Question about Dryers
How do i fit the belt between the door and the drum on a tricity bendix dryer
    Scholar:
  • 82 Answers
Hello. I don't know if you have fixed your dryer or not, but on most dryers you have to take it completely apart, top, front and even the back sometimes. Not fun.
Posted on Dec 04, 2008
How do I replace a belt on a tricity bendix TM221W tumble dryer - a video of this would help. thanks.
no video
unplug it
you have to take the top and back panel off
take photos of how the belt is fitted before removal
see what holds the belt on or stops it from coming off
undo what is required and fit the new belt
then reverse all the take apart steps till it is fitted
Tricity Bendix TM221W 91609308601 Tumble Dryer Functional parts Spare...
Dec 26, 2014 | Tricity Bendix Dryers
How to fit belt on a tricity bendix tm310w tumble dryer
round the pulley then around the tensioner then around the drum.
Jun 08, 2014 | Tricity Bendix TM310W Electric Dryer
Replace a belt on a Tricity Bendix TM 320 W Tumble Dryer
1. remove top plastic panel (retaining screws are at back)
2. locate metal brace (12 incles long and 1/2 inch wide) on top of the cabinet (in mine it is on right edge)
3. unscrew retaining small bolts (there is one a few inches below on the inside of the cabinet too).
4. Repeat for left side.
5. push the back and front halves of the cabinet away from each other
6. slide the new belt around the front of the drum
7. reassemble
8. if you need to tension the belt wrap 10-20 turns of insulation tape around the idler pulley
Jan 30, 2010 | Tricity Bendix TM310W Electric Dryer
I am trying to fit a new belt to my Tricity Benix TM320w. I have fed it around the drum, looped it under the motor, but the belt is far too loose to turn the drum
There is a pulley to tension the belt that sits in a slot on the floor of the dryer. If you have the belt wrapped around both the motor and the pulley try going up and under the tensioner in the opposite direction. I've been on hundreds of house calls for this simple solution. Good luck, Dana P.S. You will have to hold the tensioner back in order to get the belt on, if you do not have to hold it back than you are going in the wrong direction. Also, one side of the belt is ribbed and not the other, make sure you've got the correct side down. Look at the motor wear marks on the old belt, that will tell you which side goes against the drum.
Sep 06, 2009 | Tricity Bendix TM321W Electric Dryer
Tricity Bendix Condensor Dryer
the belt needs to go over motor rod first this means you have to take cover off then release the spring that attached to the motor so there is some play with the belt ,then pull the belt around the drum,quiet tight but you can do it,then pull the motor spring back into position to tigthten the belt put back together.... job done
Jan 19, 2009 | Tricity Bendix TM310W Electric Dryer
Tricity Condenser drier
clean the condensor itself
Sep 09, 2008 | Tricity Bendix Dryers
Dryers Logo
Top Dryers Experts
Marvin
Marvin
