Question about LaCie 80GB Rugged HD USB 2.0 80 GB Hard Drive
My lacie 80 gb external harddrive does not work properly. when plugged in, it says searching for software and after awhile, it gives a message that the drivers were not successfully installed...
    Problem Solver:
  • 14 Answers
Try to unstull the software and renstull it again
Posted on Nov 30, 2008
Lacie External Drive won't turn on (blue Light doesn't go on)
Inside the LaCie D2 250GB (300770) external harddrive's case, is a 250GB IDE (PATA) harddrive that is 3.5 inches across in width.
A desktop computer sized harddrive. (May be a Western Digital WD25000JB)
The harddrive plugs into a small circuit board, (Bridge board), and the circuit board has a USB port on it.
Using this Western Digital Passport for an example,
http://www.xbitlabs.com/misc/picture/?src=/images/storage/wd-passport-250gb/p3.jpg&1=1
Scroll down to the second photo, and left-click on it. The case of the external harddrive is shown open.
Inside is a 2.5 inch laptop sized harddrive.
An aluminum tape strip covers the small circuit board, attached at the back of the harddrive.
The second photo down on this page, shows you the small interface circuit board, that the harddrive plugs into, with the aluminum tape removed.
http://www.xbitlabs.com/articles/storage/display/wd-passport-250gb_2.html
(Another design has wires coming from the small circuit board, to an interface the harddrive plugs into )
It is this small circuit board that goes bad in a LaCie. QUITE common.
Solution?
Simple.
1) Obtain a 3.5 inch IDE external enclosure
2) Remove the 3.5 IDE harddrive from the LaCie's case.
3) Install the harddrive out of the LaCie into the external 3.5 IDE enclosure.
An example of a 3.5 IDE (PATA) external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 19, 2012 | LaCie (300770) 250 GB Hard Drive
My lacie drive fell off desktop and is not recognized as readable by my Mac. What chance do I have of recovering the data?
Inside that LaCie external harddrive's enclosure is a regular SATA harddrive.
The kind that fits in a desktop computer (3.5 inches in width), or laptop. (2.5 inches across in width)
Open the external enclosure (Case) of the LaCie, remove the harddrive, and install it into a suitable external enclosure.
(Laptop size, or desktop size)
The external enclosure has a USB cable also. Just plug it into any available USB port on your desktop computer.
Do I know for a fact that the harddrive is okay, and this will fix the problem?
No sir/maam I do not.
But IMHO this is the first diagnostic method to use.
IF the harddrive is a desktop sized harddrive, it could be installed in your desktop computer as a Slave drive.
However the above method is so much easier, and it allows your harddrive to be an external harddrive once more.
Inside the external enclosure of the LaCie external harddrive, is a small circuit board that the Harddrive plugs into.
It is this small circuit board that receives the damage in most cases.
If the problem is the Harddrive itself, a professional data recovery shop will;
A) Try a new, or good used harddrive circuit board.
Check to see if the harddrive's circuit board received the damage.
B) If the circuit board proves to be good then the next step is to remove the Platters inside.
The room used is a Clean Room.
A room that is 99.9 percent dust free. (In most cases)
The Platters are installed into the case of a compatible harddrive, that has the Platters removed.
Then as much information as possible is copied off.
There are other methods data recovery specialists use also.
[A Harddrive is built in a Clean Room. 99.9 percent dust free. The technicians wear a Clean Suit, that resembles what a doctor would wear in an operating room.
They enter the work area after going through a corridor, fitted with air jets at various levels.
If a harddrive is opened up in a room that is not a Clean Room, the harddrive's 'life expectency' drops to a day, or a few hours. The dust 'kills' them ]
http://computer.howstuffworks.com/hard-disk.htm
http://www.youtube.com/watch?v=gpY8c7lT_7k&feature=related
http://www.youtube.com/watch?v=ax390l2A-AY
Observe the other videos also.
Examples of both a SATA 2.5 external enclosure, and a SATA 3.5 SATA enclosure,
(The Harddrive's width is measured in inches. (2-1/2 inches for a laptop drive, 3-1/2 inches for a desktop drive)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
SATA 3.5 external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4421576&CatId=2780
Regards,
joecoolvette
Jul 02, 2011 | LaCie Hard Disk design by Neil Poulton...
My LaCie 500GB External Hard Drive stopped working. Before when I turned it on, I could hear it spinning but now all I hear is a clicking sound. When connected to my computer the computer no longer...
Sorry nothing to do your harddrive is dead. you might be able to open the case and replace the harddrive with a new one. Try searching google or youtube on how to do that.
Regards.
Mar 19, 2011 | LaCie Design by F. A. Porsche 160 GB Hard...
Hi I have a Lacie External Harddrive 500gb, when I connect my hard drive to my computer it does not open, instead it gives me a message saying that " disk is not formatted"?
