Question about Baumatic Kitchen Ranges
The oven will light but will not stay alight. Do you think the thermostat is broken?
  • 833 Answers
Generally, there is an item called a thermocouple which is a safety sensor built into the gas valve.  This is a thin tube with a through 'bolt' on the end that screws into the valve.  It is supposed to sit near the burner.  It sees the burner lighting...or not.  If the unit is bad, the burner gas is shut off.  Find it, remove it, noting the exact placement.  Take it to the appliance parts guy and get a new one and install it.  If this doesn't fix it, the valve is bad.
Posted on Dec 04, 2008
  • charles
    charles Nov 14, 2014
    thats exactly my thought as well, but find a dude that you know to do it and avoid the 60 bucks!
  • 78 Answers
Gas ovens normally suppose to start after 45sec-1 min. If oven starts after 2-3 min and flame very low and thermostat indicator light stays on - replace glow ignitor.
Posted on Dec 02, 2008
New oven, but goes out soon after lighting but stays alight on second attempt
Better call maker and have them come out and fix it before something bad happens (still under warranty?).
Either that or return it!!!
Dec 31, 2015 | Ovens
Push knob in on oven sparks & lights release knob flames go out
Often on ovens you have to hold the knob down for a period of time before the flame will stay alight.
Try getting the oven lit then holding the knob down for 30 seconds. That should be more than enough time if that is indeed the problem.
Is it a new oven or has the problem just arisen? It
Jul 23, 2015 | Ovens
Top oven wont stay alight
Seems the Thermocouple (instrument that lets the oven know the gas is lit) is not working properly. Your ignitor is working thus allowing the gas to burn...but the heat is not moving down the thermo line to register as being lit. Thus the oven thinks gas is being pumped but not burning and turns off as a safety precaution. THere must be a thermostat sensor...usually a wire or tube that allows the heat from the burning flame travel towards a sensor...this is faulty...remove and replace.
Dec 02, 2013 | Ovens
Oven will not stay on
try turning the gas up slightly and holding the knob down a few seconds longer after it is alight.
Feb 09, 2013 | Bertazzoni Gas Range
Westinghouse oven LPG 527 wont stay alight and grill wont start
Normally the grill is completely separate to the oven. Press the ignitor before you turn on the grill, as, to ignite, oxygen needs to be present (ie: not flooded with gas) . and you should be able to see the spark from the ignitor in the grill. if you can't, then you may have problems with your ignition pack or ignition leads.
Feb 16, 2012 | Ovens
My cooker will not stay alight
check if the oven holes are not blocked by some dust or dirt, then try puting it on again.
Aug 03, 2009 | Indesit K344GX Gas Kitchen Range
Oven will not stay alight
You have aproblem with you ffd ( flamme faliure device which is located in the oven.. Or if your oven has a thermocouple that has gone. Yo need to replace either one of them depending which one you have in your oven
Nov 18, 2007 | Ovens
Kitchen Ranges Logo
339 people viewed this question
Top Baumatic Kitchen Ranges Experts
Greg Cann
Greg Cann
Vitaliy Gins
Vitaliy Gins
Treefrog15
Treefrog15
Are you a Baumatic Kitchen Range Expert? Answer questions, earn points and help others
