Question about Honeywell Programmable Thermostat Heater
Replacing aging erratic honeywell chronotherm III
I have an older (~20 yrs) honeywell chronotherm III programmable thermostat controlling an oil furnace and a seperate AC. It will skip over periods, get stuck in periods, not raise the temp, not stop running funace when temp is reached, etc. I've tdecided it's time to replace it, but I don't know what with. Is there a cross-walk somehwere that says "if you had x, you should now get y"? How do you know what's compatible? How hard a job is it for a person (my son, not me!)with computer hardware and automotive skills but no experience in heating to do? Should I call a pro, or is this a DIY project?
    New Friend:
Hi, your replacement part can be purchased on amazon, take a look here: Amazon com honeywell chronotherm III thermostat. I hope this was helpful. Cheers
Posted on Dec 06, 2014
  • 61 Answers
Honeywell has a great newer thermostat.
This is what I sell, it is easy to program and use and has a large touch screen. I hooked up 4 in a office and it saved them 15 % of heating bills this is the link for Honeywell thermostat for the page.
Posted on Nov 30, 2008
  • 334 Answers
You will be fine with another Honeywell T-stat.
You need one designated for single stage heat, single stage cooling.
You can also use one for universal applications as long as the single stage heat and cool are one of the options.
These can sometimes be a little more confusing to hook up for beginners, as you have many different options.
Honeywell's instruction booklets are as good if not better than most all the others.
When he removes the old one. Have him draw a diagram indicating what color wire goes to which terminal.
This will help hook up the new one.
White wire = W2
Red wire = R
Green wire = G
Yellow wire = Y1
Blue wire = C (common on most HVAC systems)
Some T-stats have batteries and do not need a common wire.
If you have a brown or black wire hooked up and you have no humidifier/dehumidifier, air cleaner etc then they are most likely unused unless they are going to the W1/W2, Y1/Y2, R, C, or G terminals.
Posted on Dec 06, 2008
Display shows LLL
PDF]Chronotherm III 7 Day Programmable Thermostat - Honeywell
O I" O 0. HEAT M10 COOL OF ow to operateyo. This Owner's Guide will show you how to get the most benefit from your new thermostat. Your new Honeywell ...
Sep 13, 2015 | Cars & Trucks
Honeywell Chronotherm III Thermostat shows time of day-AC. No heat in the 2 zones with this message.
Hello,Message AC means that there is no 24volt power to the thermostat from the unit/s it controls.Please check all switches & curcit breakers to the unit/s as there is no low voltage power to the thremostat from the transformer in the unit/s.Maybe got turned off by mistake.
Nov 01, 2010 | Honeywell Electronic Programmable...
My honeywell chronotherm III says -AC any ideas
The problem is your 24v power source. I am unsure as to why you put "other than power source or batteries". If you did indeed check that your thermostat is receiving 24v, then I would say that you have a bad thermostat. Hope this helps
Jan 22, 2010 | Heating & Cooling
Chronotherm III Thermostat Completely Blank Screen, No Heat
One of two things either the disply has gone out which is likely as it is a common failure for that thermostat or your heating unit is not sending control power. the older chronotherms were system (24volt ac) powered the new hardware/box store units are battery powered. Either way display should not be blank with fresh batteries. to get heat on remove the thermostat jumper or twist together the wire from the R terminal with the wire from the W terminal. note the color of each wire for later reference, heat up house disconnect wires from each other and go purchase a new thermostat
Dec 17, 2008 | Honeywell Programmable Thermostat Heater
-AC appears in the display of chronotherm III
I have had the same problem- twice. It was a similar but different problem each time. The -AC means the ac control voltage isnt making it to the thermostat. In my case both times it was a switch in the control circuit that wasn't closing properly. The easiest was the front cover switch. If the front cover is removed from the furnace or has vibrated loose, the switch will open, preventing the furnace from running. The other instance I ran into was a flow switch on the exhaust blower which ensures the there is flow OUT the chimney. The switch wasn't functioning, so the furnace wouldn't start. The blower would come on for a short time, but the burners wouldn't light.
Hope this helps,
Dec 12, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
6,232 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