The disk was probably dropped or jolted. You can consider the drive bad now. The arm is broken inside. You can format the drive but most likely it won't work after that. Getting the data retrieved can cost up to $2500-$5000.
Nov 30, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
I accidently formatted the drive, now have no
try recovery softwares, download pc inspector file recovery software its free on net
Sep 21, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Having a similar problem with the La Cie 500gb. Powerbook G4.
The problem that has been inherent with all LaCie external harddrives, is the interface in the case itself.
Interface:
All external harddrives have a Style of harddrive that is used in a laptop, or one that is used in a desktop computer.
Laptop harddrives are 2-1/2 inches across in width.
Desktops are 3-1/2 inches across.
Your LaCie will have a 3.5, (3-1/2) inch desktop style harddrive, inside the case.
There are two main Types of harddrives.
IDE and SATA. (There is also a newcomer. SSD. SSD isn't being used in LaCie external harddrives at the moment, to my knowledge)
Your LaCie will use a SATA harddrive inside it.
This is an example of an average SATA harddrive,
http://en.wikipedia.org/wiki/File:Hdd.jpg
The photo of this harddrive is tilted at an angle, that doesn't readily show the interface connection, but it helps to explain.
At the bottom of this harddrive in the photo, and to the left, is the interface area.
Viewing the harddrive, look at the four metal pins on the extreme right of the harddrive. To the left of these pins is the Jumper pin area. (Has a white jumper on two of those pins)
To the left of the Jumper area is an opening, and to the left of that, is a long slot. The first small slot area is for the 7-pin Interface cable.
(Data cable) The next slot to the left, is for the 15-pin power cable.
This 7-pin Interface mates up to socket holes in a connector, of the case of the LaCie external harddrive.
It is this interface connector, inside the LaCie external harddrive case, that is the problem.
Solution?
Buy a quality, in-expensive External Enclosure, take the harddrive out of the LaCie, and install it in this enclosure.
Examples of 3.5 Sata External Enclosures,
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2780&name=3.5-eSATA-enclosure&Nav=|c:2778|&Sort=0&Recs=10
(From $15 to $35, is a good range for a decent external enclosure)
Jul 22, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Sometimes the hard drive will connect and sometimes it won't.
There have been problems plaguing the LaCie external harddrives, for quite some time now.
The issue directly relates to the interface, inside the external enclosure. I don't know if you are acquainted with harddrive designs, or the interface that they plug into. If you are, disregard the following.
This is an average example of an IDE harddrive, http://en.wikipedia.org/wiki/File:Hard_drive-en.svg
Looking at this illustration, note where it points to -> IDE Connector. The illustration isn't very good, but those dots are metal pins.
The connection inside your external harddrive,
that connects to the harddrive itself, is called an Interface. This is a plug that has socket holes, to match those metal pins.
Now we go a little deeper. There are two types of harddrives. One is an IDE harddrive, the other type is a SATA harddrive. Your LaCie
will have a SATA harddrive inside.
Instead of the 40 pins that an IDE harddrive has, the interface for a SATA harddrive has 7.
(It has 15 pins for the power connection)
Now my solution:
Should you wish to save data that is on your LaCie external harddrive right now, I suggest you buy an external enclosure, (SATA), take out the hardrdive thats in your LaCie, and install it in the enclosure.
Since, the dimensions of the, LaCie design by Porsche 160GB external harddrive are:
Height -> 1.4 inches, (About 1-1/2 inches)
Width -> 4.4 inches, (About 4-1/2 inches)
Length -> 7.4 inches, (About 7-1/2 inches),
I'm willing to bet the harddrive inside is a desktop harddrive size. (3.5 inches across in width)
http://www.lacie.com/download/datasheet/porsche_hd_en.pdf
These are examples of 3.5 inch SATA external enclosures,
(A $25 or $35 unit will work just fine)
Jul 18, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Lacie 1tb external hard drive into ps3 is not regconised
I have the same issue, however with my verbatim 500g its ok. i believe it is because the lacie is a desktop external and therefore is compatable with windows xp and 7 alone.
Verbatim is a "portable" external hard drive which makes it compatible with several different systems. I would suggest returning it, I just formatted my old verbatim harddrive and set up mediaasharing. Through my router. You can actually route the lacie harddrive by going to my computer and right click the icon. Next go to share with; advanced settings and allow all. Then when you turn your ps3 on search for media servers... I would suggest to google media server for ps3 to get it all seet up. GOOD LUCK
Jun 07, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
External Harddrive Overheated
The disk in side is jammed, try throwing the harddrive like a frizbe but dont let go. That might help unsick the drive
Mar 28, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Can the disc of a external harddrive be change to get your data recovery back
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Jan 14, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
LaCie 80GB Rugged HD USB 2.0 80 GB Hard Drive Logo
157 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
