Question about NexxTech DP3222 DVD Player
Nexxtech DVD Slimline model DP3222
Hi, My Nexxtech DVD model SP3222 powers itself off after 5 seconds. It has been used maybe 4 times, and I have had it for just over a year. I have used it recently to play CDs and just today when I went to turn it on, the power light stayed on for 5 seconds and then it turned itself off again. I can't push any function buttons to keep it from turning the power off. I have tried several times but there are only so many buttons to try pushing. What would you suggest? Toni
    Top Expert:
  • NexxTech Master
  • 51,372 Answers
Could be an open internal fuse or power supply failure
Posted on Jun 04, 2017
4 Suggested Answers
SOURCE:
SOURCE: NexxTech DP3222 DVD Player
Open tray, press on the remote, stop-2-3-7-9, press arrow down until 0 and press ok.
Make shure you put TV TYPE --> ntsc in the general setting
I tried this (on a multisystem set that can be "made to think" that it's a PAL or NTSC set as the case may be) and it worked. The Nexxtech DP3222 and the Entiveo DP3220 are basically the same unit except that (a) the hack for the Nexxtech doesn't require resetting every time you turn the unit on and off, unlike the Entiveo (this is really annoying) and (b) you can set the Nexxtech to multisystem, NTSC, or PAL standards, whereas the Entiveo is NTSC-only, but (c) the fast-forward on the Nexxtech is somewhat less intuitive than on the Entiveo (involves holding a button down). All in all, I prefer the Nexxtech, if only because it is more easily hackable. And I would have sworn that the Nexxtech had a blue screen saver on it before I started hacking it, because now it has a really gross-looking black-and-white screen saver. But I don't care about screen savers as long as the unit does what I want it to do.
Posted on Jan 28, 2008
Nickstar19
  • 417 Answers
SOURCE: nexxtech dp3222 dvd player
DISC IS STUCK U NEED TO OPEN DVD PLAYER REMOVE MANUALLY ITS REALLY EASY TO DO JUST TAKE THE SCREWS OUT TAKE LID OF REMOVE DISC THEN PUT LIT BACK ON PROBLEM SOLVED
Posted on Jul 02, 2008
jpc1994
  • 35 Answers
Try a Laser Lens Cleaner disc.
It is a CD with brushes on the bottom to help clean the laser lens (used for reading discs).  It can be found cheapest in grocery stores, then office supply stores, and finally most expensive in electronics stores.  It will usually run you about five to ten dollars,and can be used multiple times on any disc drive.
Posted on Aug 13, 2008
I am unable to play DVD from different region on my Samsung ht-c655w??
Hi!
Follow this:
1. Open tray and remove any disks in tray.
2. Close tray.
3. Switch Off Player and unplug from power. wait 30 seconds (this clears RAM)
4. Reconnect to power.
5. Turn on player with remote.
6. Press ENTER (middle button of the arrow keys) on remote. (ignore message on screen)
7. Press 8, 4, 2, 6, 9 using keys on remote.
8. Press ENTER on remote.
9. Wait until player finishes processing. (approx 15 seconds)
10. Player will turn itself off, otherwise turn off player with remote.
11. Turn power back on with remote.
Player is now Region Free.
Regards,
Pelu.
Mar 21, 2011 | Samsung Black DVD Player DVDC350
My 40" toshiba tv nexxtech
Please let me know if this works for you! would love positive feedback! if this doesnt work let me know as well will continue to help
toshiba codes are 0159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141
an to reprogram it you have to follow these directions if found from an online manual for this model
Turn on the device you wish to program the remote to, point the remote at the device and press the key for that particular device (TV, etc.) on the Nexxtech remote. For TVs combined with a VCR or DVD player, use the "TV" key, and for VCR/DVD combination units, both "VCR" and "DVD" will need to be set up if your particular remote offers both.
  • 2 Locate the code (or possible codes) for your brand and type of device in the list supplied with your remote. Press and hold "P" until the display light blinks twice and then enter the first code. The display light will blink with each digit and blink twice if the code was accepted; repeat using the next code if it was not. Press "Power" once the code was accepted to see if the device responds by shutting off. Repeat the steps for all the codes listed under that brand name.
  • 3 Search for a code if none of the listed codes were accepted or if you do not have the list by pressing the appropriate device key, pressing and holding "P" until the display light blinks twice and pressing "9-9-1." Press "Power" to see if the device responds, and press "CH+" to try more codes if it does not. Press "P" again to lock in the code when successful.
