Question about iRiver H10 MP3 Player
Music file problem
My iriver h10 was working fine after downloading new music onto it for a couple weeks. recently if i try to play the music it says that " this music has expired or failed to have license." this has happened more than once and i cannot figure out why it is saying that. does it have to do with using the music provider, napster, to download music onto it or what?
Yes, It has to do with using napster. When you purchase songs form napster or most other online digital music vendors, the files that you download have digital rights management or DRM for short. In other words the recording companies have limited your rights to use of the files in some way becasue they are worried that you may go and give them to all your friends and they will have lower profits due to the resulting lost sales. There is a license associated with your digital music file. While there are different license schemes, one sure thing is that you can not play the music on a player that does not support DRM. Luckily the H10 is a Media Transfer Protocol (MTP) player, which means that it does support DRM. You must, however, use the right software to transfer the files; Software that will transfer license information to the player. I think Napster can do this itself but I have never used the service, so I can not be sure. The iriver plus software or Windows Media Player 10 and above should also work if Napster is not performing this task properly. I may also be that you must refresh the licenses for the DRM music files on a regular basis or they will expire. Hopefully using any of the above mentioned transfer programs will accomplish this task. Can you still play the songs on your computer? If not then there may be a more serious issue with your licenses. If you see all of these DRM restrictions as the rediculious hassle that they are, the you should know that there are ways to strip this information from your music files, but it's probably against the rules to go into that here. You should be able to find them if you are interested and willing to look hard enough. I hope you get them working properly.
Posted on Jan 23, 2007
Iriver won't let me upload from CDs and transfer....
Best way to use the H10 20gb is by creating a directory on your hard drive with your desired mp3 format files. Use ripping and encoding software with your existing audio cds.
Connect the h10 to the PC via the UMS trick (see this website).
Using a file directory on your pc, drag and drop the mp3 files from your pc to the MUSIC file folder on the h10. Install and run the EASY10 playlist creator software on your pc to organize the new files on your iRiver player. Disconnect the USB connection and enjoy!
Mar 22, 2009 | iRiver H10 MP3 Player
H10 wants to lock up
sounds like a hard drive problem...
need to see if you can still access your hard drive through the UMS trick
For 20 GB MTP Models
  • Make sure your H10 is turned off and disconnected from the computer.
  • Poke the "reset" button with a paperclip.
  • Turn on the hold switch (so that you don't accidentally turn the H10 on all the way).
  • Plug the H10 into your computer.
  • Turn on the H10 while holding the "O" button.
  • You will see the message "Emergency Connection" if you have done everything correctly. You can now let go of the "O" button.
If yes, try formatting the H10 hard drive, reload the latest iriver h10 firmware, and transfer your music files directly to the h10 music folder with Windows file manager.
Download and run Easyh10 free playlist maker, to build and save a playlist to your player.
also see this website:
users
Good luck.
Mar 20, 2009 | iRiver H10 MP3 Player
My iriver wont sync with WMP
try bringing your music up as a file normally it works cause with a lot of devices that's the only way you can send them so bring your music up as files then open your i river as files then all you have to to do is copy and paste
Oct 11, 2008 | iRiver H10 MP3 Player
Coping files from iriver H10 20 GB to pc
The USM trick allows you totreat your H10 as an external hard drive. Then it is easy to copy the musicback to your PC using explorer.
The details for the USMtrick are taken from mistic river.
http://www.misticriver.net/wiki/index.php/H10_Tips_and_Tricks/UMS_Trick
H10 Tips and Tricks/UMSTrick
From iriver Wiki, yoursource for everything iriver - a part of MisticRiver.
Jump to:navigation, search
Most people agree that theUMS trick is a great thing to know how to do. With it, you can transfer music,OR treat your H10 as a harddrive to put anything you want on. The UMS trickwill also allow you to use your H10 with virtually any OS.
5/6 GB MTP Models
1. Make sure your H10 is turned off anddisconnected from the computer.
2. Take out the battery, wait a second, andput the battery back in.
3. Turn on the hold switch (so that youdon't accidentally turn the H10 on all the way).
4. Plug the H10 into your computer.
5. Turn on the H10 while holding the"O" button.
6. You will see the message "UMSMode" if you have done everything correctly. You can now let go of the"O" button.
20 GB MTP Models
2. Poke the "reset" button with apaperclip.
5.Turn on the H10 while holding the "O" button.
6. You will see the message "EmergencyConnection" if you have done everything correctly. You can now let go ofthe "O" button.
UMS Models
UMS models do not need thistrick because they are always in UMS mode!
Sep 01, 2008 | iRiver H10 MP3 Player
Lost h10 iriver installation disk
You can download the software from this site;
http://www.iriver.com.au/iriver/index.cfm?pageID=10001
Probably also from worldwide site. www.iriver.com
As a work-around you can copy files with Explorer to the Music folder and use the Browser on H10 to play them.
Feb 14, 2008 | iRiver H10 MP3 Player
Music won't show under "Music" in main menu
Dear iriver users,
When I frist drag and dropped pictures onto iriver, nothing showed up. With more playing around, I discovered, frustratingly!..that I can download pictures onto WMP and sync it with my iriver that way. That is the only solution I have found, even though it seems possible with the drag n'drop!
good luck!
Dec 05, 2007 | iRiver H10 MP3 Player
Windows media player vs. h10 20gb
Fimrware upgrade might actually result in this problem - check the iRiver help forums - i believe I saw a horde of people with this issue
Oct 27, 2007 | iRiver H10 MP3 Player
Iriver h10 20mb
download the firmware off of the iriver website. all of the files will be erased but when you recopy them onto the iriver, they will play.
Aug 06, 2007 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
87 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Peter Dragonetti
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
