Question about Dell Inspiron 2200 Notebook
How to fix flip up Lid?
THe right/lower corner (near hinge) has broken open and now makes opening and closing very difficult The screw has disappeared and there is a gap between frame. What can I do to repair it?
  • kmunro Dec 14, 2008
    THe screw did not solve the problem. Taking into shop and replacing the flip up lid...not a cheap solution.
  • 50 Answers
The hing may be held in by that screw and i would say to find a matching screw and replace it or remove one of the two top center screws to replace it.
Posted on Dec 07, 2008
Hinges are loose on Toshiba NB505N508BL
Turn off the laptop, and remove the cord from the outlet.
Lift the laptop lid so the screen is in an open position.
Locate the small screws in the lower left and right corners of the screen.
If the screws are concealed by plastic plugs, carefully pry them out with a flathead screwdriver.
Use a Phillips screwdriver to turn each screw in a clockwise direction to tighten it.
Move the screen up and down to test it.
If it is still not tight, twist the screws counterclockwise to remove them.
Store the screws in a safe location.
Slip the tip of a knife into the seam where the front and rear of the screen meet.
Lift up on the knife to pry open the cover, and continue until the back cover is removed.
Rotate the laptop so the rear of the screen is facing you.
Locate the screws at the lower left and right corners of the screen.
Twist the screws in a clockwise direction to tighten.
Gently push the back of the screen into place with your fingers until it snaps back on.
Turn the notebook around so the monitor is facing you.
Reattach the screws to the bottom left and right corners of the screen.
Push the plastic plugs back over the screws if your computer had them.
hope this helps
Oct 11, 2012 | Toshiba NB505N508BL 10.1" Intel Atom...
ASUS U46E broken hinge
Replacing a hinge, or both of them, isn't very tough. Check out this WEB site. Replacing Display hinges for your laptop maybe available from thia WEB site.
Aug 27, 2012 | ASUS Computers & Internet
The scanner lid won't close properly. I see the right back corner of the lid has popped out of it's socket. how can I fix this?
I have a Lexmark X6570 All In One Wi-Fi model. Just had the problem where I went to print and received an error message saying that the cover was open (when it wasn't). I noticed that the back right hand corner had slightly popped out of place for no apparent reason. Tried to pus it back into place with no luck.
Here's what happened and how to fix it:
There are two plastic hinges at the back of the 6500 series printers that allow the top cover to open for access to the ink cartridge carriage. The lower ends of the hinges are cylindrical shaped and each contains a very stiff steel spring inside. They are designed to prop the cover of the printer up and hold it open when opened. As the plastic material ages, it may weaken and the tension of the internal spring may break the round end of the hinge off. This causes the printer cover to not fully close (even though it may appear so). There is a switch in the main printer body that detects when the top cover it open (even partially), and the printer won't work in this condition.
To fix this, open the top cover and carefully disconnect the 3 wire harnesses and the ribbon cable that run from the top cover to the base of the printer. Then remove the 'paper jam' hatch cover from the back of the printer. There are two phillips screws on the back panel of the pinter (one is located behind the paper jam hatch cover). Remove these screws (they secure the plastic hinges in place). You should now be able to lift the complete top cover/ scanner table assembly off the rest of the printer. Look for a steel spring about 3 inches long...remove this along with the round base of the hinge which may have broken off and remained down inside the printer. Glue this piece back onto the end of the hinge, but leave the spring out. Now reassemble the printer in the reverse order of disassembly and you should be good to go. Note that the top cover or the printer will not stay propped open on it's own with the spring removed, but this is not really an issue.
I am not sure if new replacement hinges are readily available from Lexmark or other sources.
Aug 26, 2011 | Lexmark X3470 All-In-One InkJet Printer
Kenmore elite top loader electric washer
you have poor contact with the left lid hinge and the lid switch.1st open the lid and check the 2 phillips head screws on the left side of the hinge.if they are loose tighten them and try mach.if the screws are tight,the lid switch might need to be replaced or adjusted.there will be 1 screw in each corner of the back of the console facing down.remove and flip console up,if there are no screws,take a putty knife and slide under front left and right corner of console and flip console up.the lid switch will be on left.if it is not broken out of socket,adjust hinge bar underneath switch by removing switch and bending silver bar up SLIGHTLY
Sep 27, 2008 | Kenmore 24032\24036 Top Load Washer
ck lid switch earlier modes had switch on right of lid opening later it was moved to left rear hinge area ..those on right just replace those on left first ck hinge screws on left be sure they are secure listen for click when closing click raise lid push on hinge arm on left side toward rear of washer slightly try again still nothing remove console screws on rear of console lift and roll console back ck switch on left side may be broken if so replace
Sep 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
For weeks now I've had to slam the lid on my washer to get it to work. Now nothing! The same thing happened to my dryer...close the lid and nothing. It wasn't even a year old and someone had to come out...
