Question about Pioneer DJM-600 Silver Professional DJ Mixer with Auto Beat Cou Home Equalizer
Master channel problem
the master channel when moved off 0 peaks red on left db.
i have tried different connections and last of all disconnected everything and still i have the same problem. is this something i can possibly fix/ order the parts required??
thanks
  • 515 Answers
There is a master gain volume on the rear of the unit. Make sure this is not maxed out. Keep it between 1/2 to 3/4's of the ay up.
If this does not solve your problem, your going to have to give me more details. What do you mean when you say "moved off 0 peaks red on left"? Do you mean that when you lower the master volume, the left signal is still hot (red)?
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Posted on Dec 18, 2008
Hello, I have a telefunken ttv-2131. Moved houses, Please help me to tune it show the channels clearly, Thanks, Georgie
if you are using an areal antenna tried to move in other direction to get good channel reception .
Aug 09, 2012 | Televison & Video
Unable to get record levels to peak when recording onto HDD. There are input sound levels but they are well below acceptable levels. Any clues as to how to get the unit to display the correct and thereby...
Your source may have a role to play in available volume being too low.
Page 84 describes Volume controls for both analog and digital inputs.
You don't really want to play chicken with 0 dB (all digital ones). Leave some headroom for unexpected peaks.
BTW: a digital copy of, say, a commercial CD with no volume modification will be at the optimal level that may meet but won't exceed the 0 dB level.
Mar 14, 2011 | Yamaha CDR-HD1300 CD Recorder
Can i hook this amp to a 2 channle out put stereo?
Sure. Specs are listed below. I think it's designed for regular 2-channel input, isn't it?
Front Channels: 100 W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
  • Rear Channels: 25 W RMS x 2 @ 1.5 ohm-4 ohm(11V-14.5V)
  • Subwoofer Channel: 250 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
  • THD at Rated Power: <0.03% @ 4 ohm (F&R), <0.05% @ 4 ohm (Sub)
  • S/N Ratio (F&R): >108.5 dB below rated power S/N Ratio (Sub): >95 dB below rated power
  • Frequency Response (front and rear): 5 Hz-30 KHz (+0, -1dB)
  • Frequency Response (sub channel): 5 Hz-500 Hz (+0, -1dB)
  • Damping Factor (front and rear): >200 @ 4 ohm/50 Hz
  • Damping Factor (sub channel): >500 @ 4 ohm/50 Hz
  • Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
  • Differential-Balanced Input Topology: (3 pairs of inputs)
  • Front Crossover: fully-variable (50 Hz-5 KHz), selectable- slope BP or HP (12 or 24 dB per octave)
  • Rear Crossover: fully-variable (50 Hz-5 KHz), selectable- slope HP (12 or 24 dB per octave)
  • Sub Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
  • Preamp Output: 2-channel (full-range or LP)
  • Bass EQ: Variable boost up to 15db
  • Infrasonic Filter: defeatable 24dB/octave at 30 Hz
  • Left minus Right Ambience Circuit: ambient effect for rear channels
  • Front and rear speaker output connections: accept up to 8ga. wire
  • Dual mono subwoofer output connections: accept up to 8ga. wire
  • +12V and Ground connections: accept up to 4ga. Wire
  • Dimensions: 19.7"L x 9.25"W x 2.36"H
  • Dec 02, 2010 | Jl Audio 500/5 Car Audio Amplifier
    Colors of the wires for CX 400 headphones
    yellow and red-green are most likely grounds. red is normally the right channel and green is normally the left channel. quick question though, why on earth would you cut the plug off of a pair of 75-90$ headphones?
    Apr 15, 2010 | Sennheiser CX 400 Headphones
    I need an owner's manuel for a Pioneer stereo power amp SPEC-4. I have a part # ARB-235. I think this amp is a product of the 1970's. Where would I be able to get my hands on the operating instructions?...
    You can register with hifiengine.com andfind it and the service manual.
    There really isn't a lot to a power amp to be operated. This one differs from most in that it has an input level control and VU meters.
