Question about Brentwood JC-250 Juice Extractor 350 Watts
OPENING the JC-250 Juice Extractor
Once you have used the JC-250 Juice Extractor, how can I remove the cutter so I can clean its back and the inside of the extractor? I put it together just fine, squeezed out some delicious juice, but now I cannot take the appliance apart again.
  • 5 more comments
  • lynbein Feb 05, 2008
    I can't remove the mesh cutter to clean it. Any suggestion is appreciated.
  • Anonymous Feb 17, 2008
    I am having the same problem. I got this juicer second hand and don't even have a user manual to try to call the company about it. When I first got it from my friend, I had no problem taking it apart, and I'm sure he had used it before. My only guess is that maybe I put it together again wrong.
  • Anonymous Mar 09, 2008
    Cannot open the extractor to clean
  • Anonymous Jun 10, 2008
    the blades won;t come out to clean is there a manual on line
  • mr5050 Apr 18, 2009
    Cannot separate the cutter basket from the machine. -- answer found below
    I hate to admit my wife was right:  "Don't get it.  It's too cheap.  You get what you pay for!"  Gaads, I hate to admit this THIS time, she might have been right!  I am going back to play with it to see if I can figure it out!  There's gotta be a way to clean it!  Otherwise, it is just a salmonella breeding laboratory!
    Oh-oh!  I just found it - (after I cut one of my fingers on the cutters looking for access!)  Here is the answer:
    1.  Do NOT turn the basket/cutter part.
    Just because there is a knurl on the cutter basket doesn't mean we put our hands on it -- yet!
    2.  Turn the entire TOP in which the cutters nest approximately 60-90 degrees CLOCKWISE.
    3.  Lift the entire plastic assembly straight up.
    4.  The cutter basket will now separate from the plastic top.
    Good luck -- and don't cut yourself, unless the taste of your own blood excites you!
  • Anonymous Mar 18, 2014
    I am having trouble getting clear plastic juice container apart from base, to clean?
  • Anonymous Mar 22, 2014
    Juice Extractor NJE 1437
Hey, you probably have figured it out! I just got a juicer without a manual and couldn't find a way to dismantle for cleaning but I got it!!!!!!!!! Just put it upside down and twist and turn. Everything will fall off ( cutter and container). I'm so happy to help!!
Posted on Apr 26, 2009
Hold it upside down and shake from side to side until the basket works itself out.
Posted on Jul 28, 2014
O eu tb nao conseguia tirar a gradinha ,,mas a soluçao e simples !!! vira o juiter pra baixo e jire ele ,,e depois e so da uma chaqualada que as partes todas se soutao.....espero ter ajudado
Posted on Dec 10, 2009
I have the same juicer and it works great. I dread the cleanup though. To take the mesh strainer out, you push down and turn the casing clockwise then pull the stainer up. Easier said then done I know but that' how the directions read. The makers forgot to put in, Pull the stainer straight up with everything you have.
Hope this helps.
Posted on May 03, 2008
  • carolina guzman
    carolina guzman Nov 11, 2014
    thanks, thanks sosososo much, I am glad I did´t kisses and hugs
I have the same problem, I am unable to take the mesh apart to be able to clean the unit. How do I take the unit apart. No instructions came with the unit
Posted on Mar 09, 2008
  • nycmom Jul 28, 2014
    Turning it upside down a shaking a little worked for me!
JUICE MASTER MODEL NT 9214/32597, HAS NEVER BEEN USED. I NEED INSTRUCION MANUEL.
I have this same juicer and its really difficult to take apart. The filter screen with the cutter on it needs to be removed first. Its really tight and hard to get leverage on, but you should be able to get your fingers under it and pull it off. Just pull hard, you wont break it. Once thats off, twist the top part like you were doing and it will come right off.
HTH
Sep 18, 2011 | Salton Jr. JM1 Juicer
I cannot remove the blades from the shaft. This juicer has been in storage with all the attachments in place. I was able to pry it out about an inch or so but can't get it any further. Is it safe to use...
Do not use WD40. Wear heavy leather work gloves. Lightly tap two flathead screwdrivers positioned opposite each other to initially pry the blade apart from the main body of the juicer. Alternate tapping on the screwdrivers until some of the shaft is exposed. Tilt the juicer towards the blade and drizzle olive oil on to the exposed shaft. Every few hours return juicer to stable upright position and use a hammer to lightly tap a screwdriver positioned at an angle that will not gouge the shaft. Rotate blade manually and tap in different positions. Keep juicer tilted towards blade in between tapping attempts to allow oil to penetrate shaft opening. Continue drizzling olive oil on shaft as it is exposed. Cutter may need replacement after this procedure. Use steel wool to thoroughly clean shaft. Soak Cutter blade in hot soapy water for two days.
Sep 30, 2010 | Champion G5NG853S Household Juice...
Juice extractor 67800 350 Watts, The problem is the cutter strainer gets stuck and I can only get it off after much effort and struggle, is there a simpler way ,Margaret
As soon as I had described the problem I found the solution. A smear of olive oil around the inside of the base of the cutter, and around the seating of it, on the unit. And it worked. No problem.
Nov 04, 2009 | Hamilton Beach 67800 HealthSmart Juice...
Juice extractor - dismantling after use
Look at the dismantling and cleaning procedure in JE95XL Juice Fountain Plus user manual on Page 14 and 15. Procedure is the same with JE900.
http://www.breville.ca/site/EN/products/je95xl/je95xl_manual.pdf
This is what manual doesn't tell you: clean the 3 spring loaded pins on the side of the motor clutch. Sugar and pulp may get inside and seize them when dries up, thus making very hard to separate the basket/cutter from the clutch.
Apr 01, 2008 | Juicers
How to take apart
Feb 12, 2008 | Brentwood JC-250 Juice Extractor 350 Watts
Brentwood JC-250 Juice Extractor 350 Watts Logo
3,478 people viewed this question
Top Brentwood Juicers Experts
eyecam
David Payne
David Payne
Tom Chichester
Are you a Brentwood Juicer Expert? Answer questions, earn points and help others
