Question about Intel Motherboard
800MHz Dual Channel RAM on Intel D945GNT
I got an OCZ Platinum Revision-2 - 800MHz Dual Channel (i.e 1GB * 2) RAM modules and I have an "Intel D945GNT MotherBoard" running with 1GB RAM with a DRAM frequency of 266.7.
Intel's website mentions that only 667MHz is supported max... :-(
So, can I use the new OCZ RAM modules on my motherboard along with the old RAM module or atleast separately without the Old RAM???.. Any problems I may be facing because of doing that??
Thank you
Sam
  • psman1710 Nov 30, 2008
    Great... So it wont be a waste .. :)
    And are you sure it will run along with my old 1GB RAM module ... without any problems ??
    Thank You
    Sam
    Genius:
  • 1,061 Answers
YES U CAN BUT IT WILL ONLY RUN AT 667MHz.RichardM69
Posted on Nov 30, 2008
How to install 4 gig ram on EMachine 3611
You cannot. See table below.
eMachines W3611 RAM Specifications
Standard Memory 512 MB (removable) Maximum Memory 2.0 GB Memory Expansion 2 sockets Memory Comments PC2-4200 DDR2 SDRAM DIMMs. Supports Dual Channel DDR2. CPU Type 3.0GHz Intel Pentium 4 631 Model Comments 800MHz FSB, Intel 945G Chipset
Jun 09, 2014 | Computers & Internet
I want to upgrade my computer specs... hope you can help me.. CPU: intel core2 duo E4600 2.4Ghz/800Mhz/2mb L2 cache/65MOnm MOBO: elite 945GCT -M2/1333 (v1.0), 1945GC/C2D/1333MHZ/DDR2 667/PCI-E memory:...
If you are a "gamer" and you have 1GB of RAM, and you have Windows XP, you probably need more RAM.
If you are a "gamer" and you have 1GB of RAM, and you have Windows Vista or Windows 7, you DEFINITELY need more RAM.
Some motherboards support "dual-channel" mode, when you have 2 or 4 _IDENTICAL_ sticks of RAM. What happens is that each byte written to the RAM is "split" into 2 halves; one half is written to the 'A' stick of RAM, while, simultaneously, the other half is written to the 'B' stick of RAM. Obviously, this takes 4 "cycles" of the RAM, rather than taking 8 "cycles", if there was only one stick of RAM. So, your RAM seems to run at "double-speed".
So, when you buy more RAM, either try very hard to "match" your current 1GB stick of RAM, or purchase a "2GB dual-channel kit", or two "2GB dual-channel kits", to upgrade to 2GB (or 4GB) of RAM.
Aug 04, 2011 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Asus p5gl-mx 915GL chipset dual channel ddr400 no display
try to change your RAM random access memory
Regards
manish
Mar 25, 2010 | Intel Asus P5GL-MX 800MHz FSB 915GL...
Are OCZ PC3 1333 ddr3 1.65v memory compatible with
Intel's web site for the board has the following:
The Desktop Board supports the following memory:
  • Four 240-pin Double Data Rate 3 (DDR3) SDRAM Dual Inline Memory Module (DIMM) connectors with gold-plated contacts arranged in two channels
  • 1333/1066 MHz DDR3 SDRAM interface
  • Support for single- and dual-channel memory interleaving
  • Unbuffered, non-registered single- or double-sided DIMMs with a voltage rating of less than 1.6 V. Using a DIMM with a voltage rating higher than 1.6 V may damage the processor.
  • Non-ECC DDR3 memory
  • Serial Presence Detect (SPD) memory only
  • Up to 16 GB maximum total system memory
You need to contact TigerDirect and have them change out the memory for sticks that meet the above specs.
Jan 25, 2010 | Intel Computers & Internet
Memory confusion different readings
It sounds like something isnt working right, what operating system are you using, Vista? I would take out the original 512 and see what it says after, often ram isnt compatible if it is too different in size and speeds. Also, if your motherboard supports dual channel ram and you have the extra 512 chip it wont run in dual channel mode, you would run better with just the 2 chips then the added 512 chip.
Jan 17, 2009 | Mach Speed (S755) Motherboard
MOBO intel DG31PR - OCZ 4gb dual channel - AUDIO problem.
This sounds to me that there is an interupt problem with your computer system. Take a look at the manaul that came with your computer at the time of purchase, it will have information on installing extra memory and setting up interrupts etc.
let me know how you get on.
regards,
Philip
Dec 01, 2008 | Intel DG31PR Motherboard
Does OCZ Platinum 2GB ram work on Asus M3A32-MVP Deluxe/WiFi?
probably not , each motherboard has a certain setup for the ram slots , best to ask your computer parts store for the best ram for your motherboard , they can also give you a deal on used ram
Oct 06, 2008 | Computers & Internet
Intel D865GBF Ram related questions
here are the specifications of *********** board go through it...
Processor Support Intel® Pentium® 4 processor, Intel® Celeron® D processor and Intel® Celeron® processor in the 478-pin package
Note: It is important to verify supported processors before using this Intel® desktop board. Supported front side bus speed 800, 533, and 400 MHz Integrated Graphics Intel® 865G Chipset with Intel® Extreme Graphics 2 Chipset Intel® 865G Chipset AGP Connector AGP 3.0 (4X & 8X Speed 1.5 and 0.8 Volt Only) Memory Type Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100).
Note: Be sure to review important memory and system bus speed considerations before using this Intel® Desktop Board Max Memory Capacity of up to 4 GB Memory Slots 4 DDR DIMM Sockets Slots 6 PCI
So it will support DDR2 and you can upgrade upto 4GB...
Sep 28, 2008 | Intel D865GBF Motherboard
Suitable dual-channel memory module for ASUS P5N-D
Hi hellinme, since you want to go with Kingston, can I suggest this link. http://www.ec.kingston.com/ecom/hyperx/modelsinfo.asp?root=
I picked the memory you wanted. DDR2 800MHz. Than picked, Asus for the board & scrolled down through motherboards till I came to the P5N-D board. Listed there will be kingston hyperX memory suggested to work the best for the motherboard.
The memory, KHX6400 D2ULK2 2G(2x1gb), is not listed.
Enjoy!
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 27, 2008 | ASUS Computers & Internet
Problem qdi p4i865 pro
Check your manual and find the QVL list. Memory tested to work in your board is listed there. I found a link that shows your board. Click the Download on the left & check your manual.
http://www.qdigrp.com/qdisite/eng/news/20030521.htm
You Max speed is 400Mhz memory as you will see at the link.
Please vote...
Dec 26, 2007 | Computers & Internet
Intel Motherboard Logo
139 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
