Question about Relisys TL775 17" LCD Monitor
I require an adapter for my Relisys TL775 LCD Monitor.
I currently live in Germany and require an adapter for my Relisys TL775 TFT LCD monitor (U.K. Model). Can you provide me with the name of a supplier in U.K. or the name/type of a suitable Germany adapter which I could use.
    Sergeant:
  • 306 Answers
Belkin makes an adaptor for nearly everything regardless of the country. You must specify which connector you have by name and what you wish to connect to for further help. Here is a link to a UK mag review which spells those designators out for you: http://www.pcpro.co.uk/reviews/44632/relisys-tl775.html
If you need further advice please repost. Steve
Posted on Nov 30, 2008
Power Issues!
The AC adapter will go into shut down mode if the monitor is drawing too much current due to short circuits in the monitor, but it can also be bad caps in the power supply itself. You can try new adapter or check inside the monitor for shorted components.
http://s807.photobucket.com/home/budm/allalbums
Apr 24, 2010 | Scanport GEM GL-821A/B 17" Flat Panel LCD...
We have a relysis 1520 15" TFT, sound ok but no sign of a picture
peterobin378, Gee, wiz, sounds as if you have internal power supply failure. Inverter circuit can't source voltage and current to light-up the "cold cathode-fluorescent-lamps" anymore. Inspect it for BAD swollen, leaky electrolytic filter capacitors and or poor soldering ( cold or frosty looking) solder joints of surface and through hole components. 12fixlouie
Jan 30, 2010 | Relisys RLT-1500 15" LCD Monitor
All of a sudden there is no picture on my relisys 15" tft monitor, sound and channel change work, please helpnessa, thanks va
The fault is likely the back-light. The fault could be the inverter board that supplies high voltage to the CCFL lamp or the CCFL lamp. The CCFL lamp is a mini fluro tube.
For service, parts and DIY info check out LCD Parts - click on this link to their WEB site : -
www.lcdparts.net
Oct 20, 2009 | Relisys RLT1720 17" LCD Monitor
Plugged wron ac adaptor into my LCD monitor
LCD monitors use CFL lighting behind the liquid crystal display. There is an inverter circuit just for the CFL lights which requires some of the DC current from your adapter to be converted back to AC. most likely your inverter was blown.
Your only solution, in that case, is to take it to a repair shop to have any blown electronics replaced... or just get a new monitor (which might be about the same price as a repair).
Sep 21, 2017 | Relisys TL775 17" LCD Monitor
RELISYS TL766 17" TFT MONITOR
Hi,I have same monitor and problem,still unable to resolve, I been told to try the monitor on other PC to see if the actual problem is in the monitor or originates from the PC.
Oct 03, 2008 | Relisys TL 766 Monitor
Relisys vl1710ru 17" monitor start up problem
I think the pincushion of your screen needs adjusting and this can only be done internally. If it is a brand new monitor return it otherwise find a competant technician. Hope this helps.
Sep 30, 2008 | Relisys TL775 17" LCD Monitor
Monitor gone dead
does your tower turn on? just check if the monitor is the cause of the problem..
Jan 20, 2008 | Gateway FPD2275W LCD Monitor
INPUT SIGNAL OUT OF RANGE
some how your screen resolution has changed above or below what your monitor can display. you need to boot your computer using another monitor that can work with the resolution your computer has switched to(i used a spare crt monitor when it happened to me) change your resolution in display properties to a normal level like 1027x768, and while the computer is on swap the monitor cables to verify the lcd is working.
It is perfectly safe to unplug the video cable and plug it back in while the computer is turnned on.
Dec 26, 2007 | Relisys TL775 17" LCD Monitor
Relisys TL775 17" LCD Monitor Logo
167 people viewed this question
Top Relisys Computers & Internet Experts
Samuel Konger
Samuel Konger
giarcnameloc
Level 1 Expert
Are you a Relisys Computer and Internet Expert? Answer questions, earn points and help others
