Question about Dishwashers
Upper wash tube assembly came off back of unit. can not reattach.
Bosch model #6800 stainless steel dishwasher. The upper wash arm and tube assembly came off the back mounting. Cant get it to reattach.
Is there a diagram and instruction sheet online or can anyone give advice how to remount it.
  • Anonymous Mar 29, 2014
    how does one remove botton big round filter as the stainless steel tubes that hold arms and filter look like they are welded at back of the upright tube inside of the dishwasher.Can this tube be lifted up with some force and therefore release the filter for cleaning as well as the well in the bottom? would so appreciate some advice. thanks
We had the same problem with our Bosch 4800 and found that the upper wash arm and tube assembly should attach to the bottom of the upper rack (rather than to the back of the dishwasher). The wash arm and tube assembly slides in and out with the upper rack. When the dishwasher door is closed the tube assembly is forced up against the back mounting/water supply.
Posted on Feb 16, 2009
The upper wash arm fixes to the upper BASKET not the inlet tube on the rear wall of the dishwasher. Once you stop trying to push the washer arm onto the inlet tube you see the answer!
Posted on Dec 27, 2009
Noise on wash cycle
Support - Dishwashers DW80F600UTS/AA ' Samsung ...
www.samsung.com > Home > Support > Dishwashers
Samsung ElectronicsVisit Samsung today for DW80F600UTS Top Control Dishwasher with Stainless Steel Tub (Stainless Steel). You'll find product ... Yes; Sound Level (dBa) 48 dBa; NSF Certification Yes; Total Number of Cycles 4; Total Number of Wash Options 2 ...Multiple wash arms ensure even water distribution during a cycle. 3 (Upper ...
Oct 01, 2015 | Samsung Dishwashers
Not cleaning dishes
Good Morning Lynn, thank you for your post!
I understand your dishwasher is not cleaning properly. Will the spray arm rotate freely or is it damaged? If so, you might have to remove and replace the spray arm assemblies. The top spray arm typically starts to function when the unit is in rinse or wash cycle. If for some reason the top rack is not getting clean, there is a possibility that it is not working properly. The top spray arm is either blocked by pots/pans or not enough water pressure is being pump meaning that the flow of water is not making it to the upper spray arm. If you tap the delivery tube that feeds this nozzle and the water pressure jumps immediately, then the problem may lie with a faulty pump or impeller. Should all basic troubleshooting measures fail contact a certified technician to narrow down the precise issue before investing in parts that may or may not be the root cause.
Dec 15, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
Top shelf of dishwasher is not getting clean. Bottom OK
The most likely problem is the tube that connects the spray arm for the upper rack to the water supply is broken, you could see this tube by looking on the bottom of the rack.the back of it is funnel shaped and fits into the tube on the back wall when rack is pushed in.
this link shows a image of it the part is item# 6 http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Dishwasher-Parts/Model-KUDI02IRBS4/0593/0130000/W0702129/00010?blt=06&prst=&shdMod=
I hope this helps ya
Gene
Aug 02, 2011 | KitchenAid 24 in. KUDI02IRBS Stainless...
Where can I order an upper spray arm for my bosch dishwasher
Hi -
I order all Bosch parts direct from Bosch. You wont get them much cheaper anywhere else. If the model number above is correct, the part number is 359976. This is the whole upper spray arm assembly which clips onto the upper basket. The arm and retaining nut are not sold separately.
(0614 is the position number in the parts list, not the part number)
http://www.bosch-eshop.com/eshop/bosch/us/prodls.htm?Matnr=000000000000359976&ESHOPTYPE=A
$21.60 + shipping (in stock)
The link is for the Bosch USA eShop. If you are somewhere else, please let me know your location and I'll provide a different link. If you have a different from the one listed above, I can verify the part number for you, but this fits most Siemens/Bosch dishwashers, so it's likely to be the correct part..
Hope this helps.
