Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
Ice maker runs continueously
There is a temperature probe at the top of the bin. When the ice level reaches the probe the ice maker shuts off until the ice melts to below the probe and then it cycles again. Recently , however, the ice maker does not shut off when it reaches the probe. It continues to make ice continueously and the level rises all the way to the water pan. The ice maker is a Hoshizaki KM-150 BAF.
    Problem Solver:
  • 7 Answers
Simply test thermostat by placing ice on stat unit should turn off in less than 20 seconds. Remove ice machine should come on in a minute or two. If not reacting properly there is an adjustment in rear of machine. Follow cap tube back to thermostat. Warmer more sensitive. Colder less sensitive.
Posted on Feb 05, 2009
    Scholar:
  • 39 Answers
I don't have the details on you machine but if I were going to trouble shoot this problem, assuming its a temperature probe I would power off the machine, remove the access panel and remove the temperature probe and check it with an Ohm meter or continuity checker for proper functioning by putting the probe in ice and see if it opens electrically. Sometimes the probe is not a simple thermostat type. The bin control on some machines is optical. The ice pile breaks a light beam to turn off ice making. Sometimes the probe is a thermistor. These latter two kinds of probes have electronics connected to them. A simple ohm check will not work for these cases. You can tell what kind you have by looking at it carefully. The thermostat kind that can be checked with a continuity checker or ohm meter is a sealed metal tube. The optical type has a light source and a separate pick up sensor. The thermistor type is a very small device on the end of a pair of wires. For the optical type or the thermistor type write back for more details.
Posted on Jan 19, 2009
Why does my ice maker not get cold enough to produce ice? I have a Samsung RFG297HDRS French Door refrigerator. Everything is functioning except for the ice maker. Water is getting into the ice maker
Ok Randy, Lets fix it.
My name is Peter. I am a retired refrigeration field service technician.
You are not getting cooling air to your ice maker freezer compartment. Once again Samsung - bad design - put a ice maker in the fresh food section.
So, you have a ice maker enclosed next to the fresh food section where the recommended temperature setting is 35-40 degrees F.
Where as your recommended freezer temperature is +2/-2 degrees F.
There is a air damper/vent from the bottom freezer in the back of your ice maker housing. Lets remove the ice maker to check for ice build up. On the left hand side of the housing on the wall there is a long narrow cover plate. This is where you connector harness is located. There are 2 screws holding the front end in and a tong and groove tab in the back. Remove the cover plate.
Now, pull the harness out.
Lets remove the ice maker assembly. There are two screws in the front end securing the ice maker to the top of the casing. These screws are recessed. They are either Philips heads or hex heads (1/4"). If they are hex head, he recessed hole diameter is small. Some hex head hand tools will not fit. A screw gun will work or a small outside out side diameter hex head hand tool.
Remove these screws. In the back in each corner is a tong & groove. Pull forward to release the ice maker. Using a small flat head screw driver wedge the wire harness to release. Set the ice maker aside.
Inspect the air vent/damper for ice build up. Use a hair dryer to defrost.
I do not believe you have a automatic damper controlled by a thermistor (temperature sensor). If you do, Remove the damper assembly. Get your multi-meter. Set your meter to the lowest Ohm reading (Omega on your meter) Touch the two probes on your meter together, you meter should read 1.0. Disconnect the 2 motor contacts. On the motor place one probe on one contact and one probe on the other contact. If the meter still reads 1.0 the motor is bad. If the meter reads 0-50 Ohms the motor is good.
If there is no ice buildup & the damper motor checks out, replace the temperature sensor.
You will find getting the wiring back into the side panel will be a little difficult. As usual, Samsung is not service friendly.
Oct 22, 2014 | Samsung RFG297HDRS 29.0 CuFt French Door...
My Ice maker doesn't make ice anymore
90% of ice maker problems are water related. Sounds like water may be continually seeping in from the inlet water valve (normal thing to do if the water level is low). This will not allow the water to get down to freezing temperature. You have to identify the reason that water is constantly running in. It's probably "leaking" out at the dump valve. Or does that unit have a float valve that may be leaking. Check your drain to see if water is leaking out during the freeze cycle.
Jul 07, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Franklin chef ice maker fim70 finished running cleaning cycle. have cleaned plugs, lines, on rear and sprayer inside bin. water continues to run, ice forms on top (w/ frost). Ice never drops.
Hello
Ice may jam up in an ice dam and close off the chute. Shove the ice scoop up into the chute with a fair amount of force to break up the ice dam. Chunks of ice should fall into the bin, followed by a shower of ice cubes.
Jun 21, 2011 | Franklin Freezer Chef FIM70 Commercial Ice...
Alarm keeps going off
Alarm will sound if the temperature of the freezer rises to unsafe levels. An indicator light will flash and continue to flash until the temperature reaches a safe level. The buzzer will also sound and will continue for 48 hours unless a safe condition exists.
Dec 14, 2010 | Kenmore Freezers
My ice maker does not work
Good day,
The freezer must be below 12 degrees before the ice maker will activate. If it's o.k. then follow the steps outlined below. It will solve your problem.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Nov 28, 2010 | Kenmore Freezer 20.6 cu. ft. Upright...
My ice maker isnt working in my fridge model 106 59292993 the bar is in the down position like it is supossed to be and it sounds like its trying to make the ice but just isnt, do you know why?
Good day,
First off the freezer must must be at 10 degrees or lower. The ice-maker will lock out automatically at any temperature above 12 degrees.
Follow the steps. It will get you there.
Nov 27, 2010 | Kenmore Freezers
Ice maker will only make crushed ice and no cubes, what could be the problem
Open the freezer door.
Pull the ice bin forward about 3 inches.
Push the ice bin to the rear of the freezer until it seats and locks in place.
Then try to dispense cubes.
The ice bin can become dislodged from its locked position and the crushed ice solenoid activates automatically.
Sep 17, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
The ice maker does not stop making ice when the bin is full
dear sir/madam
please make sure first your freezer,s defrost mode selecter set on auto mode or it,s set on auto defrosting mode. if it.s or freezer making continuously ice in ice bin then defrosting control device or temperature controller is not working for repair it please contact to your maintenance personnel for replace it .i hope after that it will work properly.
hope answer the question
thank you
please vote!
Aug 24, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Ice maker not making ice
Hello there:
There's no ice If your ice maker has stopped producing ice completely, check these, in this order: It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: bullet.jpg If your ice maker has a small red plastic lever, lower it to lower the wire. bullet.jpg If there's no plastic lever, simply lower the wire. bullet.jpg In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Aug 07, 2010 | Maytag Freezers
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
251 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
