Dell laptop does not switch to battery power
The battery gets charged ( I've switched between 2 batteries to cehck the same). When I check through the Power Meter, it shows me how much charge is remaining on the battery. But the moment AC power goes, the laptop switches off. Local laptop repair guy doesnt want to touch it since it's too old (!). Machine is otherwise in excellent shape, so I do not want to discard it.
  • 64 Answers
It sounds like defective motherboard. If your laptop is more than six years old, it is not worth to repair.
Posted on Dec 01, 2008
Lap top will not charge battery
Sounds like the charging circuit on your motherboard is defective. Also check the AC adaptror by switching it with other Vostro.
Jan 30, 2012 | Dell Vostro 1014 Laptop Computer (Intel...
Sometimes the Adapter Charges other times Doesnot, and now finally out, cant charge!
Possible cuase:
1 AC adapter failure
2 Power jack failure
First replace it with another working charger, see if the problem gone. If not, there may be strong possibility that the power jack was broken.
Here below are some common symptoms of a bad charger.
-The laptop only runs when you keep the power cord in a certain direction.
- The laptop only runs on battery power.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently.
- The unit suddenly shuts off
- Sparks come out of the back of the laptop.
Reference: Dell Latitude D620 Charger
Jan 20, 2011 | Dell Latitude D620...
Latitude E6400 - power charging problem. Power button is not blinking and laptop is not booting up
follow the steps:
1. check ur powercord & adapter.
2. if its working then check the battery, reseat the battery & check.
3. if available then check with another battery
4. if no, then remove the battery & switch on the PC in AC mode.
5. check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. if indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
ALL THE BEST
Aug 17, 2010 | Dell Inspiron 5100 Notebook
Laptop wont charge battery
its a comment fualt with laptops the micro switch that switches between charge and main power goes faulty on them, you could be acutally onto some thing here because ther eis alot of people with laptops that wont charge at all, and if they knew ur little sequence you got going on there maybe you could save their laptops been door stoppers.
Dec 01, 2009 | Dell Latitude D410 Notebook
My dell inspiron battery is not charging.
PLz tell me about the model no.is it inspiron 1521 or 1501,From the problem u hav stated it seems that the battery is not getting charged.The computer is only running when the adapter is plugged in.
2 reasons:-
1.the batter have died
2.if it is a new computer or u have purchased a new battery,,then the problem is with the terminals from where the battery gets charged
Moreover some laptop batteries shipped by dell were faulty and dell launched the battery recall program,,specially of older inspiron models.give the service tag of ur computer to the dell technical support guy,,he will check it thru.plz keep me infmd about the prob,,and plz do reply if it gets resolved
May 12, 2009 | Dell Inspiron 6000 Notebook
My dell C840 wont power on.
well if the laptop worked till there was charge in the secondry battery its an issue with the cord or the port that connects the powercord to the laptop. ie the inlet on the laptop. check these two as well.
Mar 29, 2009 | Dell Latitude D830 Notebook
Dell Inspiron 8500 no lights, no fan, nothing.
First remove the battery and try it. If it works without the battery, then that is the problem. My Inspiron 2650 suddenly started acting like that with the battery in but works perfectly without the battery.
Whenever you replace a battery ALWAYS let it completely charge BEFORE you try to use the computer with the battery in place.
Do the POWER, DISK ACTIVITY and/or BATTERY CHARGING light stay on?
If so try powering the computer off; unplug the power cord; remove the battery; carefully remove the RAM modules; check the connections for corrosion/dirt; them reinsert the modules; close up the case; plug the power cord in and try powering it up without the battery inserted to further eliminate the battery as the problem.
If you get NO lights or fan noise without the battery installed, you probably have a mother board problem, most likely in the power switch. With the 2650s the switch is an integral part of the motherboard (DELL calls them system boards I believe) and DELL recommends replacing the board. I guess if you can find someone brave enough to work on the board, you could fix the switch because DELL refurbishes them and if the board isn’t working anyway, then you have nothing to loose.
I hope this helps you. Good luck. The 8500s are good computers if you get enough memory in them.
Don Jones
Jan 25, 2009 | Dell Inspiron 8500 Notebook
Battery will not charge
Hi cdravi
Laptops have a power supply control section attached to, or part of the main board. This allows the laptop to switch charging on and off, and control power supply function to different areas of the machine. Sounds like you have a fault in this part of the computer. Off to Dell Service for that one I am afraid.
robotek
May 05, 2008 | Dell Latitude C610 Notebook
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
