Question about Brother HL 5150D Laser Printer
New drum and the copies are extremly light
I just replaced my drum in my 5150d brother laser printer, and the copies are very light to a point where they are unreadable. I rechecked the instalation of the toner and the drum and all is well.
I put the old drum back in with the same toner cartridge and the print is correct but has the slight line at the end which is the reason I changed the drum, otherwise the copy is fine.
Is there something i CAN DO TO TROUBLSHHOT THIS PROBLEM WITH THE NEW DRUM?
  • Anonymous Mar 27, 2014
    Samsung laser printer ml2250
Drum may be defective must be repalced.
When replacing drum, be sure to reset the drum counter for HL 5150D:
-Open the toner compartment door, and hold the go button for 5 seconds.
Posted on Dec 10, 2008
  • 628 Answers
Sounds like the new drum is not good. Can you return it and get another?
Posted on Dec 01, 2008
Brother 5150d
1. Press the cover release button and open the front cover of the printer
(so you can see the toner cartridge)
2. Press and hold down the Go button until all 4 LEDs are lit. Once all 4
LEDs are lit, release the Go button.
3.Close the front cover.
4. Make sure that the Drum LED is now off
Mar 19, 2012 | Brother HL 5150D Laser Printer
Leakage onto paper so the one side of each page has black stain right along it.
Could be a leaking toner cartridge or the drum unit is contaminated and needs to be rebuild or replaced.
Feb 14, 2011 | Brother HL 5150D Laser Printer
Blank print comming when i gave print command. I refix the connection & clean scanner assambly. No image come on drum.
check the laser lock level when locked the LASER beam will not reach the drum; check if the front cover was properly closed.
Oct 29, 2010 | Brother HL 5150D Laser Printer
I've replaced the toner and drum. Now the drum light keeps flashing. How do I reset it?
Try this
After replacing the drum unit, keep the front cover open (make sure the power is on).Press and hold the “GO” button until all four LED’s are lit.Once the four LED’s light up, close the front cover.Make sure the drum LED is off.The counter is reset!
Aug 11, 2010 | Brother HL 5150D Laser Printer
Copy is too light after installing new toner and drum,
did you reset the drum counter after replacing the new drum? Open the front cover and press the option button... then just select reset drum counter...and press set...
Jun 02, 2010 | Brother MFC 9700 All-In-One Laser Printer
Drum light flashing
For the Price of these Brother Printers, it's cheaper to just buy a new Printer. I have a Drum Light and Toner Light on at the same time. Currently the copies still look great so I'm just going to let it go until this stops.
Jan 05, 2010 | Brother HL-2040 Laser Printer
Brother HL 5150D printer has all lights flashing
switch off your printer. Remove power cable from printer. Open upper cover remove cartridge and then re-install. Wait for 5 minutes. Connect power cable again and restart your printer. It will work fine.
Jun 20, 2009 | Brother HL 5150D Laser Printer
Printer adds gray tint to paper surface
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | Brother HL 5150D Laser Printer
Brother mfc8860dn copier
Open front cover with power ON
press set
read display....
choose change drum and yes/ok
close cover
will reset bias voltage aka light copies, to suit new drum
Jan 11, 2008 | Brother MFC-8860DN All-In-One Laser...
Brother HL 5150D Laser Printer Logo
294 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