Regards,
BElectric
Mar 24, 2011 | Bosch SHU5316UC Dishwasher
KUDP02CRBL0 Pump/motor housing removal
yea its a bit of a pip....
but it comes strasight up from the bottom
and then dropped in
watch your seals
Oct 11, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
No washing action through washing arms even after
Many times the washing arms of the bosch and few other models will clog up with old soap or debris.
Try removing arms and clean out any debris by blowing air through unit and if need be a toothpick or dental tool to remove any solid debris that is stuck. Reattach arms and run through cycle. Hopefully this works otherwise it could very well be the pump.
Sep 07, 2009 | Bosch 24 in. SHY56A05 Stainless Steel...
Upper rack is not cleaning. Greasy dishes on top seem that dishes are not being washed. Seems the upper water turning dispenser is not working, Bottom rack seems ok. I guess I only have half a dish washer...
Check the upper arm for free spinning, then remove the arm and check that the seam between the upper and lower halves has not split somewhere. Also check all the small holes for debris plugging. Run the machine in wash cycle for a little while with the upper arm off--that should flush out anything blocking the pipe up to the arm. If still nothing from the upper arm, tear down the lower arm assembly down to the deck while noting position of all parts removed. Clean the big screen at the bottom in white vinegar and hot water. Inspect the holes in the bottom for anything blocking them.
Aug 15, 2009 | KitchenAid 24 in. KUDS02FRSS Stainless...
Dishwasher has power and water but rinse arms are not working
Vicky,
I understand that your LDF8812 fills with water (and drains?) but is not cleaning and you are not hearing the unit wash. Are the dishes on either rack getting wet at all?
-Are you getting any error codes in the display?
On LG dishwashers, the upper and the lower arms never spin at the same time. Rather the vario check valve routes all water pressure either up or down.
The arms turn because the wash motor turns the pump (impeller) which drives the water to/through the wash arms. If the wash motor was faulty, you almost always get an error code. So the problem is probably caused by a blockage of the "plumbing" in the sump area beneath the lower wash arms. But first check all three wash arms to confirm that the holes are not blocked. (How cool is it that the light inside this model helps you do that?)
Next use a screw driver to remove the filter assembly in the sump area. There are 10 screws to remove, but first you need to firmly lift the lower spray arm directly up and out.
Inspect the entire sump area for debris. Watch out for broken glass! Look closely at the white area near the back for blockages at the check valve.
Please report back what you find and we will take the next step. OK?
May 18, 2009 | LG LDF8812 Stainless Steel Built-in...
Bosch dishwasher - top row of dishes do not get clean
There is a screen that you can remove from the sump of the dishwasher to clean. Just twist it to the left and pull it out. I have some tips that you might want to check out if this does not resolve your problem.
<a href="http://tclaundryrepair.com/">St Paul Appliance Repair</a>
Feb 25, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
BOSCH DISHWASHER SHU43C06UC/17 NO WATER UPPER ARM
Ours is a SHU3300UC/06 model, basic model which we bought in 1999 so have had 9 years of trouble free service.
Recently we noticed that there was soap left in the soap dispenser after the machine had finished all the cycles. On further inspection we noticed that the upper level glasses, cups and bowels are not consistently clean and it appears that the upper washing arm is not working properly. At the back of the upper washer arm, there is a rectangular piece that slides over the two water outlet tubes projecting out of the back of the washer which supply H20 to the upper arm. On removing the upper arm and the rectangular connector, I noticed there is an inner place that I think is supposed to work like a washer that fits tightly over the 2 water outlet tubes in the protruding from the back of the washer. I noted that the upper opening in the washer/seal is broken so a proper seal is not established. This would cause insufficient water pressure getting to the upper arm and reduce its effectiveness. Now I'm trying to find the replacement part. It appears to be something than can easily be replaced.
Dec 06, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
370 people viewed this question
Top Dishwashers Experts
