Question about Mach Speed VENOM V2DP Motherboard
Memory solution I 'am assemblying a Mach Speed motherboard ...new in box and had for 3 years ....free . Bought 1 gig ddr2700 (333MHZ). also a amd athlon xp 2200 throughbred 1.8g cpu 266 FSB Question: will this memory 333MHZ/266FSB work together.....do I have to change any jumper on M/B
  • readamanual Nov 30, 2008
    Thanks Howard
    I need help with setting jumper on M/B , Do I set jumpers to
    100 MHZ
    133 MHZ Default
    166 MHZ
    Memory is 333
    Scholar:
  • 162 Answers
No need to change anything. just put your ram into memory slot . it will be auto configured it
Posted on Nov 30, 2008
  • 341 Answers
Here is the information you will need.
http://www.shopping.com/xPF-MACH-SPEED-MB-VENOM-V2DP
In call of duty ghost do i need to buy 1 whole 8 gig of memory
You need to have 6 gigs of free dynamic ram.(Not including that used by the operating system and any other applications you have.
The way that memory is organised in a computer these days is usually in pairs or DRAM (dynamic random access memory) sticks which are matched. This allows the CPU to withdraw data from both memory sticks in the same clock cycle (DDR double data rate) which improves the over all speed of the processing.
So legal combinations over 4 gigs which will use the dual channel feature on your motherboard will probably be.
2 x 4 gigs sticks = 8 Gig DRAM
2 x 8 gig sticks = 16 Gig DRAM
Below is the minimum specification requirement.
Note: MINIMUM Faster CPU better graphics card and More ram is better.
CPU: Intel Core 2 Duo E8200 2.66 GHZ / AMD Phenom X3 8750 2.4 GHZ or better CPU Speed: Info RAM: 6 GB OS: Windows 7 64-Bit / Windows 8 64-Bit Video Card: NVIDIA GeForce GTS 450 / ATI Radeon HD 5870 or better Sound Card: Yes Free Disk Space: 40 GB
Feb 24, 2015 | Activision Call of Duty: Ghosts Full...
What's your problem?bit ix38 quad gt motherboard with 2 gig of ddr2 ram i want to add a 1 gig stick of more ram that ive bought how do i do this? thanks windows seven
Top view of motherboard, scroll down. (Thought you might also like to read the reviews, and Comments)
http://www.bit-tech.net/hardware/motherboards/2007/12/06/abit_ix38_quadgt/2
Motherboard User Manual,
http://www.theraptorpit.com/forum/index.php?/forum/124-abit-motherboard-tech-support-unofficial/
1) On the motherboard the Blue ram memory slot that is closest to the copper heatsink, is ram memory Slot 1.
Also known as DIMM 1.
Ram memory ALWAYS has to be in this ram memory slot.
The Processor reads ram memory Slot 1 first.
2) The Blue ram memory slots are Slot 1 (DIMM 1), and Slot 3.
(DIMM 3)
The Black ram memory slots are Slot 2 (DIMM 2), and Slot 4.
(DIMM 4)
To run Dual Channel ram memory, means there are two LIKE ram memory modules ('Stick'), and they are installed in the SAME channel.
This would mean to alike ram memory modules, in both Blue ram memory slots, or both Black ram memory slots.
Since the ram memory modules need to be alike, they are generally purchased from the same manufacturer, and are the same kind.
Running ram memory in a dual channel configuration, is supposed to increase ram memory 'speed', up to 30 percent.
This is Baloney!
May look good on paper, but in actual use in the field it's cr@p.
Actual performance increase is more like 1 to 2 percent.
This has been proven by Tom's Hardware, and many, many motherboards, ram memory, Processors, etc.
So you have 2GB of DDR2 Sdram, huh?
Is it just one 'stick' of ram memory, or are you referring to two 1GB sticks?
If the above holds true install them in Slot 1 and Slot 3.
If not, and it is a 2GB stick of ram memory, be sure it is installed in Slot 1 (DIMM 1)
Install the 1GB stick in Slot 2.
It isn't the same as the 2GB stick.
It is 1GB.
Does NOT go in a dual channel configuration.
(Catching all this? There is NO dual channel ram memory!
It is ram memory that is -> ALIKE, and used in a -> dual channel configuration.
Used in two separate ram memory slots, that support the dual channel configuration.
Sold with the advertising scheme of 'Dual Channel', but really just means the two ram memory modules, (Or four), are -> alike.
1) Same Voltage used
2) Same Ram Timings
3) Same Chip Configuration
4) Same size in amount
5) Same frequency rate ('Speed')
With ram memory in a dual channel configuration, the ram memory modules team up on the task.)
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 31, 2012 | Computers & Internet
Motherboard specs
Hi dwman113,
Yes your Mach Speed MB will support 2x1 GB, Dual Channel Mode DDR2-800MHz, PC6400 memory modules. (Manual states the memory dimms should be paired).
Also known as matched memory.
Max Shared Video Memory is 256MB, refers only to the integrated built in video card.
Click this link to help you understand what CL stands for; http://www.hardwaresecrets.com/article/26/3
Small example. CL3 runs faster than CL5.
