Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Loude noise how do i oil it or the moter ????
  • 125 Answers
There is no way to oil any vacuum. the oil will attract dirt
noise is usually a bad bearing in the motor, or blown fan over $100 in a dysoncut your losses and buy a Panisonic
Posted on Dec 02, 2008
How do I stop Eureka Pet Express from making loud noise?
does it make the noise with belt disconected if not its the brush . it could be installed wrong check it.
Dec 03, 2014 | Eureka Pet Expert Vacuum Cleaner in Mystic...
Samsung vcu366 making loud noise but picks up
what does the really loud noise sound like? Is it a loud, whining sound? if so, the motor may be getting ready to go out. Also check that the belt isn't stuck-though you would smell burning rubber if that were the case.
Mar 08, 2014 | Samsung Vacuums
Loud noise coming from cyclonic cap
sounds like you'v lost a rubber seal check this diagram on the link below see if you can see anything missing
http://www.vacpartswarehouse.com/Dyson-DC24-Upright-s/3888.htm
Apr 01, 2013 | Dyson Ball DC24 Bagless Upright Vacuum
Why is my central vac. making such a loud noise. It sounds like jet getting ready for take off. It seems to be getting louder. I'm not using it because i'm afraid it's going to explode or...
The bearing or the motor is warn out they last 15 years in the case. In some rare case the brush ware out or the rely can catch fire, most central vacuum are not made to be oiled! Hot oil will catch on fire. Best to unplug the vacuum unit call a few shops and ask replacement motor cost, if you remove the Vac and take to them it will cost less.
Jun 25, 2011 | Vacuums
My Dyson DC25 makes a loud beeping noise when I turn it on. Sounds like the noise a big truck makes when it's backing up. What is the cause?
you must not have operated the machine for sometime now.....so try to oil the shaft of the motor and then it will work smoothly
Jan 08, 2011 | Vacuums
Hi. My machine works, but is beginning to sound loud. My husband says it sounds like things are rubbing together and it needs oil. I have lost my manual and don't know where to oil it. Please help.
It is not any oiling but the motor must be making the noise due to a damaged bearing/bush. An oiling might redduce but might not be a solution.
But in the first place we need to open to confirm as the source of noise is the fault itself.
Maybe a reset can solve the issue.
Sep 09, 2010 | Vacuums
Our DC 17 is making a loud high pitched noise when turned on.
bearings are going. Take it apart and oil moving parts like bearings. I like to use WD40 and then oil.
Dec 28, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Loud 'drilling' noise from motor area when turned on.
Sounds like bad bushings/bearings in the motor -- need to replace them.
May 27, 2009 | Electrolux Vacuums
Rainbow SE makes Squealing Noise when switching it On/Off
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=528929
Rainbow SE makes Squealing Noise when switching it...
Posted by ray_s51 on Apr 20, 2008
My Rainbow SE works and runs strong but when I switch it on and off for approx. 20 to 30 seconds the motor makes a loud squealing noise. Do I need to oil something or what? Nothing smells, it does not make the noise all the time, but it does more often than not. Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum.
The Rainbow has 3 fans in the bottom of the motor and if they are weak they will make noise from the motor unit. Watch out… the repair of the Rainbow may exceed the cost of a new motor of which will solve your problem of noise and separator --- compare the cost and the labor and make a decision. The separator is part of the armature, the separator should be able to be removed and that might be one of the things making noise. As normal maintenance the separator should be removed and cleaned after every use and re-installed, then place a newspaper or towel under the motor unit and turn on the Rainbow and spin the moisture out of the motor unit. This should be done every time you use it. If you have further questions please feel free to contact your local vacuum cleaner dealer. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Apr 20, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Loud noise
When the motor bearings start to go bad, they will make a loud noise. Some motors if a piece broke off of the fan, then it also will make a loud noise. You may have to replace the motor.
Dec 25, 2007 | Westinghouse WST1500 Wired Special Edition...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
73 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
