Question about Frigidaire GLTR1670A Front Load Washer
Frigidaire front load washer (model LTF530FS0) won't spin
IO just bought this washing machine. I get it home, set it up, w/ a dryer on top, and the washing machine will not spin. I close the door, turn it to the first cycle, the door lock light comes on, the water fills, then nothing; the knob doesn't move, the washer doesn't spin, nada. I called the guy I bought it from (got it from a guy who deals w/ "cosmetic" damaged goods) and he said that the first time it runs it needs awhile for the ocmputer inside to get programmed, or something like that. I'm not sure if he's just telling me that or what. I unplugged it, per his suggestion, for a few hours, and then tried to run it again (w/ clothes) and nothing still. Any suggestions? He said it worked for him right before I picked it up - and when I picked it up, he was wet. I could return it, I suppose -- just a huge hassel.
  • americanstar Jan 04, 2009
    MY washer will spin for actual wash cycle but will not discharge water or go into high speed spin cycle. the timer will finish but cloths are still wet and not spun dry
  • 641 Answers
You should return it and not deal with it !!!!!
Posted on Aug 24, 2007
Can an frigidaire X091307954 dryer be stacked on a Amana NFW7200TW 3.5 Cu. Ft. Front Load Washer?
this is possible, youll need a kit that sets on top of the washer,check back where you bought the washer and dryer, they make a washer and dryer combo thats one peice, they are smaller however
Jul 13, 2013 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
My Frigidaire model FTF2140ES will not spin or drain no matter what settings I put it on.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Frigidaire Washing Machines
Hello, I have just purchased a frigidaire gallery series stackable combo 2004 model glet1142cso after hooking it up i am having problems. It won't fill unless dryer door is open..won't spin out...
Probably an auto tec installed the recepticle on the wall or in the electric pannel. in home electric the black wire and the red wires are hot. In automobiles the black is ground. You should have 240 volts between the two flat connectors on the plug when its pluged into the recepticle.
Dec 20, 2017 | Frigidaire FEX831F Top Load Stacked Washer...
Washing machine won't drain
heatman101
May 14, 2011 | Frigidaire Washing Machines
My frigidaire front load washer Model #GLTF2940E will not spin out
heatman101
Apr 30, 2011 | Frigidaire GLTF2940ES Front Load Washer
My frigidaire washer model # fws545rfs0 wont drain or spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Feb 21, 2011 | Frigidaire Washing Machines
I have a frigidaire gleh1642fs stacked washer/dryer and the washer won't drain.
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 19, 2010 | Frigidaire GLEH1642F Front Load Stacked...
The water wont drain but it does spin and everything else seems to work
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
heatman101
Jun 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire washer won't agitate
hi Cinebar.
this is what i found from the internet so not sure if this will be off help to you.
There could be several reasons why your Frigidaire washer will not agitate, including problems with the power supply, the wash cycle or the way in which the appliance was loaded. It is a good idea to try to resolve the problem with your washer yourself first since unnecessary repair call-outs can potentially be expensive if your appliance is outside its warranty period. Troubleshooting your Frigidaire washing machine will take about 15 minutes.
Confirm the water shutoff valves are open. If your Frigidaire washer cannot draw water from the pipes, it will not fill or agitate. The shutoff valves are usually located behind the washing machine where the water pipes meet the wall. Allow the washing machine to cool down for 30 minutes. Frigidaire appliances automatically shut off if the motor starts to overheat. The cool-down period lasts for half an hour if the appliance has not been switched off manually.
Verify that the detergent draw is tightly closed. If the dispenser is left open, the washer will not start or agitate its load. Push the draw so it sits flush with the front of the washing machine.
Ensure that the washing machine door is closed. As with the detergent door, the appliance will not start if the door is left slightly open, to prevent water from spilling onto the floor. Push the door closed until it clicks, and try your load again.
Confirm that your Frigidaire dryer is set to a spin cycle. If your dryer is set to a soak cycle or is currently in the soak portion of a longer cycle, it will not spin or agitate the wash. Make sure the appliance is set to a spin load and try again.
Contact Frigidaire if problems continue. You may be entitled to free service if your washing machine is within its warranty period. See Resources for Frigidaire's contact information.
or read up more at this link.
Frigidaire washer won agitate Google Search
Dec 11, 2017 | Frigidaire GLWS1649A Top Load Washer
Frigidaire GLTR1670A Front Load Washer Logo
587 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Sal De
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
