Question about HP Color LaserJet 2600n Printer
Printing mess my 2600n was on standby for a quite few months and today i used it and tried printing but the result was a mess. it has some lines from top to bottom of the paper. what will i do to solve this problem? pls help, thanks
  • BabaH Nov 30, 2008
    thanks llincon! i tried this procedure earlier but the result is still the same. what else do you think should i do?
    thanks for your quick response llincon! i really appreciate it!!
    i tried it a while ago but the result was still the same. whatelse do you think should i do next?
    Problem Solver:
  • 4 Answers
Removed each toner (one at a time). Turn them over (so the label is facing the floor) and slide the shutter door (piece of black plastic, approx. 1"x10") so it moves left or right. This will expose the drum unit. Look at each and see if there are any streaks, marks, or excess toner. Also, are these compatible toners? Look for leaking toner inside the printer. Use a good flashlight. If that doesn't work, you may have a torn fuser sleeve (depending on what the mark/line looks like). If that is the case, it may cost too much to repair.
Posted on Nov 30, 2008
    Sergeant:
  • 217 Answers
Remove all the toner cartridges and then u need to clean the dirt collected in the printer.you can blow air with a blower machine.then shake the cartridges up side down for few minutes and then insert 1 by 1.it will work. the problem is either the dirt/dust collected in the printer or the cartridges are got over and needs refilling or replacement.
Hp 2600n line
after you have printed a few pages switch the machine off just as the paper leaves the fuser. then open the front cover and take a close look at the image transfer belt ( black plastic conveyor type belt)
use a torch shone accross the belt to better light the error- if you can see these Green/yellow/cyan lines on the belt then theres a good chance its coming from the toner units- ( also try print quality troubleshooting pages in the menus under diagnostics.look at the individual colour pages and look for any lines or Uneveness about the shaded colour) replace whichever toner is not printing correctly
Jan 22, 2014 | HP Color LaserJet 2600n Printer
Fuser error 50.2 laserjet 2605dn Printer was not use at least two months. When I try print today I got this message for first time. 25 minut time out (power out) doesn't work.
If the printer is not plugged directly into the wall outlet, power it off and plug it into the wall. Power on. If message comes back, replace the fuser. If not, leave it plugged into the wall.
50.2 means that the fuser is getting too hot.
Aug 14, 2010 | HP Color LaserJet 2600n Printer
Hp 2600n printer printing light on the left side of the page
clean the scanner & calibrate the printer thre times ur problem will be resolved
Jun 03, 2010 | HP Color LaserJet 2600n Printer
HP Photosmart C4490 won't print
teps on how to change jet ink cartridge where do i pull on the printer.
Jun 24, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
HP LaserJet 1600 printing 2 lines on paper, Uneven but straight.
If the line is one specific color, then change the corresponding toner cartridge. (You may be able to see the line on the drum in the toner cartridge.) If the line is a mix of colors, then it is probably either the transfer belt or the fuser. In either case, you could replace the whole printer for about the same cost as repair.
Apr 06, 2009 | HP Color LaserJet 2600n Printer
Hp color laserjet 2600n ''black print down form its orignal place''
an allignment need to perform on printer with proper placement.
Nov 27, 2008 | HP Color LaserJet 2600n Printer
My hp 2600n color laserjet leaves RED DOTS on the printed document. What should I Do?
look at the red cartridge do you see any dots on it ? is it only when you print? what about if it's just Blk & wht?
Jul 21, 2008 | Sharp AR-5320 Black and White Copier
Lines across printed page
try to locate the print head of the unit. you will see a mirror there. clean the mirror maybe it has some foreign object.
Jul 04, 2008 | HP Color LaserJet 2600n Printer
HP Laserjet 2600n networking
When you print a test page from the general tab of the printer properties dialogue, it completely bypasses the print spooler. Since your test pages print correctly, this tells us quite a bit. Some of it good and some of it bad.
The Good:
The printers, base driver install, connections and protocols are all functioning correctly.
The Bad:
The printers, base driver install, connections and protocols are all functioning correctly making it much more difficult to pinpoint the problem.
JetDirect printing through the print spooler can be trouble prone with no clear solution. The fact that the 2600n is a host based GDI printer can make it even more so however I still have a couple of things to try.
1-Search for Localspl.dll and check the version number, file size etc. etc. If it is anything other than:
(32 bit x86)
Localspl.dll 5.2.3790.4046 342,016 23-Mar-2007 20:24 x86
Or:
(64 bit x64)
Localspl.dll 5.2.3790.4046 750,080 23-Mar-2007 22:15 x64
then request a copy of this file from Microsoft here:
https://support.microsoft.com/contactus2/emailcontact.aspx?scid=sw;[LN];1414&from=KBHotfix&WS=hotfix
See KB934885 http://support.microsoft.com/kb/934885
for more info. You may want to try the registry tweak there to see if it can help pinpoint the problem as well.
2-Download the latest firmware for the 2600n from HP. There have been at least 2 firmware updates that I know of for this printer. I don't know if any of the updates fixed issues with network printing but at this point it can't hurt.
Firmware: http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=446153&prodNameId=446154&swEnvOID=1005&swLang=8&mode=2&taskId=135&swItem=ly-32271-4
Jan 15, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n - Thin White Line on Print Out
Which color is this line? Try changing respective cartridge..
Sep 09, 2007 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
268 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
