Zenith lamp timer
please email me how to reset the lamp timer on my zenith d52wlcd - i tried holding down Enter on TV and Mute on Remote, but did not work.
Thanks,
Mike
mdepalma@gmail.com
  • 9 more comments
  • mjpalm Dec 07, 2008
    Dear Ladywinn,
    I do not understand the first part of your soultion "Reset lamp timer plug in set and it will go into stand-by-mode"
    do I not turn the tv on?
    do i need a special remote or will the stock one work? thanks!
  • mjpalm Dec 09, 2008
    Thanks LadyWinn but I am doing something wrong.
    1. I installed the new lamp bulb.
    2. I plugged in my Zenith D52WLCD. Only the Red Light is on (the tv power is off)
    3. I pressed and released the ? button.
    4. I pressed and released 9,8,7,6 and then pressed released Enter (i do not have an OK button)
    5. None of the 3 lights flashed, and the tv still powers off as if the timer has not been reset...
    Please tell me what I am doing wrong.
    Thanks!!!!
    the fan and the tv comes on for approximately 1 minute, then shuts off. then, the red lamp light flashes which supposedly indicates that the lamp is bad and that the timer must be reset.
    was I following your procedure to reset correctly of a zenith d52wlcd?
    thanks
  • mjpalm Dec 10, 2008
    the fan runs, but the tv shuts off because the lamp timer needs to be reset - tv shuts off, and lamp indicator light flashes.
    was I correctly following your procedure to reset the lamp of a zenith d52wlcd?
    Just to clarify my problem:
    I turn the set on. It runs perfeclty for about a minute. It then shuts off. The Lamp Indicator Light flashes red - which is supposed to mean the bulb needs replacement and the timer needs reset. I replaced the bulb, but cant get the timer to reset.
    thank you for all your help and please advise.
  • mjpalm Feb 10, 2009
    can anyone help? I have tried ladywinn's solution with no success
  • mjpalm Feb 12, 2009
    ok, i have also replaced the fan, as well as installed a new bulb. but i still cannot get the lamp timer reset window to appear.
    please help
  • mjpalm Feb 14, 2009
    my remote has a ? and 9,8,7,6 buttons. It has an Enter button, but not an OK button. Is having one with an OK button the only solution?
  • mjpalm Mar 08, 2009
    ladywinn, i replaced the fan. i also bought the service remote . what do i do with the service remote?
    ok, i got into the service menu by pressing in-start. then i press lamp timer and enter. it shows 0. how do i change it from 0???
    in case anyone else reads this:
    1. use the remote 105-201m
    2. press in-start
    3. press 6, enter
    4. press 0
    5. then, put in new bulb.
    6. then smile you did not pay for a service call
  • 5,138 Answers
I dont have the code with me its at my shop will get it tomorrow and let you know.
Posted on Dec 01, 2008
  • 6 more comments
  • ladywinn
    ladywinn Dec 02, 2008
    Reset lamp timer plug in set and it will go into stand-by-mode Now press ? key on the remote , Now press 9,8,7,6 and the OK button rhe 3 leds in front will flash for a moment to verify the lamp timer was reset to zero.
  • ladywinn
    ladywinn Dec 08, 2008
    Do not turn set on all sets when first pluged in go into a stand by mode waiting to be turned on. and my answer is a fixya solution because this is how you reset timer.!!!!
  • ladywinn
    ladywinn Dec 09, 2008
    Your problem is not in the lamp or reset timer you have other trouble < ck ballaster.also if Fan does not run lamp /nor the power will come on .
  • ladywinn
    ladywinn Dec 10, 2008
    Pull back off watch to see if fan stops running ,if it runs for awhile then stops it is bad.
  • ladywinn
    Fan must keep running in order for set to turn on and for lamp to work and come on itself.
  • ladywinn
    ladywinn Feb 10, 2009
    Replace the Fan ,just fixed one with same problem and it was the fan.
  • ladywinn
    ladywinn Feb 13, 2009
    Is there anywhere you can borrow a hand unit with the OK button on it if not call L&G Electronics for assitance.
  • ladywinn
    ladywinn Apr 08, 2009
    Have you fixed your tv Yet? IF NOT there is a fan located under the light engine if it is not running or working all you will get is RED light on TV.
Reseting the end of lamp life indicator
Hold down mute button on remote and enter on TV
at the same time for a few seconds, you should get
a screen promt asking if you want to reset the timer
for the lamp.
Mar 31, 2009 | Zenith E44W46LCD 44" Rear Projection...
E44W46LCD Lamp Timer Reset
To reset the lamp timer, hold the "enter" button on the tv and the "mute" button on the remote at the same time. Once the menu pops up, hit the right arrow on the remote and confirm the reset.
I would guess that's it's a little too late for this answer now, but for future reference... ;-)
Jan 09, 2009 | Zenith E44W46LCD 44" Rear Projection...
Zenith d52wlcd
Yes it can definately be reset with the service remote, all the newer models will reset with the mute and enter simultaneous buttons. I would try to call a local service center and see if they have the remote and how much they'd charge to come reset it. I know we charge a lot to come out, but if you brought the tv in (i know not the prefered method) we would just quick reset it for free. The mute + enter lamp reset is in no service manuals or training guides so I'm not positive it will work but I'd try it a few more times because I'm pretty sure it works on the wlcd models.
Dec 07, 2008 | Televison & Video
Rest lamp timer zenith
Hold mute on the remote and enter on the front panel of the tv simultaneously for 5 seconds. Make sure the remote is getting signal to the TV. This works on newer model zenith and lg digital projections.
Dec 07, 2008 | Zenith D52WLCD 52" Rear Projection...
Lamp reset timer
hold mute on the remote and enter on the front panel for 5 seconds. this will bring up the lamp timer reset.
Dec 06, 2008 | Zenith D52WLCD 52" Rear Projection...
How to reset lamp hours
try holding the enter button on the tv and the mute button on the remote. a reset screen will pop up and then just press the center direction button twice.
Sep 04, 2008 | Zenith D52WLCD 52" Rear Projection...
ZENITH D52WLCD
I just found the solution on another model of Zenith TV. Hold the enter button down on the TV and the MUTE button on the remote. In approx. 5-7 seconds a screen will pop up asking if you want to reset the lamp timer. Hit the bullseye button in the middle of the arrows and it will reset. Worked perfectly.
Apr 15, 2008 | Zenith D52WLCD 52" Rear Projection...
How to reset lamp timer
press and hold the "enter" button on the TV, the press and hold the "menu" button on the zenith remote-- after several seconds of holding both buttons the option of re-setting the lamp came up. Hope this helps
Jan 18, 2008 | Zenith D52WLCD 52" Rear Projection...
How do I reset the replace lamp message
Do you have a picture? If so the only way to reset this unit is to get a Zenith programmer remote. With this remote you can get into the service menu and reset the lamp timer and that will reset the unit.
Dec 31, 2006 | Zenith D52WLCD 52" Rear Projection...
Televison & Video Logo
318 people viewed this question
Top Televison & Video Experts
Electro Med Services...