  • 4 Point the remote at a programmed device, press the device key, press and hold "P" until the light blinks twice and enter "9-9-0" to learn the code for that device. Press "1" to see the code for the first digit; count the number of blinks on the display light and write down that number. If the number is 0, the light will not blink at all. Repeat for the next three digits by pressing the number key for that digit (2 through 4).
  • 5 Press "9-9-2" after pressing "P" to reassign a device key if, for example, you have two DVD players and no VCR and want to program the "VCR" setting to the second DVD player. In this example, follow "9-9-2" by pressing "DVD" and then "VCR", and then program in the code for that device.
  • Mar 17, 2011 | Toshiba Televison & Video
    Where can I find the remote for this device?
    here you are
    • http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=NexxTech+DP3222+&uuid=12777825676710
    feel free to rate the help
    Jun 29, 2010 | NexxTech DP3222 DVD Player
    Im looking for a used macvision mp007
    I own a macvision mp007 portable dvd player I am looking for the back seat support and a car adapter.
    I want to connect this for my son when we drive, he is 5 yrs old born with autism.
    I think it would look great in my car, and some even better once I connect it to my car sound system
    May 16, 2010 | NexxTech DP3222 DVD Player
    Set clock on sd-kv550-su
    There are two ways to set the clock on your machine, firstly by using the 'auto clock' feature and also a manual setup, if the auto setup doesn't work then you will need to setup your machine manually. the 'auto clock' feature will atempt set itself up and will take approx 4 mins for the machine to adjust itself. There is also a daylight saving setting which you can either have set to on or off. The auto and manual steps that I have added below have been taken from the user manual for your your Toshiba SD-V295 pages 24 - 26.
    Hope this helps,
    James
    Auto Clock Adjustment
    Preparation:
    • Turn ON the TV and select the corresponding video input.
    • Press VCR DVD selector to select the VCR mode.
    (The VCR mode indicator will light.)
    1. Connect the Antenna or Cable system.
    If you use a cable box, turn it on.
    2. Plug the AC power cord to the AC outlet.
    3. Make sure the DVD/VCR is turned off.
    If you press POWER, the Auto Clock set is not programmed.
    4. Wait at least three minutes and press POWER.
    5. Press CALL DISPLAY to check the clock setting on the on screen display.
    6. If the clock is not set, check the antenna
    condition. The AUTO CLOCK may not function properly if the reception condition
    is not good.
    Manual clock setting
    1. Press VCR MENU.
    2. Press SET + or – to select “SYSTEM SETUP”, then press ENTER.
    3. Press SET + or – to select “CLOCK SET”, then press ENTER.
    4. Press SET + or – to set the month, then press ENTER.
    5. Set the day, year and time as in step 4.
    6. After setting the clock, date and time starts functioning automatically
    Apr 25, 2010 | Toshiba SD-V295
    Radio controlled clock model 6302000 - cannot
    I have the same clock and had the same problem. My clock was a demo and had no instructions with it. Here is the solution:
    1. Pull out the battery and wait 10 seconds then replace the battery. The satellite symbol should start flashing after a few seconds.
    2. Put the clock outside or in a window sill till it updates. This could take a couple of minutes.
    3. Press the Mode button once to enter programming mode.
    4. Press the Adjust button as many times as needed to toggle through the time zones.
    5. Press the Mode button once to exit programming mode.
    Apr 02, 2010 | NexxTech Travel Alarm Clock (63-8042)
    Hi, I need a 5 digit remote control code for a Nexxtech DVD player with 5.1 speakers. Thank you.
    Using only the remote control do the following: open tray, then press on the remote, stop-2-3-7-9, press arrow down until 0, then press OK.
    Jan 22, 2010 | NexxTech DP3222 DVD Player
    Wireless speakers not communicating to Receiver
    Speakers have a unique RF frequency that needs to pair with the receiver (kind of like a blue tooth headset with a cell phone). At times, the signal may reset, so, you may have to go through the initial pairing sequence. Try this:
    1. Unplug rear speakers
    2. Make sure the sound signal connector is plugged in to the back of the system properly.
    3. Press and hold the ID button for 3 seconds until the blue LED light flickers.
    4. Connect the power chord to the rear speakers.
    May 03, 2009 | NexxTech DP3222 DVD Player
    NexxTech DP3222 DVD Player Logo
    164 people viewed this question
    Top NexxTech Televison & Video Experts
    Tom Chichester
    Are you a NexxTech Televison and Video Expert? Answer questions, earn points and help others