    From http://images.google.com/imgres?imgurl=http://www.incomesixdigits.com/spec4/spec4a.jpg&imgrefurl=http://www.incomesixdigits.com/spec4/&usg=__WbFLwPqHXjFHe_P2BCKyTT9CxQY=&h=652&w=1156&sz=526&hl=en&start=2&um=1&itbs=1&tbnid=5SVKh2leUGWXmM:&tbnh=85&tbnw=150&prev=/images%3Fq%3Dpioneer%2Bspec%2B4%26hl%3Den%26rlz%3D1R2ADFA_enUS360%26sa%3DX%26um%3D1
    Dynamic 150 + 150 Watts Power Output, Generous High-power Design
    The Spec-4 employs DC construction which excludes capacitors from the NFB circuits and uses a dual transistor differential amplifier with a current mirror circuit in the 1st stage. This provides a stable operation and also high gain over a wide frequency range. The pre-driver stage is a class A amplifier circuit with a regulated current circuit for the load. This makes for high-gain amplification with superior linearity. Furthermore, there is an overdrive limiter and power limiter circuit which is designed to protect the power transistors and make for added reliability.
    The power stage employs a 3-stage Darlington pure complementary parallel SEPP circuit.
    The SPEC-4 delivers Continuous Power Output of 150 watts per channel, min. RMS, at 8 ohms from 20 Hertz to 20,000 Hertz with no more than 0.01% total harmonic distortion.
    Completely Independent and Perfectly Stable Left / Right Power Supplies
    The mighty power supplies are completely separated for the left and right channels. Also, each channel is provided with two 22,000uF large-capacity electrolytic capacitors and large transistors with a superior regulation. They achieve outstanding channel separation and a clear, powerful reproduced sound, in addition to the wide frequency response. There is a built-in surge killer circuit to suppress inrush currents from the power transformers and high currents which charge the electrolytic capacitors. This circuit ensures that none of the parts are affected by these adverse currents.
    Protective Circuits Composed of Fast-response Relays and Electronic Circuits
    Each channel is protected by a DC and over current detection relay circuit. In the event of the speaker terminal shorting due to poor connections or when DC current is generated in the output, the output circuit is immediately disengaged and the speakers and transistors are safeguarded against any possible damage. The protective circuits also function as muting circuits when the power switch is turned on and off.
    Peak Level Meters with Outstanding Waveform Response
    This power amplifier incorporates logarithmic compression peak meters with a wide scale (-40 -+3dB). With 8-ohm speakers, they allow the output to be read out from 0.01W to 300W. Moreover, the meters feature a fast response for peak signal indication. In addition to the peak output reading, it is easy to interpret the dynamic margin with respect to the SPEC-4’s clipping level.
    Input Level Controls with dB Calibration
    The SPEC-4 is equipped with input level controls with direct readout attenuation values (-dB). These can be used to continuously adjust the input levels for each channel in accordance with the rated output voltage of the preamplifier. In this way, the SPEC-4 can perform the proper gain control according to the preamplifier’s output level. The preamplifier will thus be used in the condition possible for the best S-N ratio and distortion characteristics.
    Stylishly Professional Front Panel Design
    Just as you would expect from a sophisticated system, the SPEC-4’s front panel is professionally designed with the large level meters in the center. Also. The front panel’s dimensions allow the model to be mounted in an EIA standard rack, just like real professional-use amplifiers.
    SPECIFICATIONS
    ICs………………………………........................................2
    Transistors………………………………...........................61
    Diodes……………………………….................................62
    Power Amplifier
    Circuitry………………………………Current mirror loaded differential Amplifier
    3 stage darlington parallel push-pull
    Direct-coupled OCL. (DC amplifier construction)
    Continuous Power Output of 150 watts * per channel, min. RMS, at 8 ohms from 20 Hertz to 20,000 Hertz with no more than 0.01% total harmonic distortion, or 180 watts per channel at 4 ohms from 20 Hertz to 20,000 Hertz with no more than 0.03% total harmonic distortion.
    Total Harmonic Distortion (20 Hertz to 20,000 Hertz, 8 ohms)
    Continuous rated power output………………………………................................0.01%
    75 watts per channel power output……………………………….......................... 0.01%
    1 watt per channel power output……………………………….............................0.01%
    Intermodulation Distortion (50 Hertz to 7,000 Hertz = 4:1, 8 ohms)
    75 watts per channel power output……………………………….........................0.005%
    1 watt per channel power output………………………………........................... 0.005%
    Frequency Response………………………………...............5 Hertz to 100 kHertz +0/1 dB
    Input (Sensitivity / impedance)……………………………............................1V/50k ohms
    Output
    Speaker……………………………….................................................4 ohms to 16 ohms
    Damping Factor (20 Hertz to 20,000 Hertz, 8 ohms……………………………….........100
    Hum and Noise (IHF, short circuited, A network………………………………........11 5dB
    Miscellaneous
    Power Requirements………………………………...................................AC 120V 60 Hertz
    Power Consumption………………………………..........................................760 watts (UL)
    Dimensions………………………………..............................480(W) x 187(H) x 445 (D)mm
    18-7/8 x 7-3/8 x 17-7/16 in.
