I WANT TO DELETE MY OS - Computers & Internet
  • 341 Answers
It's not so much about deleting it as it is about writing over it.If it is your C or main drive you can't delete your O.S because the O.S would be deleting itself. Do you see were this is going?
So lets say you want to replace your O.S. Read your user manual and find out what key on your keyboard you need to press to get into your bios.Turn on your computer and before you boot into your O.S hit that key. You will go into a blue or black screen with simple text. One of those lines of text will mention something about boot order or sequence.Use your manuals instructions and make your cd/DVD as your first boot device.Again, using your user manual as a guide save your changes.Usually you press F10 for this but yours may be different.Put your O.S cd in your drive at this time. Boot your computer and follow the instructions as the cd loads. That should do it.
Posted on Nov 30, 2008
  • Howard Lester Nov 30, 2008
    Maybe so, but if he wants to reinstall the O.S that is how he will need to do it.Why would he want to delete the O.S on his C drive if he wasn't going to reinstall it.Like lots of questions on here the asker doesn't give you very much to go on. I think your answer is incomplete.If I asked the question I would be wondering what I needed to do next
  • 340 Answers
Hi Sunbreeze,
there are two ways doing that.
1. Boot on your OS disk and chose overwrite
2. Start/run/ - type cmd, in the black boks, type format c:
and when the system say "cant do - do you want to do it when you reboot" (or in that area) - you choose yes.
then reboot.
But, remember, there is no way back, so dont forget to copy all documets, photos an private stuff.
/Teis
If this was helpful, then dont forget to vote "FixYa" :-)
  • 1 more comment
  • Teis Thomsen
    Teis Thomsen Nov 30, 2008
    Sorry Howardepgco
    your solution is pretty complicated, all sunbreeze wants is deleting C:
    /Teis
  • Teis Thomsen
    Teis Thomsen Dec 05, 2008
    When less than a quarter feel the need to vote for the effort some of us at FixYou offer, I think to myself, ”is it worth it”.
    They get help, and do not care to thank you; “thank you” do not cost a dime, so why????
    /Teis
  • Teis Thomsen
    Teis Thomsen Dec 15, 2008
    Hi, back again,
    Wondering if you got your problem Fixed,
    - if not, let me know,
    - if it´s Fixed, then vote “FixYa” to close this case,
    Thank you
    /Teis
How to delete a hard drive of os ?
if its a multiple os option at startup you want to get rid of you :
-press start
-type msconfig in the search field and hit enter
-select the boot tab
-select the os you want to delete (the current active one do tell you its the active one in its description)
-press delete
-OPTIONAL: you may also set the timeout optiion as low as 3 sec. making it go away in 3 sec instead of 30 sec
if you want to delete an os system from a secondary harddrive (the active system will not allow you to delete it) it should be as easy as to remove the protected and hidden attributes (right click a folder and options) and delete it - this does not remove it from the multiple os option at startup- see above
Jul 27, 2014 | Microsoft Windows 7 Ultimate for PC
I have 2 copies of OS and want to remove bad one
type in msconfig and depending on what os you have type this in program search or run box if windows xp. in the box that comes up select boot. there you will have the option to delete the bad os when you highlite it. it will ask you to restart your computer and bad os should be deleted.make sure you delete the bad os and not the good 1. hope this helps.
Aug 08, 2012 | Dell Inspiron 5100 Laptop
To delete all documents from the hard drive to return the computer to the factory
if you just have one drive in your computer then format it with your OS cd if you have more than one then right click on each drives other than C drive and then click on format. after formatting each drive except C. Format your pc with your OS cd.
May 29, 2011 | Computers & Internet
My Inspiron 1521 is running unbelievably slow. I was able to delete 50 cookies, but that has not helped. What else can I do?
There are other things you can do to restore the its performance :
1. delete all cookies
2. delete all temporary internet files (*.tmp)
3. Move most of MS office data in your OS directory to other directory including the data in your
desktop
4. Defrag. your OS directory
Good luck,
Nov 19, 2010 | Dell Inspiron 1525 Laptop
There is only one OS, but during booting it shows three
Delete the OS Command line inside the MSConfig indow by clicking start - run -type msconfig then press enter. On the MS config window click on the boot.ini tab then you will see the command line inside the text box. Leave the first command line from [Boot Loader] till the end of the command line of your Default Operating system.
Example:
(Leave this lines)
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect
(Till here!)
(Delete this line)
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Viz XP Example line Professional" /fastdetect (up to here)
any other command line that says Viz XP -- you may delete it. Click apply button then Restart the computer afterwards and this should fix the issue.
Should you have any other questions just please leave a comment.
Cheers~
Jun 28, 2010 | Intel D845GVSR Motherboard
I have two os on my computer, how do i delete one of them?
Each OS will have its own partition. When the computer starts enter the Bios and choose to boot to cdrom. With your OS disk in the cddrive let the disk load and it will show your two partitions. Highlight the OS partition you wish to remove and choose delete, it will have you confirm by choosing the ``L`` key . the partition will be deleted , just exit and reboot the computer.
Sep 26, 2009 | Microsoft Windows XP Professional
I have to window xp pro x64 installations on the
you can delete one OS from registery.
go to my computer properties > Advance > startup & recovery settings > edit. here you can find two OS registery. now you can remove one OS registery.
Sep 10, 2009 | Microsoft Windows XP Professional
Windows not booting
Regarding on your problem, the main issue their is the booting problem of XP after you delete the fedora operating system. That's common problem especially when the computer are in dual boot OS then you delete the other OS. Now, the reason why it usually fall into this problem its just because the XP is your core OS then you install Linux Fedora inside in XP so whatever changes you have done in fedora particularly deleting Linux OS inside XP affects the overall performance of your XP and eventually if you delete the Fedora without proper unistallation process done by Linux OS then the Boot Loader of your XP will also corrupt or delete that's the main cause of boot failure in your XP OS. Now the best solution there is to repair your XP by inserting the XP CD Installer and boot the CD to repair your OS or you can reinstall the XP OS without formatting the storage to prevent the lost of your data that has not yet already copyed a back up.
Please do this recommendation to save and restore your XP.
thanks
Sep 04, 2009 | Microsoft Windows XP Professional for PC
Installing new OS
If you chose delete partition, ensure that you have saved your data, this will delete all data and format the hard drive to install your new system.
It is the est way to get rid of viruses, bue it will delete everything from hard disk.
If you chose delete partition, chose create new partition afterward, and then format. That is the way it works.
May 11, 2009 | HP Pavilion a1610n PC Desktop
I am not able delete data on pendrive my laptop winxp os
Check that the correct driver is installed for your pendrive and check that your usb port is not damaged.
Dec 12, 2008 | Computers & Internet
Computers & Internet Logo
89 people viewed this question
David Payne
David Payne
