Question about Brother DCP 115C All-In-One InkJet Printer
MFC-235C Print Message Problem
My printer was asking for catridges to be replaced which I have completed. Message on printer display states 'No cartridge. Open ink cartidge cover then reinstall ink catridge'
I have completed this several times and powered down the printer - but no joy and will not print.
Can anybody advise if there is some way of clearing the message and resuming printer functionality.
Please email on paul.halhead@polk.co.uk. Many thanks
  • isolabella Jan 14, 2009
    I have the same problem on a MFC-9440CN.  Even though I have replaced the toner cartridges as prompted - it still gives me a message saying to replace those cartridges and does not print.
    I would appreciate some help with this.
    d
  • marshallm2m Apr 30, 2009
    My brother 235c indicates that the ink cartidges are empty. After powering down and re-installing cartidges several times..
    Please help.
    Top Expert:
  • Brother Master
  • 26,643 Answers
Using copy cartridges this is a common issue. Always use genuine cartridges.
Posted on May 17, 2017
Mix-it-up
  • 832 Answers
SOURCE: Brother MFC-640CW Replaced Black catridge becomes empty
Compatible carts do make a lot of trouble. One point is the draining! The ink has flown into the cart assy and beyond that to the bottom of the printer. As long as you can print without problems you dont have to do anything. If the test pages wont show the correct color you have to open the printer and to clean the assy and the bottom.
Do use original ink carts though these wont drain and give correct info to printer. You can very simple refill them with dye ink. Dye ink only!!!
Posted on Oct 16, 2007
Mix-it-up
  • 832 Answers
SOURCE: new ink cartridge istallation: Brother MFC-240
I guess you d used generic ink carts?!
If yes, the cart holder needs replacement due to ink that has stained the led control. The ink has made a short circuit. The error can only be deleted by replacing the whole cart holder!
Posted on Jan 28, 2008
SOURCE: MFC-240 shows no ink cartridge
Same problem here... Figured out something that works fine for me anyway.
I took some black electrical tape and covered the clear plastic area in the front of the cartridge. It's a bit of a delicate procedure. Need a piece of tape about 3/16 of an inch wide and 1/2 inch long to match the contour of the clear plastic so it still fits inside the printer and can be surrounded by the light sensors.
Unfortunately, I think Brother is making too much on the ink cartridges and therefore is trying to make them tamper proof. I t's backfiring on them. Will never buy another Brother.
Posted on Mar 23, 2008
Mix-it-up
  • 832 Answers
SOURCE: Double prints or Text shadow printing by MFC 420CN
yes. you have to run the alignment feature. press ink - set - arrow-down til alignment. After alignment test print read the paper and choose the right setting by nr.
Posted on Apr 09, 2008
SOURCE: MFC-440CN printing problem
i cannot print anything
Posted on Jun 03, 2008
Hi there, Can I print in Black & White when I ran out one of colour ink catridges??? On Brother website it says that you can. According to their advice the Error message shoud come up on LCD screen...
as long as the color print cartridges remain in the printer you should be able to print in only black and white.
If the error message does not come up you should be able to tell the printer to print in black and white in your page setup or print properties portion when you go to print your page.
(1) go file print or print
(2) a gray box will pop up click on properties
(3) Click color
(4)click gray scale
This should do it for you!
(5) select black print cartridge only
Mar 26, 2010 | Brother MFC 6490CW InkJet Printer
Printer spits out blank page before printing
Check Your Ink Catridge. If the Catridge ink is full then try the following Steps.
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing the cannon drivers and software it will ask you to connect the printer.
  • then you can connect the printer and print a test page.
Hope this help. Please Rate My Response! Thanks!
Prem
Mar 02, 2009 | Brother Multi-Function Center MFC-240C...
Error message ''Unable to Print 4F''
How to repair error "print unable 4F" in the Brother dcp-135c .
thank alot.
Jan 06, 2009 | Brother MultiFunction Center MFC-440CN...
Brother MFC-235C print head removal
there are no instructions that you would understand and once the print head is clogged up, you can noy mannually clean it , it has to be replaced! sounds like you are using generic ink!
Nov 05, 2008 | Brother MFC 240C All-In-One InkJet Printer
Brother mfc-215c unable to clean?
The ink blotter in the bottom of the machine is full, this is a built-in redundancy. Machine needs to be completely stripped to replace this.
Buy another brand next time.
Oct 01, 2008 | Brother Multi-Function Center® MFC-215C...
Mfc-240c reading offline and empty black
Regarding your problem: If one of the color ink cartidges is out of ink, the MFC 240C printer will not operate when you only install a black ink cartidge. It requires that all four catridges have ink available in them for it to function. When you examine a cartridge it may appear that it has a little ink in it when you get message that the cartridges needs to be replaced because a little ink remains to prevent the print head from drying out. JLHinton1@bellsouth.net
Sep 24, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC 5840CNZ displays Ink Empty on CYAN when new cartridge is installed
Something that has worked for some Brother owners to get cartridges recognised.
1. With your MFC powered up, open it up and remove the cartridge you are having a problem with, then close the MFC, leaving it powered up. It should report that there is no cartridge in the machine.
Still with the MFC powered up, open it up and reinsert the ink cartridge, then close the MFC. It should either ask if you have replaced a cartridge or go into its cleaning mode.
Answer "yes" to "have you replaced cartridge?" and it should either "print" or "clean" and then "print".
Nov 08, 2007 | Brother MFC-5840CN All-In-One InkJet...
Brothers 420 cn printer question
try with clean the catridge nozzel and see if it is not working then you replace the catridge. bye
Sep 24, 2007 | Brother MFC-3240C All-In-One InkJet...
Brother DCP 115C All-In-One InkJet Printer Logo
55 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
