Question about Danby PHD DHCC6020 3-in-1 Home Comfort Unit Humidifier
Danby PHD DHCC6020 3 IN 1 - HEATER DOES NOT WORK
Danby PHD DHCC6020 3 IN 1 - Home comfort unit humidifier
The fan & dehumidifier still works...but it wont give off any heat
  • edkhunter Dec 26, 2008
    the resovoir won't fill up so I can use the humidifier part,,,,,,,any answers?
3 Suggested Answers
SOURCE: Replacement HEPA filter for Danby DHCC6020?
We just ordered from Danby... call 1-800-26-danby... it's part number 6020.02
Posted on Jan 15, 2009
  • 4736 Answers
SOURCE: need a manual for Danby PHD DHCC6020...how do I
Are you sure you have a Danby Humidifier and not a Dehumidifier? As Danby doesn't make humidifiers. At least, not in the US and Canada.
Please advise. Thanks
Posted on Apr 29, 2011
I need the air purifier filter for a danby dhcc6020
You may be able to use filters from the stove overhead filters.Stove suppliers sell filters which can be cut to size.
The filters are usually the same as those used for air conditioners.
Feb 02, 2013 | Danby PHD DHCC6020 3-in-1 Home Comfort...
Looking to download a danby humidifier manuel model DHCC6020-1
nursechris - The following is a downloadable and printable link to the owners manual, you're looking for.
Take good care of your Home Comfort Dehumidifier, as it has been discontinued by Danby.
http://www.beveragefactory.com/images/dhcc6020_efom.pdf
Hope this helped you & thanks for choosing FixYa.
Sep 11, 2011 | Danby PHD DHCC6020 3-in-1 Home Comfort...
Will not **** up water seems to be air coming out from the side with a tiny bit of sprinkles
From what you have described, according to the Owner's Manual for your "Retired" (that's Danby speak for "Discontinued") model, the air intake filter needs to be cleaned. As not enough air is being taken in, so the fan can operate properly.
In case you have misplaced your Owner's Manual, I have included a link to it that you may download and print for future reference. http://www.danby.com/cms/uploads/products/en_manual/DHCC6020%20EFOM.pdf
I hope this has helped you and thanks for choosing FixYa.
Aug 18, 2011 | Danby PHD DHCC6020 3-in-1 Home Comfort...
I have one of these and I have no clue how it works, sometimes the water reserve catches water.. does that mean its dehumidifying? What are some of the settings I should put it on?
Yes, that means it's working, Basically, the lower the humidity setting, the more moisture it removes from the household air. The higher the setting, the less it will remove and run less, too. Once the water reservoir or "bucket" as most folks call it, is full the unit will shut off automatically and the bucket FULL light will come on. You will need to remove the bucket from the front of the unit and empty it (I prefer emptying it in the bath tub or shower). Then carefully replace it the unit, so that it triggers the safety switch and the FULL light goes out and the unit will restart automatically, if necessary.
You didn't list the model number of your Danby Dehumidifier. But all Danby units work pretty much the same. To help you further I have included a link to the Owners Manual for the Danby DDR25E (this also covers 2 other models) that you can download and print for future reference. Read it thoroughly and become familiar with it's operation and the required Routine Maintenance.
http://www.danby.ca/cms/uploads/products/en_manual
/DDR25E%2C_DDR30E%2C_DDR45E_EFOM.pdf
Hope this helped you. Please let me know. Thanks.
May 25, 2011 | Danby (DDR600R) Humidifier
Need a manual for Danby PHD DHCC6020...how do I get the dehumidifier to work??
Apr 28, 2011 | Danby PHD DHCC6020 3-in-1 Home Comfort...
I got E4 error message, and my tank is empty. The humidity value blink too... What can be the problem?
There is some type of electrical component that needs to be replaced called a relay switch. I had the exact problem and it was only a little over a year old. I am not impressed with the appliance for the price i paid for it. I went and bought the cheapest dehumidifier I could find and it works great. You can bypass this problem on your home comfort system by attaching the hose that came with it to the back and the machine will work the water will drain out of it. I
Apr 07, 2010 | Danby PHD DHCC6020 3-in-1 Home Comfort...
Does not dehumidify
Hello. I am here to help. Let me begin by saying that a dehumidifier only needs to be operated if the humidity in your home is too high. If the humidity is low, the humidifier will have to work really hard to try and remove water from it.
Here is an overview of how the dehumidifier is supposed to work:
When the unit runs, the circulating fan and compressor also run. The fan continually draws room air over the evaporator coils, which are cold, and then over the condenser coils, which are warm. Because the evaporator coils are cold, the moisture in the room collects on them--just as the outside of a glass of icy liquid "sweats" on a warm, humid day. When the moisture on the coils increases, it drips off of the coils into the collection container.
The air then flows over the warm condenser coils and out into the room. This process removes water from the air and, because of the heat from the fan motor and compressor motor, the exiting air is somewhat warmer, as well as dryer.
May 20, 2009 | Whirlpool AD40U Humidifier
Heating does not work in Danby 3-IN-1 Home Comfort Unit
Called Danby, and the Unit is under warranty. They gave me the name of someone local who will fix the unit under warranty. The only problem is contacting the person. Voice mail is full.
Thank you
Feb 02, 2009 | Danby PHD DHCC6020 3-in-1 Home Comfort...
Nov 23, 2008 | Danby PHD DHCC6020 3-in-1 Home Comfort...
Changed filter and need to know how to reset icon
Press the 'Timer' and 'increase button' simultaneously (3 seconds) to resume normal operation.
Danby PHD DHCC6020 3-in-1 Home Comfort Unit Humidifier Logo
49 people viewed this question
Top Danby Humidifiers Experts
Paul Carew
Dennis
Marvin
Marvin
Are you a Danby Humidifier Expert? Answer questions, earn points and help others
