Question about Canon PIXMA iP4300 InkJet Photo Printer
Blure text when I print a text, some lines are missing or come out blur.
  • 14577 Dec 01, 2008
    Sounds similar to my problem...how do I find Printer properties to check if the printout is set on draft mode please?
  • Kamiliada Dec 01, 2008
    Now the quality of the printout is much better, The detailed instruction for trouble shooting is in- on-screen Canon manual guide .
    I opened printers properties box then I used maintenance options.
    Sergeant:
  • 217 Answers
Three options to be checkout. 1)the cartridge ink is near to empty.if this is the case  get your cartridge refilled or replace it with new. 2)the head unit in which the cartridges r installed.in that head the holes from where the ink comes out may be blocked so it needs cleaning manually by removing the head. 3)or the third option the printout is set on draft mode .if this is the case go to printer properties and change that draft setting to normal mode printing.
Posted on Nov 30, 2008
Epson workforce 600 blurry 5th line
Update: Blurring of every 5th line occurs in text mode but not text & image mode. Know of a way to see text & image as default for all print jobs?
Aug 18, 2012 | Epson WorkForce 600 All-In-One InkJet...
Hi - I have a 3-4 year old Canon Pixma IP4500. The initial problem was blurring in places on black text. Nozzle check showed that bottom half of PGBK grid was missing horizontal lines. Took out the print...
one idea is that you rouined printhead with tap water and second idea is to buy new print head or printer.
Note: If you want to replace ink head, be sure to replace purge unit and ink absorber also.
Sep 02, 2011 | Office Equipment & Supplies
I bought some cheap toner and noticed almost immediately streaking and missing lines. I replaced it with HP toner but now black won't print at all.
If your printouts are streaked or faded, missing black or other colors, have blurred or fuzzy text, or ink streaks or smears, or show other problems, please refer to the link below for troubleshooting steps for print quality issues.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01957673&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=2512009
Apr 03, 2011 | HP Officejet Pro L7680 All-In-One Printer
Colors print blurred
you need to run the nozzle deep cleaning utility, nozzle check and alignment procedure under the printer properties maintenance tab.
Please rate this solution. Thanks.
May 27, 2010 | Canon i860 InkJet Photo Printer
Printer printing blured images and text. It looks as if the printer prints a line then about 1/8 to 1/16 if an inch it prints the same line again.
You need to run a new alignment on the machine, Assuming you have the software installed open up the hp help center and print an alignment page after that look at the numbers and letters and line up the marks by selecting the numbers closet to the perfect alignment that you can see after you have finished click on the front of the printers OK button.to finish they try printing a new page. If this does not help try updating your software at http://www.hp.com.
Dec 24, 2009 | HP PSC 1210 All-In-One InkJet Printer
Our Sharp projector Model PG-B10S is Flickering and blurred text? is this problem associated with bulb?
the flickering could be the lamp, but as for the bluring: if it's pixelated, it's resolution. make sure the computer and projector have the same. if it's not pixelated bluring, it's an optical problem. either the lenses are dirty or misaligned.
Jul 01, 2009 | Sharp Projector lamp Projector Lamp
Printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Mar 20, 2009 | HP DeskJet 9800 InkJet Printer
Some lines are blurred, Some lines are printed larger, Some lines
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 02, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Lines of text are blurred or jagged
Hey, Matthew here. If you go in to the settings of the printer and then advancd, there should be a head alingment options- it will print out some pages with crooked and straight lines and ask you to pick ones to calibrate it. It is very easy and should only take 5mins. Hope this helps, Matt.
Dec 31, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Canon PIXMA  iP4300 InkJet Photo Printer Logo
140 people viewed this question
old marine
old marine
Corne Viljoen