    Feb 10, 2010 | Audio Players & Recorders
    Our two left speakers, front and rear will not
    Check the connection on the back of the receiver. Check the balance setting, make sure that it's in the middle. Try another mode like stereo, you should hear left and right front only. Also, if your receiver has an on screen menu, check the dB levels for the front and rear left speakers. Good luck!
    Dec 09, 2009 | Audio Players & Recorders
    Left meter problem in Nakamichi cassette deck .
    I once had the same problem with a philips deck, except that both meters were twitching and both channels were distorted.
    And guess what - it started happening when i reassembled it after i oiled the motor axis as it was a bit noisy.
    No, that doesn't mean this had anything to do with the motor, but i had to disassemble the deck once more, i moved the wires and connectors a bit and the meters and outputs returned to normal functioning, so my guess is that there is a bad connection somewhere.
    Try disconnecting the connectors inside the deck, see if the contact pins are dirty or oxydized, if so, clean them and reconnect - this might help.
    Also check for any broken or shorted wires, broken insulation on wires and bad solder contacts.
    I don't know if this will help, it sure did in my case, but i guess it's worth trying.
    good luck
    3rq8 (Triarcuate)
    Jul 26, 2009 | Audio Players & Recorders
    Do you have instructions for wiring install on volfenhag GX8200??
    Amplifier Class AB
    Number of Channels 2
    RMS Power (4 ohms) 120 watts x 2 channels
    RMS Power (2 ohms) 200 watts x 2 channels
    RMS Power (1 ohm) Not Stable
    Bridged RMS Power 400 watts x 1 channel
    Total RMS Power Output 400 watts
    Peak Power Output 1000 watts watts x 1 channel
    Minimum Impedance Unbridged 2 ohms
    Minimum Impedance Bridged 4 ohms
    THD at Rated RMS Power 0.1%
    Speaker Level Inputs No
    Preamp Outputs 1 pair
    Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
    High-Pass Crossover Frequency 40 - 250 Hz
    Low-Pass Crossover Frequency 40 - 250 Hz
    Subsonic Filter N/A
    Signal-to-Noise Ratio N/A
    Channel Separation N/A
    Bass Boost 0 - 18 dB
    Bass/Gain Remote Yes
    Fan Cooled Yes
    Fuse Rating 20A x 2
    Dec 24, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
    Setting up a Computer to install Windows XP Professional.
    Pedro -
    I'll assume each of these is an IDE device, meaning each has a wide connector versus a narrow SATA connector commonly found on newer hard drives.
    Your motherboard should have two IDE channels, labeled IDE 1 and IDE 2, Primary IDE and Secondary IDE, or something similar. Each IDE channel can support two devices.
    For best performance between the drives, you will want to have the Hard Drive connected as Master(Drive 0) on the Primary IDE channel; The CDROM should be connected as Slave(Drive 1) on the Primary IDE channel. Connect the DVDROM as Master(Drive 0) on the Secondary IDE channel, and the ZIP Drive as Slave on the Secondary IDE channel.
    When connecting the drives, make sure you set the jumpers correctly; Both the Hard Drive and the DVDROM should have their jumpers set to Master, the CDROM and Zip drives should have their jumpers set to Slave. An alternative is to set the jumpers for every drive to Cable Select(CS), allowing the physical connection of each drive to determine whether its a Master or Slave device.
    *Note*
    If your Hard Drive is a SATA device, connect it to the '0' or '1' SATA connector on the motherboard. Have the DVDROM set up by itsself as Master on the primary IDE channel, the CDROM as Master on the Secondary IDE channel, and the ZIP as Slave on the Secondary IDE channel.
    Hope this helps!
    -thinstatic
    Jun 11, 2008 | ASUS P4S8X-MX Motherboard
    154 people viewed this question
    Top Pioneer Audio Players & Recorders Experts
     Grubhead
    Grubhead
    John
    John
    Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
