Question about Philips 42PF5421 42 in. LCD Television
Hi watching tv and it just switched off
Tv swiched off as if the fuse had gone but i tested it and it was fine, there is power going up to tv , but cannot switch on any ideas??? 42pf5421/10 philips 42" lcd hd 2 years old ish
    New Friend:
If checking the capacitors does not reveal any rounded caps and all the capacitors look ok then the problem could be the back light. I am not a repair specialist but i get tv's and monitors from ppl that arent working and make a hobby of fixing them. The first thing I try on screens that have gone out is adjusting the brightness. if the screen is dark but a picture is still displayed the backlight is failing. To fix this turn the brightness all the way down and the backlight may not require as much power so it does work in cases of both backlight failure and low capacitance issues. also a repair shop will have a test kit to test the power flow through different parts of the circitry system to find faulty components.
Posted on Mar 22, 2013
    Sergeant:
  • 217 Answers
First of all check out the tv power cord wire is it fine or seems like it got cut from some where or do you get any burning small from the wire.if this the case then repair that wire.if the wire is proper then try that wire in another electric outlet.if everything does not works.then is naturaLLY the internal board error.any of the capacitors or the ICs have gone short .the faulty 1 should be checked and replaced.
Posted on Nov 30, 2008
Tv swich off completley
The power supply has a fuse on it. If it's blown then you'll have to isolate the cause. TV Parts Universal TV Stands DLP Chips ShopJimmy has replacement parts and a board repair service.
Feb 27, 2016 | LG Televison & Video
Wharfedale LCD2710HDAF no power to tv, checked cable and changed fuse a few times, new power lead? or is this a common problem?
Hi.
The power cord must be checked using a multimeter. The test is done reading impedance (ohms) between plug's prongs and contacts to TV power board.
If the power cord is OK and there is no power, then the problem is the power board inside the TV.
Regards.
Ginko.
Dec 04, 2011 | Televison & Video
Tv does not swich on. The red led light plinks 5 times.
5 flashes, bad lamp and/or lamp driver
4 flashes, bad or stuck fan
There is a chance that the bulbs are not bad, but you will need a small fan to test this. Place a small fan blowing directly behind the set and run it for several minuts before turning the set on. This may help clear the code and allow you to watch tv if not then your lamp or driver has gone bad and needs replaced.
Jul 02, 2011 | Sony Bravia KDL40HX800 40 in. LCD 3D HDTV
Fuse seems to have gone so tv cannot switch on.
If you fuse had gone off then it is most possible that the set has a failure within, This can a short in the powerr supply section or the high voltage section. So first of all remove the back covers and use a multimeter to check on the power supply which could be swittch mode power supply. You must look for short in the surge protector, the filter capacitors, the rectifiers, teh main capacitors or the SM drives. If these are fine discconnect the HT side and switch on to confirm the power supply. If fine check on the HT for failure of the drivers/ capacitors in the section by a contiinuity, voltage test. Do it carefully, get help if not familiar. Good day
Aug 05, 2010 | Televison & Video
Have no spark and fual pump has no power going to it
check the anti-rollover switch in the trunk, either side and reset it like a breaker.
Jun 20, 2010 | 1997 Ford Escort
Drivers window in pontiac montana 2002 went down and will not come back up. how do i test to see if the switch is working. The right window is functioning very well.
Most likely the window motor/regulator assembly has gone bad.Check for good fuse, if good pull out the switch and make sure you have power to it, if you do then remove door panel and test for power at motor, if u have power but motor won't work replace. Suggest replacing the regulator assembly as well because the cables often fray and cause problems as well.
Mar 17, 2010 | 2002 Pontiac Montana
Dead laptop
hi guys...can you try to remove the battery then plug the AC/Charger then see what happen..only charger no battery pack in Laptop...
thanks
Apr 05, 2009 | Acer Aspire 5920-6335 Laptop
MY BRAKE LIGHTS ON MY 1996 JEEP CHEROKEE LARADEO DON'T WORK, WHY
Hi, there should be a microswitch behind the brake pedal,it works the lights each time the pedal is depressed, it may need adjusting or replacing,or it may have come off its mount.
Dec 16, 2008 | 1993 Jeep Grand Cherokee
Dush TV 28" RF6683VPL switch off while I was waching tv
Hi there sorry but this could any number of things. But i dont think you could repair it your self. It would need to go to a repair shop. It is most likly a power supply fault inside the tv . All the best Bob
Jul 20, 2008 | Bush 5693D 24" TV
Tedelex TV
would it be reccomended to buy a tedelex tv
Dec 15, 2007 | Samsung TXN3271HF 32" TV
Philips 42PF5421 42 in. LCD Television Logo
165 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
