Question about HP PSC 2355 All-In-One InkJet Printer
HP PSC 2355 - always says no paper ? It starts some motors and makes lots of noise but does not pull in the paper. The rollers to the front whir round for ages , then it gives in and says "No paper". I have cleaned inside everywhere I can reach. I have put 10,20 and 30 pages in the loader but still the same result. Please help !
  • Anonymous Jan 03, 2009
    No paper found message given even when paper loaded
    Sergeant:
  • 306 Answers
There is a paper sensor that senses when paper is loaded. If there are no obstructions you can see then that sensor is defective and the cost to replace it would be more than buying a new printer unless you are an electronics technician. Check your warranty first of course.
Posted on Nov 30, 2008
Will not print Photo paper
Photo paper may be too slick for the roller to pick up. Can you "force feed" the paper through? Maybe try cleaning the roller(s) with isopropyl alcohol to make it tacky again.
Nov 28, 2013 | HP PSC 2355 All-In-One InkJet Printer
I have a HP psc 2355 all inone printer. It says it is out of paper but there is paper in the printer. Is there anyting else I should do to make the printer work?
Usually the pick up rollers slip causing no feed and the printer then expects it. Popping up a jam , you need to clean the pick / feed rollers which are inside where the front edge of the paper goes. The 2 on the right are the most important, use a damp cloth and rub the wheel horizontally
Nov 25, 2010 | HP PSC 2355 All-In-One InkJet Printer
My printer always jams the paper in the right corner when the paper is fed about a quarter inch over the top of the rollers and into the ink cartridges. I'm not really sure what's wrong with it but I...
Could be ether the roller needs lubercation or something getiing in the paper gidepath you need to check for both, pretty much if its a roller that would be a easy fix also try using a thin grade paper.
Sep 24, 2009 | HP PSC 2355 All-In-One InkJet Printer
My HP PSC 2355 tells me there is a paper jam
Request you to get it check with the engineer personally or their might be a piece of paper stucked somewhere in the corner. I tried the same and was fixed
Jul 02, 2009 | HP PSC 2355 All-In-One InkJet Printer
Printer won't take up the paper
I then cleaned the single big roller located further inside at the left at the back of the printer. Q-tips and Ixos spray. Thank you for your help.
Mar 27, 2009 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 2355 won't feed photo paper
You can't use the photo papers in this kind of printers
Aug 01, 2008 | HP PSC 2355 All-In-One InkJet Printer
Psc 2355
check if there is a back door where you can access from there the rollers and check for any paper stuck , turn on printer and go to DEFAULT setting on the menu . hope it works
Apr 18, 2008 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 2355 Truncated lines
Try cleaning the paper rollers and the print head.
Use a wet cloth to clean the paper rollers.
Use a little amount of water and some alcohol (Isopropyl alcohol) to clean the print head. (You may not need to do this if your printer cleans it automatically through software utility.
This may be also have caused by the low ink level. Replacing the cartridge should solve this problem.
Oct 19, 2007 | HP PSC 2355 All-In-One InkJet Printer
Out of Paper. Load Paper Error
Check
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=nz&lc=en&dlc=en&product=422000&dlc=en&lang=en
HP PSC 1600 and 2350 Series - Paper Jam or Paper Feed Problems"
When the all-in-one detects a paper jam, the following message appears: Paper jam: Press OK to continue . The computer might display the following message: There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. This document will assist in correcting paper-feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. s.gif Clearing paper jams
Jul 28, 2006 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 2355 All-In-One InkJet Printer Logo
105 people viewed this question
Ben Johnson
