Question about Lexmark E232 Laser Printer
Ran the wrong clear overhead material through printer
Teacher friend of mine handed me this printer and told me, there are 2 types of clear overhead sheets, one you write on and the other you print on, she mixed them up and ran the one you write on, she said it will melt in the heat of the laser printer. Is it fixable??? if it can how do you get through the case defences?? signed: Mr usually I can fix anything
  • woodplane57 Dec 02, 2008
    It gave me the confidence to tear it apart and remove all the melted film from around the roll. It may run again!!!! It was just stuck, the melted plastic film cooled and jammed between the rollers. Thanks
  • 628 Answers
You'll have to replace the fuser roller as you probably welded the plastic to it. Try this procedure:
Fuser Assembly Removal
1. Tilt the printer carefully to the rear so it is resting on the ASF.
2. Remove the four bottom cover screws.
3. Disconnect J7 (THM) from engine card.
4. Reattach bottom cover and set printer upright.
5. Remove charge roll assembly. See “Charge Roll Assembly
Removal” on page 4-6 for more information.
6. Remove the two fuser mounting screws.
7. Disconnect the fuser wires.
8. Release the tabs on each end of fuser assembly and lift out.
Posted on Dec 01, 2008
Is it ok to kiss and hug your preschool students?
Actually hugging and kissing children aged 1 to 5 seems normal, but what makes it malicious is how people perceived it. Moreso, if you, as teacher did it to your students. There is nothing wrong with it but the big question is how the parents will accept it. Maybe just hug your students but try avoiding kissing them specially in lips. This is for health consideration too.
Jan 04, 2017 | Preschool
Cursor jumps backwards without warning when typing
actually that comes from incidental contact with palm of your hand on touchpad happens to me all the time have to keep your wrists above the keyboard(just like old piano teacher told me)
May 28, 2012 | HP Computers & Internet
Paper jam
Hi Ruth,
This should help you fix the issue.
Remove Jammed Paper
If business card sized paper loaded sideways is jammed:
1. Power the printer off.
2. Open the top cover.
3. Remove the jammed paper with your hands.
Note: Be careful not dirty your hands. Do not use tweezers or other metal instruments to remove the jammed paper or printer damage may occur.
4. Close the top cover and power on the printer
5. Load the papr correctly in portrait orientation to resume printing.
remove foreign objects
When printing, if there is any foreign material (such as a piece of metal or a pencil) in the printer, the printer my be damaged. If there is any foreign material, remove it at once.
The images below show the iP2200 model.
2. Open the paper support and confirm that there is not any foreign material in the auto sheet feeder. If there is any foreign material, remove it by hand or with tweezers.
3. Open the front cover and confirm that there is not any foreign material in the printer. If there is any foreign material, remove it by hand or with tweezers.
Note: Avoid touching inner parts.
4. Power the printer on and confirm that the printer operate normally.
Use a flashlight to find any possible jam.
Regards,Suhail
May 19, 2012 | Canon iP2600 series
How do i take the back off a canon pixma mp240 to reach inside it to pull out sticky tack that has gotten stuck in the paper feeder?
Welcome to FixYa!
2. Open the paper support and confirm that there is not any foreign material in the auto sheet feeder. (If there is any foreign material, remove it by hand or with tweezers.)
3. Open the scanning unit (printer cover) and confirm that there is not any foreign material in the printer. (If there is any foreign material, remove it by hand or with tweezers.)
Note : After confirming that the scanning unit support is fixed into position, release your hands.
Caution: To prevent injury or damaging the unit, avoid touching the inner parts.
4. Close the scanning unit (printer cover).
5. Power the printer on and confirm that the printer operates normally.
Note: If you cannot remove the foreign material in the above procedure, the printer may require servicing.
Rates and comments are appreciated.
Thank you for using FixYa.
Jas
Mar 02, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Paper jams and won't feed straight
Sometimes when the printers jam up, is because they have a small piece of paper or something stuck in it's path. Try
Those are the only two places that something would be stuck
Good Luck
Nov 29, 2009 | Canon PIXMA iP1600 Printer
Loud grinding noise; new brakes and new tires
some of the brake material used will make that sound on toyota's and lexus.you need to try a differant type of brake pad.should help.
Jun 12, 2009 | 2004 Toyota Sienna
Paper light keeps blinking red
Pull out the drum. There is a blue button on it - if you pull it out and look straight down at it, it should be on the right hand side towards the printer. Slide the blue button back and forth, left to right, 20 times or so. Make sure to position it back to the right side all the way when done and put it back in. It should fix it. It is some kind of wire that is dirty with paper dust, etc. Brother told me to do that very thing when mine was having the same problem. Now, if that doesn't work, I also use the dust remover canned air and spray inside where the drum fits.
Hope it helps.
Nov 11, 2008 | Brother HL-2040 Laser Printer
Electronic whightbord, audio tape and overhead
instructions on how to transcribe materials from an audio tape, and Instrunctions on how to transcribe notes from an electronic whightboard printout, and Instructions on how overhead transparencies can be produced using the computer and photocopier.
Oct 06, 2008 | Office Equipment & Supplies
Lexmark E232 Laser Printer Logo
50 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
