Question about NetGear RangeMax WPN824 Router
WPN824 Keeps rebooting itself at different Intevals
Hi The wpn824 will be working fine then all of a sudden it will reboot, can be when no one is actually doing anything on the net other times can be when there are a few users connected. I have updated to the latest firmware, is there anything i can do to stop this from happening Thanks in advance Craig
  • 1 more comment
  • Craig Steven Jan 23, 2007
    Yeah I have reset it, and its not in a place where it is getting overly hot. Since the original post it has not done it yet i am sure it will soon, any other ideas? is there any other firmware you can use of this router?
  • hamazasp Jan 27, 2009
    just the same problem, it reboots itself over and over
  • Anonymous Mar 15, 2009
    Mine does the same thing. I think it must be a faulty bored or something. just will not stop rebooting. I am going to have to send it back to netgear I think
    President:
  • 2,961 Answers
It could be a general hardware problem, but check it's not getting very hot as there may be a cut out. When you updated the firmware, did you do a factory reset as on some routers it may not of saved the update, check the firmware type in the properties of the router.
Posted on Jan 22, 2007
  • andrew pester
    andrew pester Jan 23, 2007
    No you've done all you can, it's got to be a hardware fault, as it's re-booting says there is a powerdown of the supply or it's simply restarting.
    It's not as if you are losing the ISP broadband connection first, it's just turning off.
When i turn on the power to my router, all of the lights turn on and freeze
Try to reboot your router...normally reboot are two types...
In Netgear router, when you change the router configuration, it does a "soft reboot", which is related to the operating system reboot.
And a "hard reboot" is usually done by removing power from the router and rebooting it after powering it off for several seconds.
->open your browser and login your router page using username and password..
->Click the Diagnostics option which is under the Maintenance on the left hand side of your Netgear setting page.
->Then click the Reboot button and it will automatically reboot your router.
***Reboot process can vary depending on different Netgear wireless router models.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Nov 22, 2012 | NetGear WGR614 Router
Only secure sites work on wpn824
Have you made any changes to the router? Blocked or port forwarded port 80.
May 30, 2012 | NetGear RangeMax WPN824 Router
We have been using the Netgear router WPN824 for about 3 years and all of a sudden it stopped working. No flashing strobe lights - nothing. any suggestions?
Will it even power on at all ? If there are no lights at all make sure its plugged in securely. Maybe even try a different power outlet to see if the one you are using has not gone bad. If that still doesn't help then there is a chance that your router has failed. Being 3 years old it is possible. A failure can be from a power surge, storm, manufacture defect etc. In which case you will have to replace it. Sorry for the bad news.
Thank you for choosing Fixya,
Daniel
Jun 26, 2011 | NetGear RangeMax WPN824 Router
How do I restore the router back to it's factory user name and password? Since I forgot the setup username and password.
Press and hold the Default reset button on the rear panel until the power light blinks... about 10 seconds
Release the button and wait for the router to reboot
Jan 04, 2011 | NetGear RangeMax WPN824 Router
How do i set up my router? model # WPN824
Check this url http://static.highspeedbackbone.net/pdf/netgear-WPN824-manual.pdf.
Oct 26, 2010 | NetGear RangeMax WPN824 Wireless Router...
WPN824 Transmitting Signal, no internet.
As a last resort, you can reset your router by holding down the reset button in the back. It doesn't sound like this will fix the problem however. Purchasing a new router shouldn't be necessary, as most if not all Netgear routers come with a 1 year warranty standard.
Aug 02, 2010 | NetGear RangeMax WPN824 Router
Cant locate netgear router on network.... was working fine then just stopped
Try rebooting the router and check the status of the Flash card .
Jan 01, 2010 | NetGear RangeMax WPN824 Router
I had my Laptop worked and it was reset back to out of box
You need to RESET your wireless router. Her is how: Press and hold the Default Reset button until the test light blinks on (about 10 seconds). Release the Default Reset button and wait for the router to reboot. The default administrator's password is password The default IP is 192.168.1.1 Hope this helps
Jun 11, 2009 | NetGear RangeMax WPN824 Wireless Router...
NetGear RangeMax WPN824 Wireless Router (WPN824NAR) Wireless connection drops in and out regularly but frequency of this is unpredictable duration is usually a few seconds. Works find on direct ethernet...
Upgrade the Firmware of the router :
First you should check the version of you WPN824 (v1,v2 or v3). If there are no Version after the model number, it should be a version 1. Download the Firmware of your router given the correct version at this link :
http://kbserver.netgear.com/products/WPN824.asp
This is assuming that other wireless laptops has the same problem onyour wireless router. If other Laptops works great on your wirelessrouter without dropping any wireless connection, then you shouldconsider upgrading the wireless adapter on you own laptop.
***(If you haven't tried connecting otherwireless laptop wirelessly to the netgear, then you should try it firstto be sure that the netgear is the problem)
Steps on how to upgrade Netgear firmware :
  1. Download the correct file depending on your location and unzip the file to a convenient place such as your desktop.
  2. Log in the router at http://192.168.1.1 or http://192.168.0.1 (or www.routerlogin.net ) (Which ever will work)
  3. Default User name : admin / password : password
  4. Click Maintenance > Router Upgrade.
  5. Click Browse and locate the file you just downloaded.
  6. Click Upload. While the firmware is loading, do not interrupt the upgrade process.
***Therouter reboots when the upgrade is complete.
***Tocheck that the upgrade was successful, log in to the router again at http://192.168.1.1and check the firmware version.
***DONOT UPGRADE FIRMWARE USING A WIRELESS LAPTOP/PC
Oct 26, 2008 | Computers & Internet
Is the smart setup (that is automatic setup) does not work, call your internet provider for the exact details (unless you have them) and do the manual setup.
You will save time.
Nov 14, 2007 | NetGear RangeMax WPN824 Router
NetGear RangeMax WPN824 Router Logo
452 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
