Question about Garmin Nuvi 660 GPS Receiver
I am not able to download european map of garmin into sd card
I just downloaded an european map from emule, I transfered the file into the sd card, but it still does not work. What can I do?
  • Garmin Master
  • 638 Answers
You are attempting to install illegally obtained software onto a Garmin unit and it won't work? That's because you need to contact Garmin and they will sell you an unlock registration number.
Posted on Dec 02, 2008
I paid for a costa rica map thru Navsat. I need to download it to my Garmin. ow do I do that?
Typically downloaded maps can simply be installed by placing the downloaded file in a certain directory on your supplementary memory - in this case a micro-SD card. You can either plug your Garmin into your computer with a USB cable or use a SD card slot to do this.
You want to place the (unzipped) gmapsupp.img file under e.g. E:\Garmin\ after backing up any data on the storage device you are writing to. If its a new SD card you will need to create that folder.
You can also save yourself some money by downloading free maps here: http://garmin.openstreetmap.nl/
Jan 13, 2014 | Garmin Nuvi 265W GPS Receiver
Garmin nuvi 200 SD card
Did you rename the file extensions? On the unit, the map file and map unlock file must be named gmapprom.img and gmapprom.unl
On the SD card they must be named gmapsupp.img and gmapsupp.unl.
Also copy your garmindevice.xml file over to the SD card too.
Feb 26, 2013 | Garmin nuvi 200W GPS Receiver
We downloaded a European map onto the SD card, however, when we look at maps available, the Garmin 260 is not looking at the map on the SD card. How do we tell the device to use the card to search for the...
You need to download the map to your compute rather than the SD card. When downloading the default destination is the satnav but you can change it to your computer. When it's installed to your computer you then click the windows START button and in the list of programs you'll find a GARMIN folder with a program called MAPINSTALL. Connect the satnav to your computer with the SD card in. Run MAPINSTALL and select the SD card as the destination.
You can get more details of how to do it at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
Note maps installed to SD cards do not always work with Garmin Nuvis. To give it every chance of success please follow the instructions at the above link about formatting the SD card.
Jun 14, 2011 | Garmin nuvi 260W GPS Receiver
Need a North America SD Card map for my European Garmin nüvi 255w. Where can I buy one on line
You can buy direct from Garmin via this link. You can opt for instant download, purchase of SD memory cards or DVD ROM medium. You may also be able to buy maps at some of the outdoor stores and electronics specialty shops.
If you plan on using this GPS in North America from this point on, you might want to look into purchasing a "Lifetime Maps" subscription for about $119 instead of the one-time map purchase for $79. The subscription allows you do download updated maps up to 4 times per year, for life of the GPS. Contact Garmin Support directly for more info about this option.
Nov 22, 2010 | Garmin nuvi 255W GPS Receiver
Want to update maps
Yes, you will need to download the webupdater program from Garmin to get new maps for your Nuvi 200. Transfer the files to your SD memory card and then plug that SD card into your Nuvi 200. Click on the link below to get started
http://www8.garmin.com/support/collection.jsp?product=010-00621-10
May 16, 2010 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 200 Maps Disappeared
Hope this helps!
I wanted to add maps to my 250W. I found the maps I wanted on a Torrent. However, many searches around various forums never revealed how to install these. Found the following through reading and experimentation.
1. Downoaded map image file GMAPSUPP.IMG. Download also gave me "Use code XXX when generating unlock code for maps"
2. Downloaded Garmin Unlock Generator 1.3 by JetMouse
3. Looked on my GPS to find the UnitID
4. Entered the UnitID into Garmin Unlock Generator. Ignore the GM XT device unlock code and the top Generate button.
5. Selected Map Product as Custom and entered the code given for the downloaded image file.
6. Hit the bottom create button to generate a 25 digit code.
7. Download Img2Gps and run
8. Click Load Folder to load the image file. Select the tick next to it.
9. Check the Use Unlock Key option and paste the 25 digit code in.
10. Load a blank SD card into your Garmin
11. Connect the Garmin to your PC using a USB cable. You should see two dirves in windows: one is the Garmin and the other is the "Removable Disk" SD card.
12. Create a folder called "Garmin" on the SD card
13. Select Folder/Card in Img2GPS
14. Click "Copy Maps". Select the folder /Garmin on the SD card. You may need to click copy again.
15. Upload will take a while.
16. You should now see a file GMAPSUPP.IMG on the SD card in the /Garmin directory.
17. Create a new text file called GMAPSUPP.UNL in the same directory (make sure it does not have a hidden .txt extension).
18 copy the 25 digit unlock key into this file.
19. Close the file.
20. Disconnect the Garmin.
21. On Startup it should load your original maps and the new ones.
May 28, 2009 | Garmin nuvi 200W GPS Receiver
I have a garmin nuvi 750 and I have a map source map downloaded on my computer, I then put that map on a sd card with a card reader and when I put that sd card in my gps it does not show up anywhere. What...
I have never tried this way. I always use the Transfer function (send to device) from my map source. Either the SD card is too small or that procedure is not proper. Just use the Transfer function.
Oct 19, 2008 | Garmin GPS
Vista HCX Micro SD Problem
Vista only recognize gmapsupp.img files.Go to www.mapwel.biz/down.htm take MapUpload software then from mapsource select maps you want to transfer to sd card.Or directly from Mapsource select Transfer and send selected map to sd card.Maps must be unlocked.
Aug 19, 2008 | Garmin eTrex Vista GPS Receiver
USA MAPS
You need to buy a preloaded SD card, purchase maps from Garmin and download them to a blank SD card.
Dec 10, 2007 | Garmin nuvi 350 GPS Receiver
SC card
I am not able to look at the map, as it always direct me back to my home. How can I solve the problem ?
Mar 21, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
113 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
