Question about GE GTH18KBR Top Freezer Refrigerator
Freezer cold but things not frozen -frosting up. Fridge warm.
Side by side fridge / freezer GE model # GSS22QGPA.
Thick layer of frost/ frozen ice in the back of the freezer - keeps food cold but not frozen. No cold air getting through to the fridge side. I've looked at the diagrams - would the part I need be a Sensor Temp or Thermostat defrost?
This has happenned 2x before. I called service for this (out of pocket expense) can't find the paperwork now and want to try fixing this myself. Can you please help?
    Genius:
  • 1,122 Answers
Most of the time on ge its the defrost heater or defrost sensor in the freezer,that's why its freezing up.you can go to sears .com click on prats put in your modeal number and get yours parts-mike
Posted on Nov 30, 2008
  • MIKE major Nov 30, 2008
    i give you a fix it answer,and i need a fixya rating!!! you meesed up my expert rating!!! thanks-mike
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
GE GTS22KHP refrigerator - fridge is warm, freezer seems cold and is making ice. When the fridge was getting warm, we checked the freezer and some of the food in the door of the freezer was starting to...
With 'no-frost' fridgerators, they enter a 'defrost' cycle that is supposed to elimnate any frost. There are a few suspect parts, but it should be 1 of 2 parts. The timer that controls when it enters the 'defrost' cycle is occuring too often, or more likely, there is a thermostat that overrides the timer once the temp on the cooling coils (not freezer) reaches, say 55 degrees and commands the freezer to resume cooling.... I bought a themostat off amazon for $26 and put it in and no longer have my ice tray frozen solid after prolonged defrosting. Google 'no-frost' fridge how it works...
Oct 24, 2011 | GE GTS22KHP Top Freezer Refrigerator
Side by side ge fridge model number gss22kgpabb. not cooling on either side freezer is cooler than fridge side but not cold enough to make ice. What do I do to troubleshoot. Also has a slight layer of...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 02, 2011 | Refrigerators
My freezer is cold but my fridge is room temp?
Most often when you have this condition with a frost free fridge, you have one of two problems.
It could be a defrost problem. Look in back of the freezer. Is there a layer of frost against the back wall? If yes, you are Iced up. That would be either a defrost timer, heater, or termination thermostat.
The other thing it could be is the evaporater fan motor. Do you hear it running? It could be that the sound you heard was the fan blade hitting something. It may be jammed or the motor burned out.
Your fridge needs the air moved by this fan to make it cold. Thats why when you have ice blocking the coil, it makes your fridge warm.
Good luck
Jul 28, 2010 | Whirlpool ED2FHSS Side by Side...
Side by side, freezer is cold, fridge is warm, freezer is iced-up
Hi: Your defrost heater ot timer is out. Hence the frost. That also clogs the airways to the fresh food compartment. If you are handy, unload the fridge (you will need a cooler or have a bbq for everybody,) I can't give you the specifics but you will need to remove the panel where the frost is, first let the frost melt off. at the bottom of the coils will be a heater tube. Usually glass with a metal coil in it. See if there is a break in the coil. If so replace it. If that is ok it is your timer. Most likely electronic and expensive. This can be anywhere. Look at a diagram of the fridge to see. Sears parts is a good site for it. Hope I helped, Jeff
Jun 01, 2009 | GE Refrigerators
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
Fridge and Freezer are Warm Ice is still being made
Hi - I just had the same problem on a 48 Monogram 1996 model.
The guys at the factory told my local service center that it was the main logic board ($200 for parts) and they replaced it, but that wasn't it.
It was the evaporator sensor. i don't claim to understand it all, but I think that the sensor is responsible for telling a heating element to turn on and defrost. If it does not do it's job, then frost builds up (You can feel the frost if you feel up in the freezer, up hight and in the front)) The frost keeps the cold air from getting to the fridge. Eventually the logic unit will freak out because ti is trying to keep the fridge cold, but the fridge send back that it is hot.
The repair guy may not want to replace the sensor because it is like an hour and half to get back in there. And it is a tight fit.
Apr 17, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Whirlpool gold:upper half of refridgerator side not cold
Either the evap fan has a problem, or the defrost system has failed. You should never see frost in the freezer section as the defrost sensor should sense that the coils need to be defrosted before that much frost accumulates.
Unplugging to clean out helped because the frost got a chance to melt away.
If you find the evap motor is running, then the things to check are the defrost sensor, the defrost timer, and the defrost heater.
Reply back if you would like more info.
Jan 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge SIde by side SSS25KFMDWW stopped freezing
number one,is the freezer fan working?2,is there frost forming on the back wall of freezer?let me know more-mike
GE GTH18KBR Top Freezer Refrigerator Logo
597 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
