Hot point wf541. have top 2 lights on wont pump
Will spin but wont pump out. have just unblocked pump think the pump has broke but need to make sure before i order 1. the top 2 lights are wash enhance and reduce creases also the on/off button is flashing
  • 3 Answers
I have encountered a similar problem. The following lights were flashing on and off:
  • On/Off.
  • Reduced creases.
  • Mini Load.
I also found that previously one of the 'lifters' inside the drum had broken off and someone had tried to put it back in place and continued to use the washing machine. After a short period of time the above mentioned flashing lights began.
I first suspected the pump, but this was fine. I then disconnected the hose which connects the hole from the drum to the pump and I found a child's sock blocking the hose. I removed the obstruction, put it back together and the machine worked perfectly. I also replaced the lifter (apparently these break quite often) and the machine has been working perfectly ever since that day.
I hope this helps. Good luck.
Posted on Jul 02, 2009
  • Washing Mach... Master
  • 3,463 Answers
Hi.
The sequence of flashing lights is in fact indicating an error condition on your m/c.
It indicates that the m/c has failed to drain, possibly because the pump filter is blocked.
Your m/c is fitted with a filter system for the pump,
The filter may have become blocked, see care and maintenance in your handbook, in your handbook for details on how to check and clean the filter.
Also make sure the door is shut properly.
If after you have checked all these points, and it still does not work properly, then I suggest you have someone to look at the m/c, or replace the pump if it does not appear to be working.
Hope this helps.
Please leave feedback.
thanks.
Posted on Nov 30, 2008
Surpentine belt broke replaced dorve for about 15 minutes car quit will not start replaced fuel pump and crank sensor still wont fire need some help trouble shooting
need to take belt off and spin each pulley by hand to make sure they all spin freely and also look and make sure when belt broke that it did not cut a wire or something like that
Mar 04, 2011 | 1991 Lexus LS 400
I am trying to change my water pump and the thing wont come off how do you take it off
Make sure all the bolts are out then lightly tap with a hammer heres a picture of the waterpump make sure all labeled bolts are out then tap with hammer to remove,mark the location of the pump so you wont have to keep spinning it to line up the bolt holes, i marked the top of the pump, you will see that the lip is bigger than the other two that one points at 11 oclock, hope this is helpful.johnjohn2_27.jpg
Dec 01, 2010 | 2002 Buick Rendezvous
Hotpoint wf541 will not finish cycle it wont do a final spin then all the ligts start to flash how can this be fixed
Possibly a blocked filter.
If no filter at bottom front of washer then you need to remove lower rear cover of washer.
Remove l;arge black hose fastened to drum.
Remve and clean filter inside hose.
Remove hose onto pump, and check for obstuction or blockage here as well, and look inside the pump.
If all o/k, and it still does not spin, then it could be for one of several reasons.
Hope this helps solve your prob.
Thankyou
Nov 26, 2009 | Washing Machines
Aquarius wf541. Am trying to remove pump filter to clean .
think yourself lucky my plastic broke when i was unscrewing it or tying to ended up cutting my knuckle open on the shard of plastic and water pumping out all over my kitchen is there somewhere that you can purchase the cap from and how do you get the broken one off???
Nov 01, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Same problem
Power it off at the mains for 60 mins and then rety. If it still does the same then call in a repair man as it is most likely thatthe main controller board is faulty and needs replacing.
Sep 11, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Fisher and Paykel GWL11 Question
no belts ..direct drive ..lean washer back pump is a twist lock no tools needed hose clamp can be removed with fingersremove pump and ck for lock impeller also ck the diverter valve just behind pump
Jul 16, 2008 | Fisher and Paykel GWL11 Top Load Washer
Hotpoint wf541
ckd to be sure pump is operating in drain/spin feel pump housing for vibrationn from pump spining if pump not runing or huming ckd voltage to pump with wires removed.. voltage 110? pump probably bad ck for loose impeller they have been known to come loose from motor shaft..no voltage? ckd wiring at control bd last resort bad control bd..good luck
Jun 18, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Wont Spin
Hi Vixxy, Which lights flash when you hear the beeping?
Jul 23, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
191 people viewed this question
Top Washing Machines Experts
