Question about Yamaha DVR-S120 DVD Player
DVR doesn't read disc, says region doen't match
DVR says region doesn't match, movie plays in my other dvr and I can't find what the disc region is in it's jacket. If the region in the disc was 1 what other reason could there be for the dvr to give that error message. I tried cleaning the lense an still gives me the same error...
  • cynthia quesada Jan 24, 2007
    That didn't really help because I have no clue where to se the region in either the DVD or DVR
Jimmyd, do other region 1 DVDs play in your Yamaha? If yes, then it's probably the dvd. If other DVDs are also having problems, it's possible that the DVD player's region changed.
Posted on Mar 18, 2007
    Genius:
  • 1,074 Answers
Check the region of the new one probably it is region 4 made in china.your disc is a region one thats the reason why it cannot play on your new dvr which is a region 3 or 4.go on the web and see hw you can hack the code or burn a copy of that same disc.then try it in your new dvr.good luck
Posted on Jan 22, 2007
MY TOSHIBA DVR MODEL DR420KU WILL NOT RECORD ON DISC. IT KEEPS GIVING AN ERROR CODE AND NOW IT WILL NOT PLAYBACK DVD-R DICS, BUT IT WILL PLAY MY DVD+R DISCS. WHAT COULD BE THE SUDDEN PROBLEM?
see the cause and remedies:
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Finally the OPU optical pickup contain lasser beam, NOT are reading the TOC from DISK+ Syscon can be defective, you must go to the repair shop TV for fix it see the diagram attached, is a complex equipment.
God bless you
Jul 16, 2012 | Toshiba RS-TX20 DVD Recorder
I am in australia and play region 4 dvds I want to but a region 1 dvd will it play?
HELLO
Not if your machine is locked to Region 4! It's possible there may be a region hack for your machine, have a look on www.videohelp.com and go to the hacks section.
To see if it will play try to borrow a region 1 disc. If it does not play, then you'll only be able to play Region 4 discs only.
ALL THE BEST (:-)
Oct 31, 2009 | Pioneer DVR-645H-S DVD/HDD Recorder
DVDs burned with Pioneer DVR-110D do not play on the same burner
Are you burning the files with a DVD+R format. Use DVD-R. Not all players will recognize DVD+R. Also, check the region that the movies are made in and see if the player can be switched to that region. Also, are you trying to burn files larger than 700 MB. If you are, in creating an iso image or copy if you are downloading the file you have to match the checksum of the original file to the downloaded one.
Jul 25, 2009 | Pioneer DVR-109 DVD±RW Dual Layer...
LOCKED DVR
I just bought the CH-DVR 1600 @ Target. This is just a temporary workaround to enable playing of region 2 DVD disks (don't have other regions but believe it will work also), until the real regional unlock is available.
1. Insert the region 2 DVD disk and close the tray.
2. Wait for the "Wrong Region" popup to appear in the upper-right corner of your TV screen.
3. The display on your DRV reads "STOP" at this point and the "Wrong Region" popup has disappeared.
4. Press the number "1" button on your DVR remote and a small input popup will appear in the upper-left corner of your screen.
5. Do not press anything else and the DVR will accept this entry as a chapter # and proceed to this chapter to start playing the movie.
NOTE1: The DVR runs in a somewhat restricted node, e.g. the DVR display still reads "STOP" and some remote functions do not work, such as "Menu". The input numbers correspond to the chapters on the DVD disk, so you can experiment and get to the menu once you hit one of the extra feature chapters with a "back to the menu" link on it.
NOTE2: I’m anxiously awaiting the real unlock sequence, as I tried most of the old ones posted here, none seemed to work.
also try this
-Switch player ON with no disc in the tray. Close tray and press MENU, 1, and 9 on the remote control. A menu should appear with the Region Option. Highlight the Region entry and press ENTER on the remote. Type in the Region you want. (Put 0 for code free) Press ENTER again to confirm choice. Press OPEN/CLOSE TRAY button and put in movie.
Mar 31, 2009 | Cyberhome DVR 1600 DVD Recorder
Pioneer DVD RW DVR-K16 Problem
you have to reset your region code.a good technician or even the pioneer care can reset the codes in few minutes. you also take your user manual which is must.
Mar 27, 2009 | Pioneer (DVR-K16) DVD RW Dual Layer Burner
Can't record anything....dvr won't recognize blank
Not sure, but could be as simple as switching to a dvd-rw disc. Not all recorders recognize all formats.
Mar 16, 2009 | Televison & Video
How to record from DVR on Centrios EDW8020 Digital recorder
am new I dont have the manual I need to know how to record I bought the dvr+r disc but its not doing any thing
Mar 12, 2009 | Centrios EDW8020 DVD Recorder
Movie regions
Go to: www.videohelp.com what you are looking for is a region free hack..put your machines numbers in, hit search, scroll down, look to right of screen to see if a hack is listed.
Jun 26, 2008 | Pioneer DVR-640H DVD Recorder/HDD Recorder
DVR 1600
Start by checking the DVR format compatibility list, see if the dvd format matches. The check DVR settings for playing features that can be adjusted. Try other DVD's that have worked on your DVR previously.
Jan 10, 2008 | Cyberhome DVD Recorder - DVR1600
Go Video Unlock Code
check the menu settings or (setup) on the dvr 4000 to see if it has options to enable or disable parental lock or to change region settings to region 1.
also the dvds you made are they +r or -r on what brand dvd record disc on dvd-r this may solve the problem but use a quality brand disc like memorex dvd-r it is compatible with many players and recorders also make sure the disc you made on the recorder were finalized.
Jan 03, 2008 | GoVideo Go Video DVD/VCR Combo
Yamaha DVR-S120 DVD Player Logo
352 people viewed this question
Top Yamaha Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
