Yeah it´s a hard tv to Fix...but not impossible...
First You have to Check all the Board for Cold Solder and fix it...after this check the Power Supply, ´cause they are the champion of the Problems in Philips PT´s models..see if you can find any blow capacitors near the deflector Conector...Good Luck!
Did you check for any blown fuse on your tv and also did you check the inverter ?
If you have checked fuse and inverter then check soldering points of SOPS-transformer (T5663) and
line-transformer (T5620) and check IC 7220 (TDA 1521Q/N2; 4822 209 73311) and loudspeaker(s).
I dont have a circuit diagram. What is the inverter? How do i check?
