Question about Candy CPCA240FFK Bottom Freezer Refrigerator
Fridge running light(green)flickering
Hi,my candy fridge freezer's green light at the top of the door is flickering and the fridge contents are only cool and not cold,any idea's would be helpfull,cheers,vic.
  • joanne 1 Dec 02, 2008
    hi have the same problem! think its the circuit board behind the temperature control panel! but if it is I need to know where to buy one? anybody? thanks!
Hi,thanks for your e-mail i couldn't find a solution and the fridge was fairly old we bought a new one,cheers,vic.
Posted on Dec 02, 2008
Candy fridge freezer seems 2 be running ok.....but freezer only does -minus 10...fridge plus 14.....back of item is nice and clean.......?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
Apr 17, 2011 | Candy CPDA241 Top Freezer Refrigerator
Hi there, my E331T fridge (freezer on top) has started randomly beeping for long intervals with the door closed. It is still running but there is no apparent control now as all the lights on the little...
Check the push switch with your finger,this is located along the bottom edge between the two doors,there will be a second switch for the fridge ..
When the switch is pressed the lamp should not flicker
and should not feel scratchy
a replacement will remedy your problem if the above tests fail
Oct 20, 2017 | Refrigerators
Fridge not working since i replaced door
Hi I would be checking the switch that starts the light when door opens. good luck
May 18, 2010 | Candy CPCA220K Bottom Freezer Refrigerator
Candy Frostfree Fridge freezer, model CPCA240FFK
1st of all conferm that the compressor is automatically (through Thermostate) going to ON/OFF or not, if it automatically goes OFF, i sugges its OK. and if not its no problum. (Minimum 4 hours rest is Must of a compressor, u can maunally OFF it for daily 4 hours Sleep)
Take Care
Jun 17, 2009 | Candy CPCA240FFK Bottom Freezer...
Fridge has become freezer and freezer become fridge
sounds like the control board i had same problem along with no light i had to have control board replaced working fine now
Jan 25, 2009 | Candy CPCA240FFK Bottom Freezer...
Fridge freezes contents
Check the door seal is not split,it may be letting air into the compartment
Nov 12, 2008 | Candy CPCA240FFK Bottom Freezer...
Fridge freezer problem
Your appliance needs to have the condenser area cleaned or it is low on freon. Call a repairman to look into it.
Nov 06, 2008 | Candy CPCA240FFK Bottom Freezer...
Candy CPCA250 GB Freezer feezing but fridge not cold
Hello jonnyclewlow
You said, you recently had a problem with my Candy fridge freezer (it defrosted overnight and wasnt cooling at all) and a repair shop diagnosed a thermostat problem. I have replaced the thermostat, Now the freezer freezes without any problems but the fridge does not go cold at all.
Also the compressor is running constantly
This is my first thought
Fresh Food temperature is
too warm. Freezer
temperature is satisfactory.
1. Fresh Food control is set too
2. Set fresh food control to a colder setting. Allow 24
hours for temperature to stabilize.
3.Then see if you do not have your freezer articles packed full up to the top, or covering the cold air vents usually found in the rear of the freezer compartment.
The fridge and the freezer share the cold air so the air must not be restricted from travel form the freezer to the fridge and back!
This would also cause the compressor to run none stop trying to cool the fridge!
So check your air vents in the freezer.
I'll bet you did not know they were there !
Most of us never notice!
Hope this works for you.
Please let me know that one of these solutions worked for you!
or if you have any questions.
Thank You, huuum
Please remember to leave a rating!
Oct 14, 2008 | Candy CPCA270FFK Bottom Freezer...
It sounds like a Freon leak. The compressor is running and it gets a little cold. THis is not something you can fix yourself. You have to have certification to buy freon and gauges and know exactly how to use them. Besides in most cases you can't find the leak and will have to keep recharging it.
Jun 28, 2008 | Freezers
Candy CPCA240FFK Bottom Freezer Refrigerator Logo
408 people viewed this question
Top Candy Refrigerators Experts
Charles T Nevin
Charles T Nevin
Cesar Quant
Cesar Quant
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
