Question about JVC GR-D250 Mini DV Digital Camcorder
JVC GR-D350U Digital Video Camera "Communication Error"
My battery will not charge and when I plug in my power cord to tape I get a "communication error". The picture it shows indicates that there is a problem between the camera and my battery. I have only owned it 4 months and have used the battery before to tape with no problem. I am thinking the battery is bad and/or the power cord is no good. Any other thoughts?
  • JayMitch May 31, 2008
    Same problem here!!!! Solution urgently required....
  • Mstewart0494 Jan 20, 2009
    Ok, I have the same problem as posted here. I owned my camera for about six months when the problem started. As for having a cheap battery... I have the original battery that came with the camera. If anyone knows of a solution or somewhere that can fix it for a reasonable cost. Let me know please.
Just found a workaround for the "cheap battery" problem. The problem is that there is some circuitry in the more expensive JVC batteries that the generics don't have. When this isn't detected by the camcorder, it won't function. It's a neat trick to make you buy the proprietary battery. Also suspecting that with the JVC battery, if the circuitry gets fried for some reason, the battery will no longer work. Well, the generic battery I have has a plug in the back of it so you can charge it with the JVC factory supplied charger. There was also a jumper cord supplied with the camcorder. Plug this in the back of your cheap battery, plug the other end into your DC port on your camera, and voila! You're in business. Downsides are that you have a short cord between the battery and camcorder and the battery indicator won't work so you'll need a spare.
Posted on Jul 31, 2007
Same problem here. i have the same camera, and it just started doing the "communication error"
Posted on Mar 25, 2008
I have exactly the same problem! Just looking on the net for a solution myself. I don't think that there is anything wrong with the batteries - have a feeling its the camera. Looking for my receipt and going back to the store today. had the camera since August 06 (7 months).
Posted on Apr 08, 2007
Camcorder jvc gr-d740e
camera not charging when switched on message comes up communication error
May 13, 2011 | JVC GR-D720 Mini DV Digital Camcorder
Jvc HDD battery communication error
Did your battery came with a small, short cable? If yes:
- turn off the camera
- plug the cable in the camera but DO NOT attache the battery to the camera
- turn on the camera
- if the camera is working, than the battery is working.
- tape off with electrical tape the battery terminals - all of them. Now you can attach the battery to the camera.
Mar 15, 2009 | JVC GZ-MG330 HDD Camcorder
Camcorder Communication Error from Battery to Camera
Not 100% sure but when my gz-hd3u had the same problem I cleaned as well as pushed in all the battery connect pins on the camera. one of the middle pins detects if the battery is installed.
Nov 30, 2008 | JVC GR-D290 Mini DV Digital Camcorder
Communication error?!
I'm betting you bought an aftermarket battery and not an original JVC battery. The error message you are getting is caused by the camcorder not being able to read the charge sensor in the battery. Some of the aftermarket batteries neglect to put that sensor in the battery, or have a sensor which does not match the OEM sensor in a factory battery. Try an original JVC battery. Is this solution answered your question bu sure to rate it. Thanks!
Oct 23, 2008 | JVC GR-D750 Mini DV Digital Camcorder
JVC gr-d350u camcorder
TRi to check the take up wheel and idler gear or capstan motor is engaged with idler gear.
Jul 15, 2008 | JVC GR-D350 Mini DV Digital Camcorder
Lost power cord
See the links below for the part you are looking for.
A/C Adapter (plugs into camera)
Battery Charger (charges battery without camera)
Mar 05, 2008 | JVC GR-D250 Mini DV Digital Camcorder
Camera dead
there is a fuse blown it happens alot just make sure when you send it in that the shop is a certified jvc or a jvc only repair shop some places fix alot of different brands of cameras and sometimes you might not get it fixed right away because of the workload or not at all
Dec 29, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Digital Cam
If your batteries are NOT JVC batteries, then the problem is with your batteries. JVC batteries have some "smart circuitry" in them that helps the camera know and tell you how much juice is left. After about 20 seconds, the camera gives up trying to get the info from the non-JVC batteries and displays the communication error.
Real JVC batteries could fix the issue.
Nov 27, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Camcorder (used only twice)now says communication error
Try using the orijinal JVC battery, sometimes compatible batteries cause this kind of problems.
Jun 18, 2007 | JVC GR-D250 Mini DV Digital Camcorder
JVC camcorder GR-D350U
You have a clogged video head. Use a dry type head cleaner and follow the instructions. Better use the best tapes you can afford, since tape quality can keep you from having this problem, and tape cleaners can gradually damage your camera. Good luck
May 27, 2006 | JVC GR-D350 Mini DV Digital Camcorder
Open Questions:
Audio drop out and/or static sound Thanks to anyone who has taken a look at my issue with audio cutting out. JVC has always been a brand I have confidence in, and I believe I picked this camera up when those recording to an internal hard drive were out of my range. Last summer, I received a fantastic deal on some JVC Evarios, so GR-D250 duo would be used only as back-up, BUT, I have a ton of old Mini DV tapes -- never recorded over anything. I would find the heads needing cleaning solution highly unlikely. The first 250 recorded the bulk of those 150 or Mini DV's and worked like a champ. Because of legal depositions for lawyers and like, who may not want for me to call time-out in a deposition to switch tapes and the fact that eventually my first was going to give out, having a back-up and eventually multiple seemed like the thing to do. Having a couple of friends film some sports events I could my mix radio play-by-play I could with dual camera angles was cool. This same-year model second buy had sat in storage; The original tape the who sold it to me with 10 minutes of footage came with it. I could tell the battery was so much stronger after a full charge than my old one, but this newer D250 has maybe had 1/10 the recording time as my original. Whether listening to the camera speakers, piping the sound from the rear A/V jack or importing via firewire, it's the same. The video may not be perfect and may "spark" or "flicker" in unison with the audio that drops out,but not always. At times, the video seems just fine but the audio drop-out is akin to a loop and I could probably time it, which was what I termed as cyclical. Could one of my friends have dropped it or tipped over a tripod and not told me? Sure, but I would think they would have told me. One night, follow some high school hoops I was importing, excited at the prospects of some two camera angles mixing. Thought I may have had a bad tape, but ruled that out right away through trying multiple tapes in bother cameras. Apologies for my loquacious follow-up; I suppose if worse comes to worse, I could check eBay for a secondhand model. I've "misplaced" my original, but it will turn up; it's simply a matter of desiring to import all that footage, since 2008, with superior editing software and skill than what I possessed when doing so initially. Thanks so much!
Apr 13, 2014 | JVC GR-D250 Mini DV Digital Camcorder
See all JVC GR-D250 Mini DV Digital Camcorder Questions
JVC GR-D250 Mini DV Digital Camcorder Logo
1,765 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
