the CX-12 that reminds the user that the memory stick inserted might not be able to record the data from the camera effectively. HD video requires a memory stick with a relatively fast data read/write speed, and the CX-12 recommends not using any other stick that is not Mark 2.
Fortunately, though, as you have found out, it does not affect the camera's ability to record in non-Mark 2 sticks.
Hope this helps!
Nov 13, 2008 | Sony Handycam HDR-CX12 Flash Media...
Memory card
memory card is bad, repalce it
Oct 24, 2008 | Vivitar DVR 530 Flash Media Camcorder
Red flash and appears to be frozen
Yes, I get red flashing too occasionally.
turn the power off and on using the button under the screen.
reformat the card either via a computer of if possible via the camera menu item.
Remove and re-insert the card.
purchase a new and faster SD card.
Jan 06, 2008 | Sanyo Xacti VCP-HD2 Camcorder
Canon GL2 Mini DV Digital Camcorder Logo
47 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
