Question about Intel Motherboard
Boot from cd
I have an older ibm aptiva desktop that has a missing or corrutt file, im trying to boot from my cd to fix or reformat the hard drive. my problem is i dont know the key to boot to cd, hope you can help, thanks chris
  • arh55555 Nov 30, 2008
    THE F1 F12 DEL GOT ME TO THE SCREEN BUT WHEN I PRESS A KEY IT JUST BEEPS
    I HAVE THE KEY NOW BUT WHEN I PRESS A KEYSTROKE IT JUST BEEPS
Firstly open ur bios press f1 /del/f11 at pc startup going to boot option then select ur cd/dvd rom. save your bios setup then after restart.press ur setup cd inur rom drive.
Posted on Nov 30, 2008
    Genius:
  • 1,913 Answers
When u power up the computer press DEL or F2 or F10 F12 key to enter bios setup.
then go to boot option then set your dvd or cd as first boot device.
I want to use a system usb to boot to the usb drive of a xp professional IBM Aptiva desktop pc
How about this, Boot to safe mode with Networking. Download MALWAREBYTES at : http://www.filehippo.com/download_malwarebytes_anti_malware/ Run a FULL SCAN, Delete ALL results, reboot. ALSO, run YOUR UP-TO-DATE Anti Virus, a Full Scan.
Jan 16, 2013 | IBM Aptiva E 240 (2158240) PC Desktop
I canot boot my pc i select f12 then coming boot menu i select boot from cd rom but not display press any key to boot
If I understand what you are asking, you want to boot from CD but the boot from cd/dvd at start up is not showing up. It sounds like you have set in your BIOS enable boot from CD/DVD, But to be able to boot from CD/DVD you need to "in your BIOS" go to drive manager or it could be called boot drive priority, something llike that and put the CD/DVD drive first or at least before your Hard Drive.
That should make this show up for you now as long as its a bootable CD/DVD disk.
Hope this helps.
Nov 18, 2011 | IBM Aptiva 75G PC Desktop
I cant install windows xp in my ibm m51 8141 dekstop when i boot system to cd rom then after few minits the system show the error "windows ini file cant loaded" i have 3 windows cds but i try the...
You may have to Reformat your hard drive first. The current hard rive may have a bad operating system on it or one that is newer than XP. In some cases, when a computer has a more current operating system installed, it will not allow an older operating system to write over it. That is why I said, reformat the hard drive. Remember, hardware drivers are written for Windows 10 now, so old drivers may not be functional any longer.
Jan 14, 2018 | IBM ThinkCentre M51 PC Desktop
My laptop had been working fine, then the last
Hi yes try this, if no joy come back to me.
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing ESC button, or delete in some machines. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Jul 10, 2010 | IBM ThinkPad A30 Notebook
How do I take out the hard drive from my IBM Aptiva?
Open the case look for a black oblong hard drive, remove the 80 pin cable, and then remove the mounting screws from the drive and slide it out of the bay.
Jan 25, 2010 | IBM Aptiva E 2170 PC Desktop
I have an old ibm aptiva with usb port nad trying ot transfer files to external hard drive, however it doesnt recognize the harddrive, what can i do?
Depending on the external drive (try it in another computer first) the case may be bad. You can purchase an IDE cable at your local computer store, take the hard drive out of the case, plug it in directly, and voila!
Jan 13, 2010 | IBM Aptiva E 240 (2158240) PC Desktop
A disk read error occurred press ctl-alt-del to restart goes back 2 same scrn
Sounds like the hard drive has errors.
Boot to a windows XP cd.
Repair using the windows console.
at the repair console type:
chkdsk /R (hit enter)
Let that run, it takes a long time.
If it's able to repair the drive enough for operation it will.
If it cannot you will be forced to replace the hard drive.
HTH
Aaron
May 23, 2009 | IBM Aptiva E 2170 PC Desktop
Need help transfering data from IBM Aptiva to Dell computer
Sounds like the older computer is a 98 machine - Data Traveler does not have 98 drivers due to its size. Your best bet is to find a smaller flash drive that is 98 compatible - or depending on the size of the data you could e-mail it to yourself.
Jan 09, 2009 | IBM Aptiva E 240 (2158240) PC Desktop
Aptiva 2270
Here is a link to Microsoft Support dealing with this error.
http://support.microsoft.com/kb/318728
Oct 25, 2008 | IBM NetVista PC Desktop
Intel Motherboard Logo
182 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
