Question about Radio Shack Pro-95 Handheld Scanner
Blank Display The display window on my Pro-95 remains blank. The scanner has not been dropped or otherwise damaged. The scanner continues to work, but no display. What is it? What can I do?
  • 139 Answers
Bad Solder Conns from the Ribbon to the Main Board can Cause this Ck it Let me Know if this Helps ttech
Posted on Jul 20, 2007
Toshiba Satellite Ultrabook U945-ST4N02 Windows 8,
Check with the moniter by connecting the VGA Cable. is there any display on moniter if yes then laptop;s screen faulty otherwise motherboard issue.
Oct 11, 2013 | Computers & Internet
I cleared my pro-82 scanner. Program button is not working to let me reprogram. Help.
As long as all frequencies have been cleared, try initializing the scanner. This will return everything to the original factory settings.
To INITIALIZE:
- Turn the scanner OFF, then switch it back ON.
- Hold down the TUNE/CLEAR button.
- While continuing to hold the TUNE/CLEAR button down, insert a pointed object such as a paperclip or the tip of a pen into the RESET opening on the side of the scanner, and press the RESET button inside the opening. The display should go blank.
- When the display comes back on, press the TUNE/CLEAR button again. The scanner should now be ready to accept programming.
Need the manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Bill B
May 08, 2010 | Radio Shack Pro-82 Scanner
My phone has a blank screen
Are both displays blank, or only one? Is there any backlighting coming on? Any cracks visible? Was there any damage (dropping, etc.) that you remember around the time they went blank?
If you determine that your phone is actually turning on, do the other functions of the phone work? In other words, can you dial a number and hit "Send" and successfully make a call? Can you get sound out of the external speakers by pressing the little "speaker" key at the lower right of the inside keyboard?
If everything seems to work and the ONLY problem is the displays being blank, it is possible to replace the display module. If you have some electronics experience, and you are considering doing it yourself, see this thread for a little more detail about my experience (I did it successfully.) But you'd want to know that the display is the *only* problem before committing to replacing it.
Otherwise, there's not a lot of repair you can do on these things yourself.
Jan 31, 2010 | LG enV3 VX9200 Cell Phone
On power up, unit begins to go thru calibration. Then freezes up. Display remains blank. Clicking is heard from scanner unit. Scanner bulb blinks on one end. Unplugging sometimes resets to the point it...
May be the scanner is not initialized. Disassembly the covers and take out the scanner section.Open it and clean the ash from mirrors.If not help you may change the scanner section.
Oct 09, 2009 | HP LaserJet 2840 All-In-One Printer
Blank screen goes in and out
My 2096 was doing the same thing with a blank screen. IF, your scanner is scanning normally and the dim button still dims your display, your problem could be the same as mine was. This worked for me and got my display working like new again. First thing to do is to take the covers both top and bottom off to expose your scanners insides.Next, once you can see the inside of your scanner you will see a ribbon cable connected to the main board and also soldered to the display. Take the ribbon out of its coupling connector and gently clean the contacts on the ribbon with a cuetip with alcohol on it, also clean the solder joints on the display face that connect the ribbon to the display with the cuetip and alcohol. Ii then reassembled everything, ribbon back into its connector and made sure the clamping mechanisim on the ribbon was securely holding the ribbon. I pluged the power supply into it and turned it on before reassemblig the case covers to see if it would work. Bingo, it worked like new again. Hope it works for you ! Jim
Nov 04, 2008 | Radio Shack Pro-2096 Base Scanner
Radio Shack Pro 95 Display
Do a google search for GRE america store. They have parts for your radio. Their GRE 295 is the same (different in name only) as your pro 95. I think they are in Belmont shores here in the Los Angeles area.
Hope this helps.
Oct 23, 2008 | Radio Shack Pro-95 Handheld Scanner
Dispaly gone of nokia 72
you need to check the battery first rather ,and ask any cell phone service shop nearby.. display getting blank happens usually in many cell..so don worry..
Oct 14, 2008 | Cell Phones
Msg-blinks no display
Hi Dan, Yes it is a very nice system, but like any device it is sensitive to electrical storms and power fluctuations. A surge or sag (AC power going up or down), can cause the sensitive digital chips to get damaged, and from my experience if you have tried resetting the unit, and your msg lites continue to flicker and the LCD is blank, it has some serious damage and needs repair or replacement.
Aug 25, 2007 | Siemens Gigaset 2420 Cordless Phone
Display
try to set the contrast also did you drop the scanner it just went blank? give more details
Aug 06, 2007 | Radio Shack Pro-95 Handheld Scanner
Radio Shack Pro-95 Handheld Scanner Logo
104 people viewed this question
Top Radio Shack Radio Communications Experts
john milligan
Steve
xxxxxx xxx
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