You can run any PCI-Express 16x graphics card & it can be rev 2.0. Graphics cards are backwards compatible which means it will also run at v1.0. You should not buy a SLI card because you only have 1 PCI-E x16 slot. To run SLI, (Hooking up 2 PCI-E x16 cards together viva a small SLI connector) your motherboard would need two PCI-E x16 slots & the board must support SLI mode & your's does not. Here is the main web site link for your Mach Speed MSA2-6100V MB.
http://www.machspeed.com/specs/viper/MSA2-6100V.html
If you have any more issues or questions just post it & we'll go from there.
Good luck dwman113!
Mike
Aug 06, 2008 | Mach Speed Computers & Internet
Hi i have a ram issue
specs for motherboard mach speed venom
Memory type ddr2 sdram
Memory slots 2 X 240 pin slots
Supported ram 800mhz 533mhz 400mhz 667mhz
I dont know if this will assist you in sorting problem out
Aug 02, 2008 | Mach Speed VENOM MSA2-6100V Motherboard
Asus A7N8X-X (third memory slot)
Sounds like either a bad stick of memory or a bad dimm slot . Have you tried the memory on another motherboard ?
Jul 18, 2008 | ASUS A7V8X Motherboard
COMPUTER
I start out on the Asus site. I ask the customer what they need the computer to do. Then I look up the chipsets on the motherboards to see what they are capable of. If you want good graphics for photo programs, or gaming, you would want a good graphics card. That card also has a chip on it. Every motherboard and graphic card maker uses some of the same chips. Just because you like Envidea , Geforce or ATI, you do not have to buy that brand brand. Asus makes great motherboards and Video cards. The have proven themselves and won many awards. Asus also makes their own Laptops. You can go (here) to read about companies that make laptops.
The main thing is to make sure that the chipset is a good strong chipset. The chipset on the motherboard or video card are more important than the processor or memory. You can get the fastest processor and memory and put in with a crappy chipset and you will have a crappy computer. The chipset tells everything how to work. Asus usually uses the best chipsets, but they do have some low end boards. Most of their low end boards have video onboard. You want to match the processor with the chip[set speed if at all possible. If the processor that matches the speed seems too high, you can go with a slower bus speed processor. This will enable the customer to be able to upgrade later. They have motherboards that they considered ROG certified boards and those some of their best boards right now. Check (these) motherboards out. I have used one of these boards recently in a build. (This) is the one that I used and it was well designed and had very good quality parts. I only use Maxtor or Seagate Hard Drives because they are very good and have a 5 year warranty. I only use Pentium Processors because it has a TRUE clock speed and overclocks very well. Amd's are not for me because in the past they had trouble with a heat issue and that turned me away. They are supposed to be better now but I just do noy want to try them again. The same goes with IBM / Hitachi hard drives. I have used them in the past and gave them a try when Hitachi bought them out. In the past they were **** and took 3 months to get back from service. The new drive that I used died one day and I could not even retrieve my information off of it.
In a laptop I prefer ASUS because of the construction and how dependable they are. I have a L5000 series laptop that is over 3 years old that uses a 2.8 gig socket 478 processor and 1 gig of memory and 128 MB ATI video chip. I have not been able to find another laptop that my customers have brought me recently out do it.
Never use less that 2 gig of memory with VISTA and never use less than 512 mb of memory with XP. Try to stay away from onboard video unless you check out the video chipset. Some new motherboards are supposed to be coming out with high end video onboard. If you ever have the chance, go to a real computer show with Motherboard, Video, and Processor Manufacturers. Microsoft is usually at these conferences. This is a good place to learn and see the upcoming new things. You can also check out the web sites of these people and join there dealer programs. Intel has a thing on it's site to where you can find out when they will be dropping prices and coming out with new processors.
Now if you need information on a good system to build let me know. I will be glad to help you.
Jun 16, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Amd sempron 2800+
i want AMD Sempron(tm) processor 2800+ free downloads driver
May 27, 2008 | AMD Sempron 2800, 2.0 GHz 2800+...
No boot on start up all fans start but no video
I had same problem!
I figured there was something wrong with my memory because that is what the manual says the constant beeps mean.
I bought a new PNY memory stick 1 gb DDR and got the same beeps when i put it in.
So being totally disappointed I tried putting the Stick in the #3 DIMM. I booted up and IT WORKED!
I have not called tech support or tried both 1 & 3 DIMM together but I will try after I set up the rest of my computer.
Sep 03, 2007 | Mach Speed (MSNV-939) Motherboard
Not posting
Maybe a silly question to ask; but did you connect the processor power lead, as unlike some processors this needs a seperate supply.
Dec 18, 2006 | Mach Speed MK8-939A (VIPERMK8939A)...
Mach Speed VENOM V2DP Motherboard Logo
91 people viewed this question
Top Mach Speed Computers & Internet Experts
David
David
Abhinandan  Patil
Abhinandan Patil
Iqbal Husain
Iqbal Husain
Are you a Mach Speed Computer and Internet Expert? Answer questions, earn points and help others
