Question about Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore dishwasher lock light
Can't get the lockout to go out and release the other controls!
Door opens-followed the procedure outlined on the door-no dice!
    President:
  • Kenmore Master
  • 2,651 Answers
You tried holding hte "control lock " buttonn for 3-5 secs and it still didnt unlock??? if thats the case your problably gonna need to replace te console/ touchpad
Posted on Nov 30, 2008
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Oven door locked
Many Kenmore ovens have a control lock that keeps the oven door locked even when the self-clean cycle has not been in use. This feature is meant to prevent children from opening the door or using the controls on the oven. To cancel the oven lockout, push and hold "Stop" for three seconds. Wait 15 seconds for the oven door to unlock automatically.
Reset
After verifying that the oven lockout feature has been released and waiting at least an hour after a self-clean cycle, if the oven door remains locked, try to reset the oven. Disconnect power to the range, and wait 30 seconds. Restore power and try again. If the door remains locked, disconnect the power and try to reset the circuit breaker or fuse. Contact Kenmore if the door remains locked after both attempts at a power reset at 800-827-6655.
Feb 26, 2014 | Kitchen Ranges
The oven door is "locked" on my Kenmore slide in electric oven. There is a button on the display that says "oven lockout" that was evidently pushed, but now I can't open my oven. How do I unlock the oven...
Sorry but I don't know much about the Kenmore however, I would suggest that it has some sort of Child Proof locking mechanism to stop kids from putting their hands in a hot oven. Some ovens automatically lock once they start to heat up, some can be locked all the time. Perhaps on yours, like some other brands, 1 or more buttons need to be pressed at the same time on the control panel to release the lock? Have a look in your manual or look closely at the control panel itself, it may say press this/ hold that, whatever, to release the lock.
Feb 22, 2014 | YouTube Videos
Windows only work from the drivers door controls
Check the master window control panel on the driver's door. There is probably a lockout switch. It may have a window outline on one end and the same outline with an "X" over it on the other. Press the outline without the "X" and all your windows should work again. As silly as that sounds, a lot of people hit that switch without knowing it. Also, if that switch(lockout) is faulty, none of the windows will work. That happens A LOT!!
Window fuse's and relay's may be up under driver or passenger side dash or behind glove box, under the hood and even under the seats, and finally on the ends of the dash. All passenger power windows and locks are controlled thru and get power from the master control switch on the drivers door.
Aug 26, 2011 | Dodge Stratus Cars & Trucks
The remote control for my liftmaster 1280LM garage door opener does not work. I have changed the battery, made sure the lock feature is off and have tried reprogramming the remote. It does not appear to...
The receiver is going out and will not receive signal from the remotes. try to reset it by unplugging the motor from the power sorce for about 30 seconds and then plug back in. this should reset the logic board. If this doesn't work you will need to replace the board
Sep 26, 2010 | liftmaster Chamberlain Garage Door Opener...
Keyless entry not working
Programming
When
Remote control added or replaced. System malfunction.
How
Obtain all remote controls. Remove key from ignition switch. Close all doors. Open driver's door. Carry out the following within 24 seconds: Turn ignition switch ON and back to LOCK position 3 times. Remove key. Press and release driver's door courtesy light switch 3 times. Ensure doors lock and unlock. If not, wait 40 seconds and repeat procedure starting with driver's door already open. Press each remote control lock or unlock button twice. Ensure doors lock and unlock after each remote control operation. If not, proceed as follows: Press and release driver's door courtesy light switch once. Ensure doors lock and unlock twice. Repeat procedure starting with driver's door already open.
NOTE: A maximum of 3 remote controls can be programmed.
Mar 29, 2010 | 2004 Mazda 6
Kenmore dishwasher 665 lockout problem
You may have a bad control console.
Jun 20, 2009 | Kenmore Dishwashers
Lock Light Blinking
silly question but did you try holding the control lock button(perhaps its the heated dry button) in for 3 secs???? sonds as if the CONTROL LOCK has benn activated( child lockout)
Jan 14, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore 24 in. 15932 Built-in Dishwasher Logo
123 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
