Question about Husqvarna Designer I
Designer One "broken thread"
Can't figure out why the machine stops, giving me the message that the upper thread is broken. It isn't broken, nor misfed. I did discover that many times it was because the upper spool of thread was too free spinning. Using the spool holder more firmly helped. However, after sewing for several hours without problem last night, today I can't sew more than a couple inches without getting the thread broken message, same stitch, thread and fabric. This has been on-going, despite being at the shop twice. Help!
  • Kathy1226 Nov 17, 2007
    I have the same problen and have tried everything from shutting off the machine, to re-threading both top and bobbin and it still does it. I would never buy another Husqvarna sewing machine. Too many problems.
    Novelist:
  • 192 Answers
If the upper thread spool is spinning allowing slack to the inlet of the tension assy and the machine gives a broken thread indication shortly afterward, the pre-tension assy needs to be adjusted. If the machine has the original "snap in" tension assy that was in the first generation of Designer 1, have it replaced with the modern "lay in" tension assy. Slack at the spool should never cause a broken thread indication as long at the thread is in the pre-tension assy.
Sulky thread will work as well in a Designer 1 as any other embroidery thread as long as it is properly adjusted.
One thing that you can look for, when the machine is sewing, watch the thread as it passes out of the left hand side of the tension disks. It should exit the disks at the 9 o'clock position. If it starts to drift up to the 10 or 11 position and then you get a broken thread warning, the pre tension must be increased.
Posted on Apr 08, 2008
    Problem Solver:
It took a while but I finally found the solution to the "beeping" message that my thread broke when it really didn't. I was using Sulky thread! After spending two hours with a great Designer 1 repair person on a simple design, we determined it was the Sulky. We tried a simple design using Robison-Anton (no problems), Madeira (no problems) but as soon as we put Sulky in, it couldn't sew more than three stitches. I'm tossing all of my Sulky and never buying it again.
Posted on Feb 14, 2008
  • 201 Answers
This usually happens on my Des1 if the upper thread has not caught the bobbin thread at the first stitch. Make sure you have enough bobbin available (sometimes the cutters cut it too short) to be caught, and that you hold down the upper thread with your finger for the first one or two stitches. Most times this happens, though, it is from faulty upper thread threading - hate to admit it, having been a sewist for many, many years but sometimes we are just too careless with stuff we do a kazillion times a day.
Pam
Posted on Dec 22, 2007
Prior to sewing on a new project, check the upper tension. sounds like something is automatically releasing the tension so that it reads 'no tension' . also, the lower tension could be contributing to the problem, so it should be checked also. if the upper tension is totally released after the machine is turned off, the tech needs to know this. same thing goes for the lower tension ( bobbin tension). good luck
Posted on Nov 12, 2007
SOURCE:
New singer plus one.....constantly stopping with message top thread broken (which it is not) but there is a nest of thread from the spool underneath...have rethreaded from spool and bobbin # of times
bird nesting of the bobbin thread is a result of the needle thread tension not tight enough
increase that tension up and the message may be eliminated
Nov 20, 2016 | Singer Sewing Machines
Thread error message
rethread needle using every thread guide, also try changing the needle, if that doesn't help them the machine may have a computer problem
Dec 24, 2015 | Brother SE-270D Computerized Sewing...
Check and rethread upper thread message appears often even when the upper thread is not broken
The thread may not be lodging firmly in the tension mechanism. Make sure that the thread is firmly settled between the tension discs.
Also keep an eye on what is happening with the thread in the take-up lever (the arm that moves up and down with each stitch on the head of the machine) as the thread may be 'jumping' out thus causing the message.
What is the make and model of machine with this challenge?
Oct 13, 2014 | Sewing Machines
Machine keeps stopping with upper or lowef thread broken message. Thread isn't broken?
Bobbin might be upside down or backwards and for thread breaking the tension is too tight .
May 20, 2014 | Husqvarna Sewing Machines
Babylock ellegante 2
Threads bits/dust has accumulated at top thread sensor or the sensor need to be replaced
Oct 30, 2013 | Baby Lock Ellure
Upper tension when sewing fleece
This seems silly to ask but are you remembering to put down the foot? Try re-threading the upper thread with the foot raised... then try again. Make sure that your thread spool isn't catching the thread in that little thread keeper slot. Also make sure it isn't spooling in such a way that it wraps extra lines of thread around the spool pin. Also make sure you are using a Needle designed for sewing fleece.
Jul 16, 2012 | Sewing Machines
FY100 embroidery machine
Take a very good look at the upper thread very well because it is possible that it is truly broken because for it to stop working something must have truly happen.
If after careful look and nothing was observe broken, then i advice you carry out maintenance check or service on the machine. This will help in a long way to fix the problem.
Take care
Apr 23, 2010 | Feiyue FY100
Error message says please check upper thread. I do that and then it stops after a few stitches. Please Help. Carolyn
Hi
Likely there is thread or lint caught in the "flag" on the upper check spring or there is a broken thread caught in the take up levers
Most of the time the front cover has to be removed to get to the problem
contact me if you cannot get this resolved
sewaway@shaw.ca
Wayne Buss
Apr 14, 2010 | Bernina Artista 180
Trouble with sensor
The upper thread sensor on most Brother's is activated by the check spring. Either your check spring has broken or is stuck. You may be able to fix this if you can get to it. A drop of oil may be all you need. I may be able to give more specific advise if you tell me what model it is.
Feb 06, 2009 | Brother Sewing Machines
Repeated message: "Please Check the Upper Thread."
The machine stops because the sensor near the check spring(in the tension area) tells it the thread is broken or not there.. You can try to clean it out again but it's probably going to have to go in for service.
sewman7
Jun 07, 2008 | Bernina Artista 180
Sewing Machines Logo
442 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
MissFixIt828
Level 1 Expert
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
