Question about Samsung TXN3298HF 32" TV
Samsung TXN3298HF 32" Flat CRT is dead, please help
Hi, I have a Samsung TXN3298HF and it will not power up, no beep or LED action. It's like pressing a button on the TV when it's not plugged in, it will do absolutely nothing when I press the power button. I took the case off and I checked the inline fuse and it is fine. I can at least verify that 115V is getting to at main system board inside. Just today when I hit the power button, the TV does nothing. Does anybody know of a common problem with these TV's? Or where to get a reasonably priced service manual? I'm guessing it's power supply issue or there is some safety circuitry that kicked in. Thanks, AM
Hi I have a Samsung Tantus Dynaflat 32 inch flat screen TXN3298hf that all of a sudden stopped working...no power no nothing. We opened up the back and found that a 5 amp fuse had blow. This fuse regulates that power supply to the tv and can be found at the end of the power cord prior to the circuit board. Hope this helps.
Posted on Nov 22, 2009
If only you know how to use digital tester or analog then it easier for you to conclude cause you need a voltage reading the power supply,the ac input then dc input and the power regulator in and out voltage.
Posted on Feb 12, 2007
  • 38 Answers
I had encountered the same problem and i isolated the rectifier diode located at the secondary area of the power supply board. I found out a shorted rectifier diode. Replace it and im sure this will solve your problem that if the part that i mention is the same that i encountered.
Model Ln32a 450C1D. Why won't it turn on?
Samsung LN32A330 repair. Won't turn on. - YouTube
? 2:53
www.youtube.com/watch?v=CTBIwUbBArY
Mar 20, 2013 - Uploaded by bigdog8882 Watch BigDog in action as he repairs this Samsung 32" LCD tv that has no power. http://607cash.info.
Aug 07, 2015 | Samsung Televison & Video
TV wont power up
Hi Tony,
Please let me know if it has a led light at the front panel or the unit is totally dead set. It will help to determine where the fault came from.
Jdvillanueva
Oct 08, 2011 | Sanyo DP32648 32 in. LCD TV
Blank screen led light flashing on/off manual switches do not work
hi;
when your LCD TV wont start , even if you press the power button , it has a power supply failure, maybe some capacitor has bloated or changed value, try to watch this http://www.youtube.com if you know how to solder, or even disassemble the back of LCD TV. if not try to call a repair technician. thanks ,, hope this help........
Sep 10, 2011 | Samsung LN32A330 32 in. LCD TV
My brand new Samsung LN32B530 lcd 32'' crashed during a software update (from "2004" to "2006", no idea what that means). The TV looks dead, the only thing it does is flashes the red led (bottom right)....
This usually indicates that the main board is dead. A bad or incomplete download usually takes out the main board. You can call 1-800-samsung and see if they will warranty the main board and labor.
May 06, 2010 | Samsung LN32B530 32 in. LCD HDTV
My tv died last night no power at all no stand by light or sound It is a Samsung Tantus Model number TXN3298HF CRT
check first power ac cord by removing back cover trace if ac line voltage found, check for possible burn fuse. make a record after that scenario trace and log voltage trace from power supply ckt area.
Mar 26, 2010 | Samsung TXN3298HF 32" TV
All of a sudden no power.TV will not turn on using the power button on the console or the remote.
Unplug TV from power. Remove the back of the TV enclosure by removing all screws. Slide the side pieces off. Follow the power cord to where it connects to the circuit board. Immediately to the left is a 5 amp fuse in a snap in holder. Remove and replace with the same type of fuse (250V 5 amp fuse). Plug power cord in and wait 5 seconds. Try power button on either TV or remote. Reassemble TV enclosure.
Nov 08, 2009 | Samsung TXN3298HF 32" TV
Why does my Samsung 32" keep beeping? no picture, beeps every 4 sec.s and the power lights flashes. Why???
The set is trying to start but it is detecting a problem so it keeps trying. Most likely you have a horizontal or high voltage problem. Hard to say. Have a shop check it out for you. Thanks
Oct 28, 2009 | Samsung TX-P3264 32" TV
SAMSUNG T.V MODEL; CS-29Z40HE This T.V buy on JULY 2007 PROBLEM; No power; total dead; no red led stby; have beep sound...tick...tick...like not enough power when power on (maybe sound come from relay)....
Check the PTC parts,the primary AC power supply board.Disconnect the power supply board,measurement the capacitors and power tranzistors,measurement the output voltage(155V),connect on the output on 60W electric bulb,if it light the power source is ok and the problem in the horizontal driver parts(trafo,power tranzistor...).
Sep 27, 2009 | Samsung Televison & Video
32" Samsung TV, No Power or Sound, power LED on, flashes 3 times
Most likely the set has lost vertical sweep or the feedback from that circuit. This will shut the set down to prevent a horizontal line from burning the face of the CRT. This will have to be looked at by a technician.
Sep 11, 2009 | Samsung LN32A330 32 in. LCD TV
Samsung TXN3298HF 32" TV Logo
223 people viewed this question
Jerry Greenberg
Jerry Greenberg