ck lid screws especially on newer models on these the lid switch is located left rear corner just behind lid hinge if switch is on right side close lid slowly and listen for click if none heard try pressing down on lid at switch location if washer starts replace switch if switch lever broke change switch..on other type switch lower lid slowly and listen for click if none heard and hinge screws ok raise lid and push lid hinge toward back slightly and try again still no click raise console switch is on left and just snaps in place
Sep 04, 2008 | Whirlpool Washing Machines
You could have a bad lid switch or the hinge may need to be bent to make better contact with the switch. If your washer has a oval cut out on the right side and an actuator on the rt side of the lid... the next time it acts up don't open the lid and turn the tub, simply push down on the rt side of the lid, if it starts to work replace the lid switch. If there is no hole or actuator on the rt side, then the lid switch is on the back left corner, when you open and close the lid you should hear a click. If you don't hear a click or if you hear it when the lid is almost closed you need to adjust the hinge. There are 2 screws on the back of the endcaps on the control panel remove them and flip up the control panel, use a screwdirver to pop out the spring clamps on the rt and lt sides of the top panel. approx 3-4 inches from the sides. just insert the tip into the front most part of the clamp and pry back. unclip the lid switch, and pull the cabinet forward. You should be able to bend the hinge a little so it makes better contact with the lid switch. hope this helps.
Aug 21, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool wtw5850sw0
look over the top of the control panel look straight down you see 2 phillips head screws on either side youll need to remove, the console will flip back giving you access to the switch..just for curiosity its not "clicking" when you close the lid therefore it fills and stops, doesnt spin or drain???? try this the lid all the way, the left side hinge acts as the plunger for the switch.. feel under there open and close lid a little to help find the metal hinge. after finding the hinge place a 1/4 nutdriver(doesnt matter the size just needs a hollow shaft.) over the protruding portion of the hinge. still under the top but right there! when its on push the driver back(in essence bending hte armature back slightly). itll flex a bit as you push the hinge the door will push back(you got the right spot then). after you crank it back a bit try closing the lid now. did you hear it click??? your golden!!!!!!! no need to change.. reason for telling you this is for the most part the switch doesnt go bad but the lid /hinge isnt bent enough to make contact, and over time of swinging top into the fully opened position it actually bends to far forward to make contact. i have a box full of switched that other techs ordered and weren't needed. not saying they dont go bad ive seen that, but try this first might get lucky!!!!
Mar 16, 2008 | Whirlpool LSR9434PT Top Load Washer
Cracked i880 screen
It is possible but can be difficult. there are seven T6 screws two of the are hidden under cover plugsa the bottom right and left corners of the phone on the rear. there is also one near the top left hand corner near the antenna.Once open you will see that the phone has a ribbbon cable that connects the flip to the main board. Carefuly remove the cable and replace the flip..then make sure to seat the new flip correctly and replace the backhousing and screws..good luck
Jan 01, 2008 | Motorola Mobility i880 Cellular Phone
Electrolux Oven EOG9330
Hope this helps (technique used on EOG9330XN):
1) With the door open, on each hinge, there is a top cover which lies flush with the hinge. Simply swing this cover up and back towards you. This unlocks the hinge. Undo both and carefully close the door, holding it at the bottom. The door should be able to be pulled away from the frame now. Lay the door on a flat surface.
2) The oven will normally be attached to the surrounding built-in cupbpard. If so, unscrew all attachment screws (mine had at least three per side) and pull the whole oven out about seven inches, supporting if neccessary. Each side panel has a locating screw in bottom front corner, so remove the screw. Peel back the side panel (only thin alloy, but watch for sharp edges) sufficiently to see.....
3) The two side securing screws for the door hinge receiver should be visible. After pulling receiver forward, if loose, tighten securing screws (use lock washers if available, as Electrolux don't provide them).
4) Reverse the procedure to finish job, fitting the door in the near vertical position to engage hinges in the receivers. Support the door, lower to open position and flip the locking hinge covers back.
[This technique works if the hinges aren't worn and if the door doesn't close properly, it usually means that the receivers are loose and have been pushed back into the oven frame].
Apr 11, 2006 | Electrolux EOG9330 Gas Double Oven
Dell Inspiron 2200 Notebook Logo
85 people viewed this question
Alun Cox
